Go Back   Subaru Legacy Forums > Model Specific Forums > First Generation Legacy (1989 - 1993)
Reload this Page 95 legacy engine swap
#1: 01-28-2013, 08:53 PM
 Viking1980
Car: 93" Legacy L 25 anni., 99 Legacy L,
Send a private message to Viking1980 Find all posts by Viking1980 Reply With Quote
can I swap a 1995 legacy 2.2 inton my 1993 legacy 2.2? What are something I need to look for interms of issues with the swap?
Viking1980
Find More Posts by Viking1980
#2: 01-28-2013, 09:22 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 93 SS, 03 WRX 205/22T
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
I think the only difference is the 95 22 has egr. Is your car auto or manual?
monkeyposeur
Find More Posts by monkeyposeur
#3: 01-28-2013, 09:35 PM
 Viking1980
manual
Viking1980
#4: 01-28-2013, 09:43 PM
 monkeyposeur
Why do you need to swap? Usually the 22s go forever.
The 95 22 will have egr and may have some wiring differences but I'm not sure about that. If you swap your 93 intake mani over along with the sensors I don't think you would have any problems. Some of the sensors may be interchangeable but swapping the intak mani would get rid of the egr problem.
monkeyposeur
#5: 01-28-2013, 09:46 PM
 Viking1980
timeing belt popped so i figured for the cost of the kit with pulleys, belt and water pump i can get a whole engine out of a 95 for $300$ off a freind.
Viking1980
#6: 01-28-2013, 09:48 PM
 Viking1980
Then i can rebuild the 2.2 out of the 93. and have another backup with a little more power.
Viking1980
#7: 01-28-2013, 09:54 PM
 monkeyposeur
You can get a timing kit with pulleys and idlers and water pump on eBay for $125. A nice Gates kit will be more. The 22s are non interference so if your timing belt broke there won't be any internal engine damage. It's cheaper and easier just to do the timing belt and pulleys compared to swapping.
How many miles are on your engine?
monkeyposeur
#8: 01-28-2013, 09:59 PM
 Viking1980
I was told the 2.2 were interference motors thats why i figured just swap in stead of goin through the whole head ache of the bent vales to tell you the truth I'm not sure of the miles i just bought the car for 200 as is. the price I got was from from napa for the kit.
Viking1980
#9: 01-28-2013, 10:00 PM
 Viking1980
it was 369 through napa
Viking1980
#10: 01-28-2013, 10:04 PM
 Viking1980
thanks for the info monkeyposeur
Viking1980
#11: 01-28-2013, 10:07 PM
 monkeyposeur
The 22s went interference in 97. So no need to worry about valve damage. Happy to help!
monkeyposeur
#12: 01-29-2013, 10:17 AM
 pleaidestar
pleaidestar's Avatar
Title: macaque
Car: 2000 L wagon // 1990 ls wagon (flea-bag)
Send a private message to pleaidestar Find all posts by pleaidestar Reply With Quote
I don't think manual tran 2.2's have egr on them, f they do egr delete is easy I did one on my 95 motor, just take it out and plug the holes on the head and manifold with m16x125 bolts. Your ecu will tell you you have an egr code in diagnostics...but it doesn't affect the way the motor runs.
pleaidestar
Find More Posts by pleaidestar
#13: 01-29-2013, 10:20 AM
 pleaidestar
Title: macaque
You can leave the valve body on the manifold with your vacuum lines going to the switching solenoid, or just make a block off plate or get one off a newer 2.2 that is equipped with a standard transmission ...easy as cake, if you don't mind a trouble code.
pleaidestar
