Go Back   Subaru Legacy Forums > Technical Forums > Interior/Audio
Reload this Page Oem iPod integration kit won't work
#1: 04-14-2011, 09:38 PM
 Rushin
Car: 08 spec b
Send a private message to Rushin Find all posts by Rushin Reply With Quote
First the car: 08 spec.b, apprenty the car is actually 07. Bult date is late 07. I was told that the wiring in my car is all 07 and my stereo is 07 not 08.
So I ordered OEM iPod integration kit. Installed it and it plain does not work. I hit the SAT button and I goes to the iPod kit, when I plug the iPod it says attached but no Subaru logo on the iPod, no charging the iPod and no music obviously. Tried it with 4 and 5 gen nano, original iPhone and iphone4. Non work.
Any ideas? Did I just wasted 150 dollars? Whyi legacy has the worst stereo of pretty much all modern cars? (really a rhetorical question.)
Rushin
Find More Posts by Rushin
#2: 04-16-2011, 10:29 AM
 RabidWombat
Car: 09 DGM LGT Stage 0, 08 DGM Impreza
Send a private message to RabidWombat Find all posts by RabidWombat Reply With Quote
Is the ipod fully charged? You'll need an adapter cable for charging any of the newer iProducts. It should still show the Subaru logo though, it just won't charge.
RabidWombat
Find More Posts by RabidWombat
#3: 04-18-2011, 08:57 AM
 Rushin
Car: 08 spec b
The charging is not the issue. It just won't communicate with the ipod. If my stereo has a SAT button but nothing happens when i press it does it mean i have the SAT radio or it means its just not activated?
Rushin
#4: 04-19-2011, 07:19 AM
 vr4Legacy
vr4Legacy's Avatar
Title: Contributing V.P.
Car: '06 Elantra (his) /'11 Outback (hers)
Send a private message to vr4Legacy Find all posts by vr4Legacy Reply With Quote
^ You have to buy a seperate Satellite radio module that bolts under your stereo and plugs in where your ipod interface is now plugged in. From there you will get your usual sat info until activated (Channel 1, radio id, etc...)
So if you took out your stereo and there was nothing plugged into it when you installed you adapter, your car is Sat-ready, but not Sat-equipped.....
As for the iPhone question, I have no idea, but I am thinking about picking one up, but not if it doesn't charge.... subscribed for more info.
vr4Legacy
Find More Posts by vr4Legacy
#5: 04-19-2011, 07:24 AM
 joedirtae09
joedirtae09's Avatar
Car: 2008 DGM LGT Limted, Stg 2
Send a private message to joedirtae09 Find all posts by joedirtae09 Reply With Quote
I may be wrong about this but I think I read some where on here that if you have the SAT button, you cant have iPod intergration.
On my 08 LGT, I just use the AUX button to listen to my iPhone.
joedirtae09
Find More Posts by joedirtae09
#6: 04-19-2011, 07:27 AM
 vr4Legacy
vr4Legacy's Avatar
^ there is a newer kit that you can buy. It plugs into your sat input in the rear and essentially ports through that and gives you iPod integration with your controls.
Does anyone know if you can connect this in tandem with the SAT?? Meaning can I have integrated Sat and iPhone?? or is an either or?
vr4Legacy
#7: 04-19-2011, 12:18 PM
 dsickles
dsickles's Avatar
Car: 2008 Legacy 3.0R Limited
Send a private message to dsickles Find all posts by dsickles Reply With Quote
ive never been able to get a straight answer on this... so id be curious as well.
dsickles
Find More Posts by dsickles
#8: 04-20-2011, 07:27 AM
 vr4Legacy
vr4Legacy's Avatar
I've read through the whole other thread in the audio forum about the integration kit
http://legacygt.com/forums/showthrea...kit-66267.html
After 27 pages and reading the actual users manual that comes with the OEM kit this is what I've concluded.
It CANNOT be used in parallel with XM, it's either or. This is stated implicitly in the manual.
It was created for pre 5v iProducts (i.e. iPhone 3Gs, 4 iPod Touch and new gen iPods) the old iProducts used 12v for charging, the new use 5v. There was a change to the pinout so the OEM kit will not charge the newer products if they have updated OS because it recognizes the different pinout. Apparently you can get a passthrough from Scosche that address this.
As for integration, it should work just fine. You may get the "not supported" message but cancelling it should still work. Many people seem to be using them fine.
The newer kits say they work with iPhones, so I am guessing the pinout was updated on those. I would hope a product sold in 2011 would work for a phone purchased in 2009
Myself, I bought a cable a few months back that hooks to my iphone and has two output cables.
http://amzn.com/B003X78QCG
One is a usb cable for chargin, the other is a 3.5mm aux plug for audio. So I can now hook my phone up to ONE cable and get charging and audio. I did need to buy a usb adapter plug for my power port, but that will come in handy for other devices too. I have since come along some cords that have the plug built in for a cig outlet.
My only negative is that it doesn't charge the phone as quickly as a regular charger, but I think that's because I bought a 2 usb adapter and it's not outputting enough amps. I think I'm gonna pickup another single usb adapter and see if that changes anything.
However the setup now does not drain the battery when listening, it at the very least maintains a charge.
vr4Legacy
#9: 04-20-2011, 08:01 AM
 joedirtae09
^ I got a similar cable off of eBay a couple months ago. Havent had any issues with sound quality or charging.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEAFB:IT
But it definetly doesnt charge as fast as a regular USB charging cable, probably because its off brand no name.
joedirtae09
#10: 04-20-2011, 08:17 AM
 RabidWombat
The iPod integration plugs into the SAT input. You can't have Sirius/XM and the iPod.
There's a subaru specific part that fixes charging on newer iPods.
Part # H621SXA300
RabidWombat
#11: 04-20-2011, 09:31 AM
 vr4Legacy
vr4Legacy's Avatar
Do you know how many amps your usb adapter outputs? From what I understand alot of them output .5 amp where the newer iPhones and iPods need at least 1amp, with the iPad requiring 2 amps.
The one I got has 2 outlets and is rated at 1 amp, but I think that may be combined amperage, essentially sending .5amps to each outlet.
I think I may try the plugged into an outlet charger that I know provides plenty of amperage just to see if it works better.
vr4Legacy
#12: 07-15-2011, 06:38 PM
 SaggioWRX
SaggioWRX's Avatar
Car: 07 DGM OBXT
Send a private message to SaggioWRX Find all posts by SaggioWRX Reply With Quote
Any updates on this? Does the kit actualy work from subaru?
Can you control your Ipod/Iphone with the factory deck?
SaggioWRX
Find More Posts by SaggioWRX
#13: 01-29-2013, 10:17 AM
 ktm200
ktm200's Avatar
Car: 09' LGT 5EAT
Send a private message to ktm200 Find all posts by ktm200 Reply With Quote
Old thread but did anyone ever try out the newer kit Part # H621SXA300?
I have an 09gt (has the sat button) and wanted a way to hook up my iphone4 to charge and control with the steering wheel buttons through the dock connector.
Any suggestions?
ktm200
Find More Posts by ktm200
#14: 01-30-2013, 09:22 AM
 SCASEYS
SCASEYS's Avatar
Title: continuum transfunctioner
Car: parts wagon
Send a private message to SCASEYS Find all posts by SCASEYS Reply With Quote
Originally Posted by SCASEYS View Post
You use the h621sxa300 w/ the h621sxa200 to achieve
the results given w/ the h621sxa201(hard to find)
happy hunting!
I can confirm it charges the gen 4 ipod and iphone
until apple changes it again....
http://legacygt.com/forums/vbpicgall...o=hall&u=50442
SCASEYS
Find More Posts by SCASEYS
Similar Threads
Ipod music plus video on OEM nav screen tcoope13 Interior/Audio 2 09-15-2011 08:35 AM
FS (VA): OEM Subaru iPod Interface Kit - SOLD mr_hicksta Member Classifieds - ARCHIVE 1 09-04-2010 11:33 PM
2009 inventory clearance!!! FredBeansParts Vendor Classifieds 25 12-17-2009 12:09 PM
PA: FS - OEM 2008 Legacy GT Turboback Exhaust and more.- CLOSED Soda Popinski Member Classifieds - ARCHIVE 20 08-04-2008 06:53 PM
