Go Back   Subaru Legacy Forums > Technical Forums > Suspension/Brakes
Reload this Page REmoved my Front Sway Bar - turn in is now AWESOME!!!
#1: 01-29-2011, 05:56 PM
Removed my Front Sway Bar - turn in is now AWESOME!!!
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
So my lap timer was showing that I was losing a few thousandths on my daily autocross course and I was hearing an annoying clunk from under my car.
I decided to have a look under my car and wouldn't you know it, one of the front sway bar links was broken I removed the link and since I didn't have any lying around due to my sloppy inventory control I removed the entire bar so that it didn't fop around and scratch my tire rod ends.
The car's handling is not INCREDIBLE!!!! Turn in is almost as good as in a Mustang V6
I may not reinstall the bar. I know a lot of people install larger rear sway bars, but installing a smaller front sway bar is the same thing and having no sway bar in the front is like an infinitely small bar!
On a side note, the rear O2 sensor also decided that it had enough and it failed. MY SUBARU IS FALLING APART I guess everyone is right.
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
#2: 01-29-2011, 08:50 PM
 pillboy
pillboy's Avatar
Title: Reese's Monkee
Car: 2005 Legacy GT Sedan, 2002 Outback Wagon
Send a private message to pillboy Find all posts by pillboy Reply With Quote
Originally Posted by rao View Post
I was an annoying drunk under my car. I guess everyone is right.
Fixed.
It is still ugly.
pillboy
Find More Posts by pillboy
#3: 01-29-2011, 09:13 PM
 PhilT
PhilT's Avatar
Title: Head above water
Car: Wagon with a 6 speed & DCCD
Send a private message to PhilT Find all posts by PhilT Reply With Quote
Must be a lack of oil threads lately
Double Award Winning Legacy GT Wagon
PhilT
Visit PhilT's homepage!
Find More Posts by PhilT
#4: 01-29-2011, 09:15 PM
 underground000
underground000's Avatar
Title: Bus Wanker!
Car: 08 LGT
Send a private message to underground000 Find all posts by underground000 Reply With Quote
For reals or fake thread?
Ive read about it for auto cross, but how about fwy speeds stability now?
5eat downshift rev match
Powder coated wheels: completed
underground000
Find More Posts by underground000
#5: 01-29-2011, 09:22 PM
 dmanaenk
Title: iTroll
Car: RWD Subaru
Send a private message to dmanaenk Find all posts by dmanaenk Reply With Quote
Shouldn't have driven it at all.
dmanaenk
Find More Posts by dmanaenk
#6: 01-29-2011, 09:24 PM
 madcatz
madcatz's Avatar
Title: brokted' LGT
Car: 05 SWP GT Ltd.
Send a private message to madcatz Find all posts by madcatz Reply With Quote
I ran my bb6 prelude without a front swaybar for the longest time.
I never put it back on and don't remember if it helped or hurt turning
-Travis
Originally Posted by PeteAWD View Post
Rob (rao) you're a fine gentleman, thanks I guess.
madcatz
Visit madcatz's homepage!
Find More Posts by madcatz
#7: 01-29-2011, 10:13 PM
 LosAngelesLGT
Title: Banned
Car: 05 LGT 5mt 371hp on 91oct & 06 OBXT Stg1
Find all posts by LosAngelesLGT Reply With Quote
I have heard from multiple people that removal of the FSB dramatically improves Legacy handling. Seems like a much smarter upgrade than spending money on sway bars imo.
LosAngelesLGT
Find More Posts by LosAngelesLGT
#8: 01-29-2011, 11:58 PM
 madcatz
madcatz's Avatar
Title: brokted' LGT
Car: 05 SWP GT Ltd.
Oh the sarcasm in this thread.....though I was being serious about the sway bar being disabled in the BB6
So what should I do....I just installed my Whiteline Adjustable links in the front....take them back off now?
I mean they weight a whole 3 lbs each, and then I can take off the COBB bar.....another 4 lbs.
10 lbs off the front of the car.....oh man, the possibilities
-Travis
madcatz
#9: 01-30-2011, 04:46 AM
 OhBe1
OhBe1's Avatar
Title: Moondog's crewchief
Car: '06 LOB, '97 MX-5, '03 Taco
Send a private message to OhBe1 Find all posts by OhBe1 Reply With Quote
Depending on the vintage of the Mustang, these two sentences may agree with each other, and I may agree with them both...
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
OhBe1
Visit OhBe1's homepage!
Find More Posts by OhBe1
#10: 01-30-2011, 05:01 AM
 fonts
fonts's Avatar
Title: RIP Coxx
Car: 07 LGT Spec. B
Send a private message to fonts Find all posts by fonts Reply With Quote
I don't think you should drive it.
fonts
Find More Posts by fonts
#11: 01-30-2011, 05:11 AM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
Here are a few other free mods:
1) Debadge. This saves weight at the very extremes of the car.
2) Drop tire pressure by 2 or 3 psi. This reduces the unsprung mass your Legacy will have to deal with, and improve performance.
3) Improve throttle response by replacing the Intercooler with a piece of PVC pipe. That way you get a smooth custom fit, sure to improve performance AND save weight and drop the CG.
4) Don't worry about lowering springs, just load the car up with sand-bags, then snug some zipties around the springs. A few hundred will easily do the trick. Use the sand-bags to fine-tune ride height for that racing look. After the ties are in place, remove the sandbags.
5) Drain out a quart of oil. It'll save weight, and the car is designed to work throughout the WHOLE range from E to F. Also, remove the oil-can light behind the gauge cluster. It'll save weight, and prevent a bright amber light from illuminating low in your field of vision, that could distract you and cause an accident.
6) Just run inner brake pads, and block the sliders on the caliper. That way the inner pads will engage, and you won't have to worry about wearing through rotors. This will save weight in two manners, first simply from unsprung mass removal. The second, is removing weight from the periphery of the rotation of the wheel/tire/control-arm system. This reduces it's angular inertia and helps the suspension to work better. In addition, the decrease in weight means the brakes will have improved feel and response.
7) Remove the uppipe. This will nearly eliminate backpressure, ensuring a free-flowing system that will make more power.
I can't think of any others, but perhaps others can add to this list.
The Following User Says Thank You to BAC5.2 For This Useful Post:
SonOfBadBoy (01-24-2013)
BAC5.2
Find More Posts by BAC5.2
#12: 01-30-2011, 05:11 AM
 rao
Very real, the link broke and I removed the sway bar until I get a new set of endlinks.
The rear o2 sensor also went out.
I suppose my choice of endlink oil might be to blame. I will have to run an oil analysis on it to see what happened.
Rob
rao
#13: 01-30-2011, 09:03 PM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
Car: 2005 Garnet Red Legacy GT Sedan, 5MT
Send a private message to Th3Franz Find all posts by Th3Franz Reply With Quote
Just reflash your car and remove the rear O2 alltogether
-Franz
http://www.youtube.com/th3franz
Th3Franz
Visit Th3Franz's homepage!
Find More Posts by Th3Franz
#14: 01-30-2011, 09:39 PM
 madcatz
madcatz's Avatar
Title: brokted' LGT
Car: 05 SWP GT Ltd.
but leave the bung out so you can super exhaust leak your Hogzwast
-Travis
madcatz
#15: 01-30-2011, 09:58 PM
 bnguyenbb6
Car: '06 LGT built + 3071
Send a private message to bnguyenbb6 Find all posts by bnguyenbb6 Reply With Quote
Wow...so much sarcasm and some truth in this thread...Sways don't only reduce body roll but they are also used for balancing the front and rear. Thats why your aftermarket front sway may be 75% stiffer but the aftermarket rear is like 180% stiffer than stock...WOW better turn in. Why? because the balance front and rear are different than stock.
Thread to check out if you don't believe me:http://forums.nasioc.com/forums/show....php?t=1981716
Check the mod list...
bnguyenbb6
Find More Posts by bnguyenbb6
Similar Threads
ATTN: New Members! Look here first. BDII New Member Introductions 60 04-29-2013 12:13 PM
shock strut set up colt 45ss Suspension/Brakes 12 11-24-2010 08:21 PM
clunking, front drivers side, not sway bar bmx045 Suspension/Brakes 5 09-08-2010 03:04 PM
What I've Learned RE: Suspension Tuning Underdog Suspension/Brakes 33 03-18-2008 05:54 PM
Front sway bar, front endlinks, rear endlinks - Legacy 2006 azca Member Classifieds - ARCHIVE 4 05-15-2006 05:41 PM
