Go Back   Subaru Legacy Forums > General Forums > New Member Introductions
Reload this Page Just Purchased a Legacy GT
#1: 01-15-2013, 07:14 PM
 SCHNITZ93
SCHNITZ93's Avatar
Car: 2005 Subaru Legacy GT
Send a private message to SCHNITZ93 Find all posts by SCHNITZ93 Reply With Quote
I just bought a 2005 subaru legacy GT off of my neighbor for $8600. Car is in awesome shape he always took care of it and is a close family friend so wouldn't screw me over it has around 85k.
The car has
Td05 16g turbo
2.4 Inlet
Aftermarket Inner Cooler
Boost Controller
4" Exhaust off turbo
Walbro 255 Fuel Pump
Boost Guage on Steering Column
Straight Downpipes
Open Source tuning
Sti Mani
Everything was done professionally from turbotektuning (if you are familiar)
Few Questions I had is what would you recommend I do next? I was thinking the injectors because as far as I know they are still stock. Also, he told me It has not been tuned in awhile and that I should probably tune it down to around 8lbs so I was going to take it to PSIPROformance and get it tuned.
SCHNITZ93
Find More Posts by SCHNITZ93
#2: 01-15-2013, 07:24 PM
 bomberlegacy
bomberlegacy's Avatar
Title: pew pew
Car: '08 2.5i
Send a private message to bomberlegacy Find all posts by bomberlegacy Reply With Quote
12psi down to 8? I'm no turbo expert by far.. But that doesn't sound quite right for our cars.
Welcome!
'08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust
bomberlegacy
Find More Posts by bomberlegacy
#3: 01-15-2013, 07:31 PM
 bigjweb
bigjweb's Avatar
Title: Contributing V.P.
Car: 12 X3
Send a private message to bigjweb Find all posts by bigjweb Reply With Quote
I agree. 8psi wtf? If that 16g has a larger then stock wastegate, 8psi wouldn't be possible anyways. Even at 12 psi, that thing has got to be boring to drive. Turn up the boost man!
bigjweb
Find More Posts by bigjweb
#4: 01-15-2013, 08:00 PM
 SCHNITZ93
SCHNITZ93's Avatar
Im not sure why thats just what he told me to do. Im no mechanic or tuner im just getting into cars so im not sure what to do
SCHNITZ93
#5: 01-15-2013, 09:05 PM
 bigjweb
bigjweb's Avatar
Car: 12 X3
Sounds like bs to me. Stock boost is around 13.5 psi. I see no point in upgrading turbos and exhaust if you're going to run lower then stock boost.
bigjweb
#6: 01-15-2013, 09:12 PM
 wurkenman
wurkenman's Avatar
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
Welcome and congrats on the new ride. If you have stock injectors, you will most likely not be able to fully utilize the 16G. I would not go down in pressure, but stay right about where you are or maybe a little more depending on the limits of your set up. Luck dog it's even AWP.
If you woke up today, you have another chance to do it right.
wurkenman
Find More Posts by wurkenman
#7: 01-15-2013, 09:38 PM
 bigjweb
bigjweb's Avatar
Car: 12 X3
A 16g with stock fueling should be able to handle around 18-19psi through the midrange and taper down to 14-15psi up top. Telling him to stay around the 12 psi he's at is pointless to me. If he's gonna stay with low boost he should just sell it and buy an N/A car.
bigjweb
#8: 01-15-2013, 10:13 PM
 Drift Motion
Drift Motion's Avatar
Title: wheels
Car: Malibu w/V8 RWD Conversion
Send a private message to Drift Motion Find all posts by Drift Motion Reply With Quote
my 16g with stock fueling is at 17.5 psi
so yeah...maybe it's a typo 18 instead of 8?
4" exhaust is HUUUUGGGEEEEE
Next should be suspension mods/good set of tires
With great power, comes/needs great traction.
Drift Motion
Find More Posts by Drift Motion
#9: 01-16-2013, 03:28 AM
 wurkenman
wurkenman's Avatar
AHHH 18 makes more sense.
wurkenman
#10: 01-16-2013, 09:01 AM
 SCHNITZ93
SCHNITZ93's Avatar
I dont know if the injectors are stock or aftermarket but I know they are 550cc. and yeah I think tuning it down would be dumb thats just what he told me to do but when I get it tuned I think they are going to tune it up to 16=17psi
SCHNITZ93
#11: 01-16-2013, 09:01 AM
 SCHNITZ93
SCHNITZ93's Avatar
Also Drift motion, what kind of suspension mods would you recommend I start off with?
SCHNITZ93
#12: 01-16-2013, 10:19 AM
 RabidWombat
Car: 09 DGM LGT Stage 0, 08 DGM Impreza
Send a private message to RabidWombat Find all posts by RabidWombat Reply With Quote
Your first priority should be getting a good data log. That way you can check the boost as well as pick up any potential lean conditions, etc.
You'll need a laptop and a Vag-com cable for the data logging. The "Tuning" section is a good place to post the log, and people will be able to look over it.
RabidWombat
Find More Posts by RabidWombat
#13: 01-16-2013, 10:28 AM
 PeterJMC
PeterJMC's Avatar
Title: MD08Spec.B
Car: '08 LGT spec.B, '17 Ford Fusion Energi
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
Welcome to the site!
Was the former owner on this forum? If he was, maybe he had a build thread so you could read through some of the history?
'08 spec.B -- Thread Here
'17 Ford Fusion Energi Titanium
PeterJMC
Find More Posts by PeterJMC
#14: 01-16-2013, 11:09 AM
 Drift Motion
Title: wheels
do some research on the forum, there are plenty of threads on this topic
most will say do rear sway bar first
Drift Motion
#15: 01-16-2013, 03:53 PM
 SCHNITZ93
SCHNITZ93's Avatar
yeah ill do that im still figuring out how this site works and all
SCHNITZ93
