Reload this Page Looking for apr?? Case and head bolts
Page 1 of 3 1 23 >
#1: 01-08-2013, 10:58 AM
 Grimmrican
Grimmrican's Avatar
Car: 95 legacy outback
Send a private message to Grimmrican Find all posts by Grimmrican Reply With Quote
Sup guys in the next few weeks I'll be working on a project for my wagon. I'm curious on a few things and hoping u guys can help. I looking for case bolts for a 2.2 block and head bolts for a 2.0 Rex. I kno I'll need a 2.0t ecu but what about the harness?? Please help
Grimmrican
Find More Posts by Grimmrican
#2: 01-08-2013, 11:18 AM
 sbw
sbw's Avatar
Car: 07 spec B
Send a private message to sbw Find all posts by sbw Reply With Quote
Im confused. Lets start over.
What are you trying to do exactly?
sbw
Find More Posts by sbw
#3: 01-08-2013, 11:35 AM
 Grimmrican
Grimmrican's Avatar
Sorry I was in a bit of a rush as I wrote this. Ok from the beginning.
I'm putting together an engine. 2.2 block with wrx 2.0 heads turboed. I'm going to put in some acl race bearings and blah blah blah. But my concerns are: where can I find the case and head bolts. Everyone I've talked to said go with apr. Where can I obtain these bolts.
And also. With this hybrid setup I'm curious as to what harness (if need be) should I use when I do the engine swap?
Grimmrican
#4: 01-08-2013, 12:39 PM
 subikid90
subikid90's Avatar
Title: EJ22T
Car: 97 LGT & 98 LGT
Send a private message to subikid90 Find all posts by subikid90 Reply With Quote
For case bolts go OEM, no need to spend money on ARP's.
For the head bolts you have two choices, ARP 2000 and Custom Aged 625+.
http://www.importimageracing.com/arp...u-wrx-sti.html
http://www.importimageracing.com/arp...ries-dohc.html
For what you are doing the ARP 2000's will be just fine.
Always run the matching harness and intake manifold to you heads.
-Subikid90
1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR
1998 Legacy GT Limited waiting for EJ22T hybrid swap
The Following User Says Thank You to subikid90 For This Useful Post:
Grimmrican (01-08-2013)
subikid90
Find More Posts by subikid90
#5: 01-08-2013, 01:37 PM
 Grimmrican
Grimmrican's Avatar
If I could hit the thanks button a million times I would. Thank u much
Grimmrican
#6: 01-08-2013, 01:45 PM
 Grimmrican
Grimmrican's Avatar
Also another question..... When I click the first Link I noticed the head bolts r for a 2013. Does it matter??
Grimmrican
#7: 01-08-2013, 02:08 PM
 subikid90
subikid90's Avatar
Title: EJ22T
No all EJ's use the same head bolts
-Subikid90
subikid90
#8: 01-08-2013, 02:09 PM
 Grimmrican
Grimmrican's Avatar
Sweet thanx again
Grimmrican
#9: 01-08-2013, 05:47 PM
 Baddog
Baddog's Avatar
Car: 96 Hybrid, 93 SS, 90 L
Send a private message to Baddog Find all posts by Baddog Reply With Quote
2.2 and 2.5 are different though.
Baddog
Find More Posts by Baddog
#10: 01-08-2013, 06:03 PM
 Grimmrican
Grimmrican's Avatar
I'm not going 2.5. I'm doing 2.0 heads on a 2.2 block
Grimmrican
#11: 01-08-2013, 06:06 PM
 subikid90
subikid90's Avatar
Title: EJ22T
Not completely true. DOHC and SOHC are different.
-Subikid90
subikid90
#12: 01-09-2013, 10:36 AM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
so meaning arp's work on every block and only dohc heads right? never thought about this before, but who actually likes there sohc heads?
Originally Posted by Stang70Fastback View Post
Clearly, the solution to shit breaking is to break more shit until the shit works again.
I'm Dumber Then I Seem, Remember That, I Won't.
Swagon_Wagon
Find More Posts by Swagon_Wagon
#13: 01-09-2013, 10:42 AM
 subikid90
subikid90's Avatar
Title: EJ22T
They make a set for both DOHC and SOHC in the ARP 2000 material and DOHC in the Custom Age 625+ material.
-Subikid90
subikid90
#14: 01-09-2013, 01:02 PM
 SBT
SBT's Avatar
Title: Site Majordomo
Rank: Admin
Car: SWP 05 LGTLW 5MT waiting on an S402
Send a private message to SBT Find all posts by SBT Reply With Quote
Is this on a 2.2T block?
So many mods, so little time
SBT
Find More Posts by SBT
#15: 01-09-2013, 02:44 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
Title: Contributing V.P.
Car: 1998 Subaru Legacy GT-L powered by EJ22D
Send a private message to DOHCEJ22E1 Find all posts by DOHCEJ22E1 Reply With Quote
Recipe for the DOHC EJ22 Turbo that you're trying to build:
205 Timing Belt & Pulleys.
205 Heads/Wiring/ECU/Intercooler/Intake-Exhaust manifolds.
205 Crank Gear (you MUST have this as it is what the ECU needs to determine crank position).
Turbo crossmember or cut crossmember w/welded reinforcement.
EJ22 Phase 2 MLS Gaskets (order them thick because the Phase 1 2.2 pistons clear the deck & the coolant passages match those of the 205 heads.)
Wiring for WRX dashboard (use the whole dash, if you can).
WRX fuel pump.
Keep your manual transmission (if you have one) but 2 extra holes may need to be drilled into the case where it connects to the engine.
The Following User Says Thank You to DOHCEJ22E1 For This Useful Post:
Grimmrican (01-09-2013)
DOHCEJ22E1
Find More Posts by DOHCEJ22E1
Page 1 of 3 1 23 >
