Reload this Page Disconnect driveaxles to replace clutch?
#1: 01-12-2013, 08:19 AM
 relative4
relative4's Avatar
Send a private message to relative4 Find all posts by relative4 Reply With Quote
Preparing to do a clutch job on my '05 LGT. I'm seeing conflicting information on whether I need to disconnect the driveaxles from the transmission, or whether they allow the transmission to move far enough back that I can clear the input shaft without disconnecting them. Anybody know?
relative4
Find More Posts by relative4
#2: 01-12-2013, 08:31 AM
 Nolmers06LGT
Nolmers06LGT's Avatar
Car: '06 LGT 5mt w/103k STG2 @18.25psi
Send a private message to Nolmers06LGT Find all posts by Nolmers06LGT Reply With Quote
I didn't remove mine and I still had enough clearance to access everything I needed. You get roughly 5 inches of clearance
Nolmers06LGT
Find More Posts by Nolmers06LGT
#3: 01-12-2013, 11:49 AM
 slowGT
Car: 05 LGT 5MT
Send a private message to slowGT Find all posts by slowGT Reply With Quote
I didn't remove the shafts as well. Next time I would remove them though. It makes lining the trans back up easier without the axles in place. I fought against those axles for way too long.
slowGT
Find More Posts by slowGT
#4: 01-14-2013, 09:55 PM
 ScottFW
ScottFW's Avatar
Title: Homebrew Vendor
Car: 05 SWP 5MT LGT Limited
Send a private message to ScottFW Find all posts by ScottFW Reply With Quote
I changed my clutch last month without pulling the front axles. The trans moves back far enough that the front of the bellhousing can kind of rest on the rearmost part of the front subframe. Plenty of room.
As for whether it makes it harder to reattach the trans, I can't speak to that. I was working alone so it was going to be a pain in my ass either way. By moving the trans jack up & down to set the height at the front of the bellhousing, and using a separate floor jack under the rear of the trans to adjust the pitch, I eventually got it.
ScottFW
Find More Posts by ScottFW
#5: 01-14-2013, 10:10 PM
 ericem
ericem's Avatar
Car: 07 LGT grey 5EAT Infamous1 stg 1
Send a private message to ericem Find all posts by ericem Reply With Quote
I usually pull the engine forward and leave the PS and AC lines attached but undo some wiring gives me enough slack and I am working ontop which is way easier. obviously you will need to pull the rad but might not be the best option for those without a engine lift.
ericem
Find More Posts by ericem
#6: 01-14-2013, 10:46 PM
 Nolmers06LGT
I ended up pulling my hood too. It was only a few bolts and it made things much easier.
Nolmers06LGT
