Reload this Page No start after new motor
#1: 12-03-2012, 09:52 PM
 revD
Car: 05 LGT sedan - BCBR coils + sways
Send a private message to revD Find all posts by revD Reply With Quote
Engine needed a rebuild and i got that done by a machine shop and have since put it back in the car. Now trying to start it, it doesn't want to fire. I have checked all the plugs and such a couple times. Hopefully something easy. So here is the deal:
- no spark and not grounding the injectors when cranking
- it is throwing codes when I unplug sensors as I check them (so ECM is working)
- it is powering the fuel pump when the key is turned on
Any ideas? Anything weird about getting these back online after tear down ?
I am checking the crank and cam sensor outputs now...
revD
Find More Posts by revD
#2: 12-04-2012, 07:03 AM
 ripemeat
Title: Banned
Car: Saxual content
there should be 3 engine grounds, one going from each head to the frame rails, and one from the pitchstop mount to the tranny. did you hook up the fuel lines backwards to the engine? did you set the timing properly? you need to retrace your steps
ripemeat
Find More Posts by ripemeat
#3: 12-04-2012, 09:02 AM
 2manysubies
2manysubies's Avatar
Car: '13 BRZL,05 LGTL Stg3+,05 LGTLW+3 subies
Send a private message to 2manysubies Find all posts by 2manysubies Reply With Quote
^+1
Mac
2manysubies
Find More Posts by 2manysubies
#4: 12-04-2012, 04:14 PM
 revD
3 grounds are on there.
Machine shop finished the long block and set timing, I looked at the marks and everything before putting covers on, but will review again.
I checked the fuel lines, but even if they were backwards - would that make the car no have spark or ground the injectors when cranking?
revD
#5: 12-04-2012, 04:31 PM
 ripemeat
Title: Banned
Car: Saxual content
the engine harness has a set a grounds along with the starter, they collect and all bolt to 1 12mm tgv bolt, drivers side. make sure the engine harness plug is tight together and that no wires pushed out of the clips.
ripemeat
#6: 12-04-2012, 05:50 PM
 frank_ster
frank_ster's Avatar
Title: MASTER OF THE BUCKARU
Car: 05 lgt 5EAT 3.8, buell 1125cr ,79 camaro
Send a private message to frank_ster Find all posts by frank_ster Reply With Quote
well #1 does the crank sensor work / plugged in ?
#2also fyi if the cams are off by one tooth the ecm wont let the car fire. to test for this unplug both cam sensors.
# 3 the large connector above the turbo if its not fully plugged in it will cause issues.
Now that's thinking out of the boxer!
fyi all 05 legacy's have built in code reader
frank_ster
Find More Posts by frank_ster
#7: 12-05-2012, 10:51 AM
 revD
#1 I had a scope on the car, we tested the crank sensor out of the car, and in it for ocilation of voltage - it works
#2 So, the car will fire with both cam sensors off then?
#3 Big connector is plugged in and wires checked.
thanks so far guys, very helpful, Ill try the cam sensor trick.
revD
#8: 12-05-2012, 10:52 AM
 revD
ill double check that ground on drivers side,
revD
#9: 12-05-2012, 04:42 PM
 Max Capacity
Max Capacity's Avatar
It must be something simple, re-trace your steps.
Did you pull any fuses ?
Max Capacity
#10: 12-05-2012, 05:35 PM
 frank_ster
frank_ster's Avatar
waiting for some one to say " is there gas in the tank ? "
The Following User Says Thank You to frank_ster For This Useful Post:
EJ25subie05 (12-05-2012)
frank_ster
#11: 12-09-2012, 03:33 PM
 revD
Ha. Yeah thanks there is gas. I confirmed I am getting fuel pressure also.
I tried the cam sensor trick, and checked all the fuses. I agree should be something simple. I have not had much time to fuss with it and have a borrowed car right not. Just frustrating.
revD
#12: 12-09-2012, 03:54 PM
 ripemeat
Title: Banned
Car: Saxual content
are you getting any stored CEL's? scan it and see
ripemeat
#13: 01-20-2013, 05:21 PM
 revD
Got this figured btw, Machine shop goofed and the timing was not set properly. pully got marked wrong somehow. Car is dialed now, should have looked at the timing closer.
revD
#14: 01-20-2013, 07:21 PM
 frank_ster
frank_ster's Avatar
hehe
its because the subarus are ment to be timmed 90 deg from tdc. i made the same mistake.
frank_ster
