Reload this Page DIY maintenance
Page 1 of 4 1 23 > Last »
#1: 01-15-2013, 11:29 AM
DIY maintenance
 uncledoobie
Car: 2010 Subaru Legacy 2.5i Premium
Send a private message to uncledoobie Find all posts by uncledoobie Reply With Quote
So I've had to put off some important maintenance on my 2010 2.5i due to financial reasons but it's starting to make me nervous how long I've been letting it go. It also made me realize I don't like depending on the dealer or any garage for that matter to help keep my car in tip top shape. I understand major things would have to be brought in to the shop, but minor things - oil changes, or any fluid changes for that matter, belts, hoses, etc - I should be able to do on my own. Now keep in mind, I've had zero wrench time on my car and I want to change that. Any recommendations on where to start?
Also, with regards to something like an oil change, which i'd like to attempt on my own, how do I deal with the low ground clearance? Do I need a lift or find a place with one? Can i build myself a ramp and hopefully not kill myself in the process?
uncledoobie
Find More Posts by uncledoobie
#2: 01-15-2013, 11:37 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Just buy yourself a set of Rhinoramps (~$50) and start with that. A good first job is an oil change--you'll need a pan to drain the oil into, a ratchet/socket to get the drain bolt out, and an oil filter wrench as well.
If you read that and think to yourself "gawd, I have to buy all that just for an oil change!", then you might want to rethink your DIY aspirations--otherwise, go nuts and have fun. Wear some safety glasses while you are under the car.
BarManBean
Find More Posts by BarManBean
#3: 01-15-2013, 11:45 AM
 uncledoobie
This sounds fantastic. I don't mind the equipment costs because it'll be spread out over the long run anyway (assuming most of these will last long). Now when the car is up on the ramp, will there be an issue about the oil draining out fully? Or should I expect some leftovers in there when I fill it up with the new oil?
Also, is there a case to be made for synthetic over regular? and is there a specific weight I should use with the NA 2.5i?
uncledoobie
#4: 01-15-2013, 11:50 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
No issue with leftover oil, you'll be fine. Different people will tell you all sorts of things about what type of oil to use. The one consistent piece of advice for your car is probably to just use whatever the manual says to use, use something that is within your budget, and change it regularly according to the intervals indicated in the manual. One thing to steer clear of is "racing oils"--you don't need them and several of them are overhyped or just cruddy.
BarManBean
#5: 01-15-2013, 11:53 AM
 MN3.6R
MN3.6R's Avatar
Car: 2011 3.6R Limited
Send a private message to MN3.6R Find all posts by MN3.6R Reply With Quote
There will always be some left over when draining. Do not let it drain till its stop dripping. I am sure you could find some DIY oil changing videos on you tube that may help to at least give you a visual concept of what you need to do.Should take 5w-30 on the newer 2.5i
MN3.6R
Find More Posts by MN3.6R
#6: 01-15-2013, 12:03 PM
 uncledoobie
Great, thanks to you both. This is all extremely helpful.
The service I'm overdue for is the 30k major service, per the Subaru recommended service guide. Is that really necessary? I looked over what they do and it just seems like they're doing a lot of checking, with some fluid fill ups and an oil change. Is that service really necessary? It doesn't seem like it's worth the $600 they're charging. For that price I'd rather throw on a new exhaust.
uncledoobie
#7: 01-15-2013, 12:06 PM
 3.6rrrrrmatey
Title: Banned
Find all posts by 3.6rrrrrmatey Reply With Quote
I can't do an oil change cheaper than the shops and it's really the only part of the maintenance i'd do in my garage with ramps.
3.6rrrrrmatey
Find More Posts by 3.6rrrrrmatey
#8: 01-15-2013, 12:11 PM
 laff79
Title: Banned
Car: '05 ABP Legacy GT
Send a private message to laff79 Find all posts by laff79 Reply With Quote
and why is that?
not worth the money. search on here and have a car guy/friend help you out. get the exhaust instead
laff79
Find More Posts by laff79
#9: 01-15-2013, 12:12 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
You're not trying very hard then. You can change every fluid in the car, sway bars, the entire exhaust system, and I'm sure several other things using just a set of ramps. Keep in mind it's advisable to also have a set of jack stands to put under the car for added safety incase the ramps fail--you should always have a back up.
As far as the cost goes, you get what you pay for. I do my synthetic oil changes for about half the cost (or less) of what I would pay at any shop--and I do better work.
BarManBean
#10: 01-15-2013, 12:17 PM
 biggitybakes
Car: 2012 Subaru Legacy 3.6R Limited SWP
Send a private message to biggitybakes Find all posts by biggitybakes Reply With Quote
Definitely get some rhino ramps, there are some that have less steep angles if you are worried about clearance. My advice is.. make sure your car is centered on the ramps and drive up them very slowly.
Also, know where your jack points are and invest in a set of jack stands. Also, some other good things to have are wheel chocks to make sure the car doesn't move on you. If I am working on brakes or suspension I usually throw the wheel under the car too, just in case
Don't go under the car unless you know it won't fall. I was amazed one time when I was out of town and I had my friend help my wife look at her brakes. They used the OEM jack that you find in the trunk and the car ended up falling with the wheel off and left a nice dent in some fairly new asphalt, which could have easily been one of their legs or arms.. They ended up jacking up the rear and had the e-brake on, but didn't chock the front wheels so the car rolled on them.. and trust me, these people aren't stupid, just inexperienced. It may be best to grab an experienced friend your first couple times under the car.
biggitybakes
Find More Posts by biggitybakes
#11: 01-15-2013, 12:24 PM
 biggitybakes
Yeah they may be cheaper.. but they usually mess something up. When I didn't have a garage, I would take it in for changes in the winter and it was astonishing how often they would mess something up. They always over tighten the oil filter, and when I asked them to not do it so damn tight, they put it on too loose and it started leaking on me. They also checked my radiator fluid and got some paper towel caught in the cap and it was spraying coolant everywhere.. They almost ruined my wife's engine by not using a gasket on the oil filter houseing (mini cooper). Ugh I hate those quick service lube shops. Those 17 year old's really don't know what is going on.
biggitybakes
#12: 01-15-2013, 12:40 PM
 CL21376
CL21376's Avatar
Car: 10 LGT Stage1; 94 Pontiac Firehawk #251
Send a private message to CL21376 Find all posts by CL21376 Reply With Quote
You can also make your own ramps out of wood.
I prefer to jack the car up and slide the ramps under the wheels.
CL21376
Find More Posts by CL21376
#13: 01-15-2013, 12:52 PM
 uncledoobie
yea i was thinking about building my own with some cinder blocks and wood, but I'd rather just go the regular route of buying some time and tested ones. 50 bucks on amazon ain't bad, and I'll get regular usage out of them.
uncledoobie
#14: 01-15-2013, 12:54 PM
 uncledoobie
Are there any particular parts of the car that will require regular service beyond the simple oil change and fluid check? Are belts and hoses something I should let the dealer manage or can I tackle that as well? I imagine battery maintenance is another thing I can do on my own.
uncledoobie
#15: 01-15-2013, 01:03 PM
 bluesuby
bluesuby's Avatar
Send a private message to bluesuby Find all posts by bluesuby Reply With Quote
I can't figure why anyone would need ramps for an oil change (unless they weigh 500 pounds and have very short arms). Buy a "cap" style oil filter wrench which fits over the top of the filter. Check the Sears sale paper this weekend for savings on socket and ratchet tools. Six point sockets are best for getting a grip on that drain plug.
bluesuby
Find More Posts by bluesuby
