Go Back   Subaru Legacy Forums > Technical Forums > Performance/Dyno Numbers/Track Times
Reload this Page 07 lgt stage two Mustang dyno
#1: 11-16-2012, 10:09 AM
 chaz517
Car: 07 5spd MT Legacy GT Ltd white
Send a private message to chaz517 Find all posts by chaz517 Reply With Quote
Tuned by ecs performance 255whp and 284wtq
2007 lgt manual
Mustang dyno
http://www.eastcoastswappers.com/mai...rgb1=000000255
http://www.eastcoastswappers.com/mai...php?runid1=461
What u guys think... Posted this from my phone so I'm sorry about the format
chaz517
Find More Posts by chaz517
#2: 11-16-2012, 10:23 AM
 lee07
lee07's Avatar
Send a private message to lee07 Find all posts by lee07 Reply With Quote
Looks just like mine when I was stg2, same curves, just you make more power in the high range - redline and mine made more in the low and mid range but fell after 5700rpm but it looks good.
6 months from now you'll probably be stg3 or at least thinking about it
The Following User Says Thank You to lee07 For This Useful Post:
chaz517 (11-16-2012)
lee07
Find More Posts by lee07
#3: 11-16-2012, 10:27 AM
 chaz517
Sweet thanks man. Def pulls harder than I expected. I'm already thinking about stage 3, so sad haha. It's like having the flu. Not sure if it be worth it to go w tmic and then re tune or just save up for turbo and tmic and then re tune. What do u think about my boost.? Thought 19 psi was kinda high for the stock turbo. Unless the previous owner switched it and I can't tell haha
chaz517
#4: 11-16-2012, 11:40 AM
 Drift Motion
Drift Motion's Avatar
Car: RMS13 --> 05 Turbo Camry
Send a private message to Drift Motion Find all posts by Drift Motion Reply With Quote
save up for all supporting mods for stage 3 build, and re-tune it at once
someone said this: stage 2 is just a placeholder for future stage 3 build
The Following User Says Thank You to Drift Motion For This Useful Post:
chaz517 (11-17-2012)
Drift Motion
Find More Posts by Drift Motion
#5: 11-16-2012, 12:10 PM
 liljonson
liljonson's Avatar
Car: 07 LGT
Send a private message to liljonson Find all posts by liljonson Reply With Quote
Im at 20psi stock turbo and its fine. Id be more worried about your stock intercooler. Definitely should think about jb welding that junk
The Following User Says Thank You to liljonson For This Useful Post:
liljonson
Find More Posts by liljonson
#6: 11-16-2012, 06:39 PM
 wurkenman
wurkenman's Avatar
Title: Contributing V.P.
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
ALWAYS want more power. I am at just under 330 and am already planning on a new turbo and injectors.
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
The Following User Says Thank You to wurkenman For This Useful Post:
wurkenman
Find More Posts by wurkenman
#7: 11-17-2012, 08:13 AM
 chaz517
Def gotta do the jb weld trick. Wish I had the funds to go stage 3 now
chaz517
#8: 11-17-2012, 09:21 AM
 lee07
lee07's Avatar
Stage 2 is all you will ever need on the street.
More is nice but you will never use all those power on the street.
Just wait until you have everything for a stg 3 build and tune it then unless you are sure that just a little bit more from a bigger intercooler is the last and final upgrade you will ever do.
My stock intercooler was fine at I think 17-18psi but then I never really drove it all that hard.
Right now this is all the power you will ever need on the street unless you are into drag racing
lee07
#9: 11-18-2012, 11:32 AM
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
Mine separated at 17.5psi - highly recommend the "Bulletproof kit" if you are running stage 2 power levels and plan to keep the OEM TMIC, (which is efficient but weak where the core attaches to the plastic end tanks), and I think it's a better solution than JBWeld.
spec.B #163 Build Thread with Pictures
Get CryoTuned!
LGT.com 2006 spec.B Registry Mapped
.:Catalyst:.
Find More Posts by .:Catalyst:.
#10: 02-06-2013, 01:14 PM
 Moddiction
Moddiction's Avatar
Car: 2008 OBP Legacy GT
Send a private message to Moddiction Find all posts by Moddiction Reply With Quote
Need maybe. Want definitely not haha. 300 ish whp feels very normal after a little time spent getting used to it.
I know in my other car I am currently at 410whp in a 2800 lb car and feels almost like stock to me now.
Moddiction
Find More Posts by Moddiction
