Reload this Page Fuel pump control module
Page 1 of 30 1 2311 > Last »
#1: 08-19-2010, 05:56 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner Reply With Quote
How many here have bypassed the fuel pump control module and replaced it with a relay when they did their Walbro install?
GTTuner
Find More Posts by GTTuner
#2: 08-19-2010, 06:17 AM
 f1anatic
f1anatic's Avatar
Title: Das Cruise Meister
Car: Legacy GT spec C & Forester XP
Send a private message to f1anatic Find all posts by f1anatic Reply With Quote
I would like to know that as well. Also please include any and/or all links to the said operation of using a relay.
f1anatic
Visit f1anatic's homepage!
Find More Posts by f1anatic
#3: 08-19-2010, 06:20 AM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
Making that change would be easy, but why would anyone do this?
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
#4: 08-19-2010, 06:33 AM
 GTTuner
GTTuner's Avatar
Car: It runs 12's
Thanks for chiming in rao. I figuired why run the pump at less than 100%?
Why does Subaru do this? I just want smooth consistant fuel delivery from this pump before I tune since my IDC's are up pretty high.
Your thoughts are apprecieated! ( Sorry, I'm going to make you type today)
GTTuner
#5: 08-19-2010, 06:39 AM
 rao
They do it to reduce the heating of the fuel and evaporative emissions. In a nutshell, the pump will run in 3 modes: 1/3 at idle or no load, 2/3 at low load and 100% at high load. There is ABSOLUTELY NO REASON AND NO BENEFIT to running the pump 100% at all times.
Rob
rao
#6: 08-19-2010, 06:51 AM
 SubOperator
Car: 05 RBP LGT WGN 5MT S2; 07 B9; 05 OB 5MT
Send a private message to SubOperator Find all posts by SubOperator Reply With Quote
Paul, have you looked into 08+ WRX & Sti pumps ? I was looking at 245lh ones AVO is selling for 05 LGT with variable voltage support, and they list it as compatible with 08+ Wrx, Sti and FXT. My thought was to get one of those and retrofit it into my LGT. I was wondering what the flow is on those pumps. Don't think I like the idea of fuel pump running at 100% capacity all the time.
SubOperator
Find More Posts by SubOperator
#7: 08-19-2010, 06:52 AM
 holyjoetart
holyjoetart's Avatar
Car: '07 LGT
Send a private message to holyjoetart Find all posts by holyjoetart Reply With Quote
+1. The life of your fuel pump will also be shorter.
My car is really fast in reverse
holyjoetart
Find More Posts by holyjoetart
#8: 08-19-2010, 08:58 AM
 m sprank
m sprank's Avatar
Title: Vendor III
Send a private message to m sprank Find all posts by m sprank Reply With Quote
I have debated for a while installing a relay to make the Walbro get full power all the time.
Only because the Walbro is not designed to run at different voltages. Sure any 12vdc electrical motor will operate at about 5-6 volts. Even many 110v motors will operate at less voltage (just hook them up to a light dimmer and watch). But I am hearing that the failures associated to Walbros (fewer than the rumors portray) are most likely due to feeding them low voltage and causing the motors to overheat and fail.
Rao, any thoughts (honestly, not sarcasm).
m sprank
Find More Posts by m sprank
#9: 08-19-2010, 10:07 AM
 executor485
executor485's Avatar
Title: Like a Bause
Send a private message to executor485 Find all posts by executor485 Reply With Quote
/subscribed... Interested to hear some real ideas and thoughts as I will be installing my walbro soon.
This forum has made me a happy (and poor) person...
"That's what" - She
The Following User Says Thank You to executor485 For This Useful Post:
blk mk8 (11-10-2011)
executor485
Find More Posts by executor485
#10: 08-19-2010, 10:17 AM
 GTTuner
GTTuner's Avatar
Car: It runs 12's
m sprank......exactly my thoughts on this. The OE pump is designed to run on lower voltage but can the Walbro stand up to this?
sub op, I'll look into the Sti pump.
GTTuner
#11: 08-19-2010, 10:18 AM
 GTTuner
GTTuner's Avatar
Car: It runs 12's
Another thought on this; Has anyone had one of the FP control units fail?
GTTuner
#12: 08-19-2010, 10:21 AM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
Car: 2005 Garnet Red Legacy GT Sedan, 5MT
Send a private message to Th3Franz Find all posts by Th3Franz Reply With Quote
The ECU can only deliver a limited amount of electrical power. If you put in a big pump or more than one that need a high current draw to reach its rated pressure, the stock ECU might not be able to supply enough juice. For now, on my friend's car with dual Walbros we have relays in place drawing current directly from the battery. I have a background in power electronics so I am designing a circuit that will use the stock fuel pump control to reduce the speed of the pumps for idle and low load situations.
Why would lower voltage cause a motor to overheat and fail?
-Franz
http://www.youtube.com/th3franz
Th3Franz
Visit Th3Franz's homepage!
Find More Posts by Th3Franz
#13: 08-19-2010, 10:25 AM
 John M
John M's Avatar
Car: Formerly 05 LGT w/ FP Green
Send a private message to John M Find all posts by John M Reply With Quote
NSFW has found the fuel pump duty cycle tables but right now it's not a standard definition. Apparently it's different in each ROM revision so he's got to manually locate it for each ROM.
Once it's been made available for all ROMs, it's simply a matter of typing in 100% for all values -- no hardware change required. I'd want to do this even if I went to a relay so it'd have a steady trigger input.
John M
Visit John M's homepage!
Find More Posts by John M
#14: 08-19-2010, 10:31 AM
 rao
That is complete BS.
Rob
rao
#15: 08-19-2010, 10:34 AM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
I think the switching frequency is high enough where the relay stays closed but I haven't had a chance to measure it directly yet. I'm waiting on a high-speed DAQ card to do it.
-Franz
Th3Franz
Similar Threads
Alcohol/Methanol/Water Injection Kits... Ultimate CC Vendor Classifieds 131 01-08-2012 12:41 PM
Older Legacy Specs & Codes icrackedcorn Older Legacy Performance 15 06-07-2011 11:41 AM
DIY: Retrieving Trouble Codes without an obd-reader stlnet Walkthroughs :: Basic Operation & Maintenance 1 06-02-2010 06:30 PM
Fuel pump install - failed!! finse Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 15 05-10-2010 06:42 AM
Testing Used Fuel Pump rubberman Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 3 02-02-2009 09:37 AM
