Reload this Page Rough Idle
#1: 01-21-2013, 09:56 AM
Rough Idle
 Spenc13
Spenc13's Avatar
Car: 2006 Subrau Legacy 2.5GT
Send a private message to Spenc13 Find all posts by Spenc13 Reply With Quote
Hello,
I have a 2006 Subaru Legacy 2.5GT with 129,000 miles on it and it has been idling extremely rough when I put in the car in drive and will even stall out sometimes when the temperature is around 20 degrees or below. Any ideas on what the problem could be?
Spenc13
Find More Posts by Spenc13
#2: 01-21-2013, 10:31 AM
 DOHCstunr
DOHCstunr's Avatar
Car: 2005 SWP Legacy GT Limited 5mt
Send a private message to DOHCstunr Find all posts by DOHCstunr Reply With Quote
Any codes?
I would start by checking your spark plugs and testing your coil packs.
The Following User Says Thank You to DOHCstunr For This Useful Post:
Spenc13 (01-29-2013)
DOHCstunr
Find More Posts by DOHCstunr
#3: 01-21-2013, 10:40 AM
 06silvarubiLGT
06silvarubiLGT's Avatar
Send a private message to 06silvarubiLGT Find all posts by 06silvarubiLGT Reply With Quote
Intake manifold O-rings... Spray some carb cleaner around the TGVs when at idle and see if it changes
The Following 2 Users Say Thank You to 06silvarubiLGT For This Useful Post:
fysics (01-29-2013), Spenc13 (01-29-2013)
06silvarubiLGT
Find More Posts by 06silvarubiLGT
#4: 01-21-2013, 11:28 AM
 Mr. Sinister
Car: 08 Spec. B/Supra 91T
Send a private message to Mr. Sinister Find all posts by Mr. Sinister Reply With Quote
^ If it's only happening when cold, yup.
Mr. Sinister
Find More Posts by Mr. Sinister
#5: 01-29-2013, 08:42 AM
 Spenc13
Spenc13's Avatar
Spark plugs have been replaced within a year. I sprayed around the TGVs when at idle with carb cleaner and nothing happened. The car still continues to idle rough when in drive if it doesn't stall completely. It seems to be getting worse as it was only about 48 outside when it stalled the other day. Any other ideas of what could possibly be wrong?
Spenc13
#6: 01-29-2013, 08:44 AM
 Spenc13
Spenc13's Avatar
DOHCstunr --->> No check engine light or codes.
Spenc13
#7: 01-29-2013, 08:56 AM
 Mr. Sinister
Did you spray around the areas where the intake manifold mates to the head? The intake manifold o-rings are one common leak, the TGVs are another (less IMO).
Also, have you done the usual checks for vacuum leaks?
Mr. Sinister
#8: 01-29-2013, 10:54 AM
 Max Capacity
Max Capacity's Avatar
The o rings are a known problem area on these cars when its cold outside.
Max Capacity
#9: 01-29-2013, 03:12 PM
 fysics
fysics's Avatar
Car: '08 DGM specB
Send a private message to fysics Find all posts by fysics Reply With Quote
here's the thread on the o-rings if it's an only when it's cold kinda thing.
http://legacygt.com/forums/showthrea...09-155325.html
the deal with mine was idle was rough until the engine was up to temp with about 20minutes of driving, not just until the blue engine temp light shut off. I had the rough idle plenty of times with no CEL, then that finally came on a few times. was enough to get me going on the fix.
I just did this myself and it's looking like it's cleared up my idle issues!
The Following User Says Thank You to fysics For This Useful Post:
Spenc13 (01-30-2013)
fysics
Find More Posts by fysics
#10: 01-30-2013, 12:37 AM
 joshcwang
joshcwang's Avatar
Car: 05 LGT Stage 2 tuned, 05 STi P&L 35r
Send a private message to joshcwang Find all posts by joshcwang Reply With Quote
seafoam through my bpv line always cleared out any rough idling and gives me better mpg
or it could be the o rings...but nevertheless...never hurts to seafoam your car every 12-15k miles just to get rid of all the burnt up crap in your motor and to clean your injectors. I always do it right before a tune to make sure everything's perfect
and try not to inhale the smoke
joshcwang
Find More Posts by joshcwang
