pongeee Posted January 18, 2013 Share Posted January 18, 2013 what is the easiest way to clear your head lights? Is there a way to do it without removing the bumper? Link to comment Share on other sites More sharing options...
Dujo Posted January 18, 2013 Share Posted January 18, 2013 Clearing headlights requires removing them from the car and baking them apart in your oven (on a low temp). You do have to remove the bumper to remove the lights. Walkthroughs on how to do both those things in the walkthrough section. Bumper is basically remove the grill and then remove some popits and then it pops right off. Don't forget to detach your fog lights. Headlights come out by removing the steel support bar holding the lights up. Enjoy. Welcome to LGT.com! Link to comment Share on other sites More sharing options...
Gire Posted January 18, 2013 Share Posted January 18, 2013 Yes, there is a brilliant walk through that is actually stickied at the top of the walkthrough forum. http://legacygt.com/forums/showthread.php/headlight-clearing-w-pics-3737.html?t=3737&highlight=headlight+clearing Link to comment Share on other sites More sharing options...
pongeee Posted January 19, 2013 Author Share Posted January 19, 2013 thanks guys, i saw that walkthrough when i first got my car. im worried about breaking clips and whatnot and the bumper not going back on right. i guess i just gotta suck it up. thanks again. Link to comment Share on other sites More sharing options...
Dujo Posted January 24, 2013 Share Posted January 24, 2013 Get a popit removal tool of some kind. Actually works much better than a screwdriver. And keep in mind that even the master techs break popits sometimes. Just get a few extra to have on hand in case. Also, even if you are missing a few popits, things aren't going to fall off the car. The bumper is really only seriously attached to the body where the grille screws it in to the brackets. The rest is popits and clips, which will hold things in place, but won't keep the bumper on the car at 70 mph. You aren't really relying on them to keep things on anyway. I only have about 5 bumper popits left. I need to get a few more. You're right. Suck it up and take the risk. If you break it, just replace it or live with the broken version. <-- This attitude is required if you intend to modify your car. You (or anybody else) will never get things back together as well as it was put together at the factory. Just a fact you have to live with if you want to customize things. Link to comment Share on other sites More sharing options...
Nrw Posted January 24, 2013 Share Posted January 24, 2013 Removing the bumper is easier than it seems. Link to comment Share on other sites More sharing options...
O.C.D. Posted January 24, 2013 Share Posted January 24, 2013 Screw, screw, pop, pop, pop, pop, pop, pop, pop, and done. (might have forgot a pop, lol). Link to comment Share on other sites More sharing options...
