01-22-2013, 05:47 PM
kw v3 on the way!!!!!!!!!!!!
Car: 2012 Legacy 2.5 prem cvt, Aprilia Futura
I ordered my v3"s on fri and am looking forward to havin my scoob handle the way it is supposed to..I will post review during and after install....getting excited!!!
peace,
Dave F...
The Following 2 Users Say Thank You to disgoduc For This Useful Post:
01-22-2013, 05:49 PM
Car: 2010 LGT
My KW V3 with Swifts springs are here, getting them installed Thursday.
I'll post my review next week.
The Following 2 Users Say Thank You to exbagboy For This Useful Post:
01-22-2013, 06:50 PM
Car: 2004 WRX Wagon stage 3 / 2012 LGT
Will you also post before and after pix? ^.^
The Following User Says Thank You to Kaijubei For This Useful Post:
01-22-2013, 07:08 PM
Car: 2010 LGT
I already have Swifts springs on but OP could do a stock vs lowered pic. I am planning on dropping it 0.8" only. You from Colorado Kaijubei?
01-22-2013, 07:27 PM
yessir
01-22-2013, 07:32 PM
Car: Stage 2+ 2010 LGT
Good luck with that lol. They say 0.8 but it's definitely more than that.
01-23-2013, 06:24 AM
Out of curiosity, where did you get your v3's? And what model number are your swift springs? I just got the V3's with the KW springs and was going to look into swifts later if the ride was too harsh, but after reading another member's review about the ride of the KW's on the winter setting I thought I would try stock first. I am the primary driver but the better half takes it to work occationally and she has quite a long ride so ride quality might affect her. Other than that a slightly harsh ride doesn't phase me a bit....
Peace,
Dave F.
01-23-2013, 06:51 AM
Car: 2012 LGT
Peace,
Dave F.
Just for clarification the winter settings I use and report on is my recommendation, not from KW. Even at the recommended settings from KW I would never describe the ride as harsh, just really firm.
I look forward to reading about your experience, it is night and day!
KNG
The Following User Says Thank You to killerniceguy For This Useful Post:
01-23-2013, 10:36 AM
Car: 2010 Legacy GT Limited
Peace,
Dave F.
Are the Swift springs firmer than the KW V3 springs that come stock on these coilovers? ...Thanks Dave, looking forward to reading your review on this setup. Also, could you recommend or post a link to where you bought them? thanks.
01-23-2013, 11:00 AM
Car: 2010 LGT
I got the KWs from a member here and they came with the Swifts springs which are supposed to be softer than the stock KW springs. I will look for a part number on them.
The Following User Says Thank You to exbagboy For This Useful Post:
01-23-2013, 11:32 AM
Since the swifts have a larger gap between coils and use a unique material, they are more compliant which in term makes them less.....aggressive when encountering a less than perfect surface. Ultimately the valving, comp and rebound setting is more or less responsible for the actual ride quality. I got my KW's from VR speed factory in Mass. If you go to the website u won't find them in the legacy section you have to go into the universal section and search the kw coil overs and I believe it's on pg 42 or 43...there are a lot of them!!
Peace,
Dave F
The Following User Says Thank You to disgoduc For This Useful Post:
01-23-2013, 12:52 PM
KNG
I'm not sure if I agree. The KW settings are harsh IMO. I am using your winter settings recommendation and its slightly stiffer than stock without the horrendous body roll. One thing to note, the colder it gets outside the harsher the ride so I've noticed. Was 7 degrees here this morning lol.
The Following 2 Users Say Thank You to Blizzard For This Useful Post:
01-23-2013, 03:51 PM
Car: 2010 LGT
Yes, in cold weather I've noticed my stock shocks are firmer and less bouncy, the viscosity of the oil inside the shocks is increased I presume.
