Reload this Page Cold air Intake
#1: 01-19-2013, 07:01 PM
Cold air Intake
 McMullen34
McMullen34's Avatar
Send a private message to McMullen34 Find all posts by McMullen34 Reply With Quote
Can someone help me with a cold air intake. I cant seem to find one that says it will fit a regular 2.5i legacy non turbo.
McMullen34
Find More Posts by McMullen34
#2: 01-20-2013, 01:24 AM
 ehsnils
ehsnils's Avatar
Title: Kafka was an optimist.
Send a private message to ehsnils Find all posts by ehsnils Reply With Quote
There are few parts available for tuning of the 2.5i, most tuning is for the turbo models where it pays off.
For the 2.5i you will probably benefit more from a suspension upgrade and possibly from an exhaust upgrade, but for the latter you need a tune. If you change the intake you will also need a tune.
Try my OBD Application Current Version 1.5.612.
ehsnils
Find More Posts by ehsnils
#3: 01-20-2013, 08:13 AM
 stanjk3
stanjk3's Avatar
Car: 2005 BSM LGT Limited Wagon 5EAT
Send a private message to stanjk3 Find all posts by stanjk3 Reply With Quote
The 05-09 turbo models don't benefit from a CAI or aftermarket intake unless you install a larger turbo and get a tune. Otherwise you'll run lean.
Friends don't let friends drink cheap beer.
stanjk3
Find More Posts by stanjk3
#4: 01-20-2013, 08:17 AM
 underground000
underground000's Avatar
Title: Bus Wanker!
Car: 08 LGT
Send a private message to underground000 Find all posts by underground000 Reply With Quote
search
5eat downshift rev match
Powder coated wheels: completed
underground000
Find More Posts by underground000
#5: 01-20-2013, 08:22 AM
 SCASEYS
SCASEYS's Avatar
Title: continuum transfunctioner
Car: parts wagon
Send a private message to SCASEYS Find all posts by SCASEYS Reply With Quote
2.5i
try the NA forums
intake is only going to add sound and decrease MPG
sounds ricemazing!
http://legacygt.com/forums/showthrea...5i-115322.html
http://legacygt.com/forums/vbpicgall...o=hall&u=50442
SCASEYS
Find More Posts by SCASEYS
#6: 01-26-2013, 04:33 PM
 Cadillac
Cadillac's Avatar
Car: '09 Legacy 2.5i
Send a private message to Cadillac Find all posts by Cadillac Reply With Quote
Good to know and kind of interesting in comparison to other cars. Not improving the air intake is kind of counter intuitive, no?
Cadillac
Find More Posts by Cadillac
#7: 01-26-2013, 06:09 PM
 bomberlegacy
bomberlegacy's Avatar
Title: pew pew
Car: 08 E85 Supercharged 2.5i
Send a private message to bomberlegacy Find all posts by bomberlegacy Reply With Quote
Most newer cars should be similar.. mods aren't helpful unless you tune for them, they will decrease performance. Plus our intakes are "cold air intakes" and flow plenty for the average mod list.
Raptor SC 9psi | E85 & Deatschwerks | Rallisport UEL headers
Because racecar
Build Thread
bomberlegacy
Find More Posts by bomberlegacy
#8: 01-26-2013, 06:44 PM
 bigjweb
bigjweb's Avatar
Car: 13 eins fünfunddreißig i
Send a private message to bigjweb Find all posts by bigjweb Reply With Quote
Originally Posted by stanjk3 View Post
the 05-09 turbo models don't benefit from a cai or aftermarket intake unless you install a larger turbo and get a tune. Otherwise you'll run lean.
it's a non turbo
bigjweb
Find More Posts by bigjweb
#9: 01-26-2013, 11:38 PM
 underground000
Title: Bus Wanker!
Car: 08 LGT
what makes our cars different* is our ecu's (car's computer) doesnt adjust/compensate as much as some other manufacturers. why? because most people who buy subaru's do not modify them so why waste the extra money to make a ecu better* when theres no reason to. why make it better is it works perfectly fine the way it is...
look at the stock air duct. it has a scoop to get outside air. look at most aftermarket intakes, yes it might flow more air but most open filters sit in the engine bay without any proper duct work to get colder air.
The Following User Says Thank You to underground000 For This Useful Post:
GeraldG (01-27-2013)
underground000
#10: 01-27-2013, 02:04 AM
 bigjweb
bigjweb's Avatar
Pretty sure that whole statement is an opinion
bigjweb
#11: 01-27-2013, 05:25 AM
 Cadillac
Cadillac's Avatar
Geez. This is confusing. If the ECU statement is an "opinion" then it's an open debate.
I love my 4thgen DGM but would love it more if I had another 10-20 HP.
Best bang for the buck is not an air intake? If not that, what can I do?
EDIT: Found the NA forum FAQ. Noobie forum members always rehash old schtuff like this.
Cadillac
#12: 01-27-2013, 07:10 AM
 DeltaNu1142
DeltaNu1142's Avatar
Title: Engorged, throbbing,
Car: 2009 QSM LGT 5MT stg3
Send a private message to DeltaNu1142 Find all posts by DeltaNu1142 Reply With Quote
I have a stage 3 LGT, and I'm running a stock intake... I'm pretty sure you'll be just fine.
Spend the dough on a RSB. You'll thank me.
vBGarage
The Following User Says Thank You to DeltaNu1142 For This Useful Post:
Cadillac (01-29-2013)
DeltaNu1142
Find More Posts by DeltaNu1142
#13: 01-27-2013, 11:51 AM
 stanjk3
stanjk3's Avatar
Originally Posted by bigjweb View Post
it's a non turbo
I know, but my point was that even on the turbo engines the intake isn't a restriction. The same holds true for the NA engines.
If you want more power, trade it in for a GT/XT or 3.0/3.6R.
stanjk3
#14: 01-27-2013, 12:44 PM
 andnyleswillriot
andnyleswillriot's Avatar
Car: 09 QSM 2.5i
Send a private message to andnyleswillriot Find all posts by andnyleswillriot Reply With Quote
your only options are either buy an aftermarket panel filter, I recommend this one:
http://www.avoturboworld.com/avoshop...ilter-p-3.html
, or the AVO power filter kit:
http://www.avoturboworld.com/avoshop...6mm-p-187.html
andnyleswillriot
Find More Posts by andnyleswillriot
#15: 01-27-2013, 01:10 PM
 bigjweb
bigjweb's Avatar
Aftermarket panel filters are garbage. There is plenty of research that shows K&N style filters do nothing other then allow more dirt into your engine.
OP,
bang for buck power for an N/A engine is tough. You can experiment with e85 or NOS for pretty cheap. But without a complete build you won't see much. Even with that is still would be $$$$$$ > actual results
bigjweb
