Reload this Page Battery issues
Page 1 of 3 1 23 >
#1: 10-24-2012, 12:37 PM
Battery issues
 Scooby Fan
Scooby Fan's Avatar
Car: '12 Leg Ltd Silver,06 Impreza 2.5 White
Send a private message to Scooby Fan Find all posts by Scooby Fan Reply With Quote
Yup....yet another battery problem thread, but before you start flaming me....I did search and read all that I could find...just nothing quite specific enough.
The situation....2006 LGT sedan with 58,000 Km...totally stock....only electrical after market accessory is a Garmin GPS running off the cigar lighter(Disconnecting it does not affect the problem) New 550 CCA battery installed a few months ago....all terminals are clean and secure. Battery will go to DEAD in about 4-5 days if not driven.
The car has been to the dealer about this numerous times while it was still on warranty....no problem....no solution.
Battery readings across the terminals
Running at idle...............14.4V
Running at 2500 rpm........14.4 V
After shut off.................12.7 V
After off 1 hr..................12.4 V
After off 5 hrs................12.2 V
After cold overnight........12.1 V
After start and 2 km drive...12.6 V
I did the Dark Current test as outlined in TSB 07-62-07
Milli amp draw down fluctuates between 1 mA and 18 mA...never higher and no where near the suggested max of 150 mA
Love to hear from anyone on here with any serious ideas about his problem.
Scooby Fan
Find More Posts by Scooby Fan
#2: 10-24-2012, 12:54 PM
 compsurge
compsurge's Avatar
Car: '05 5MT ABP LGT wagon
Send a private message to compsurge Find all posts by compsurge Reply With Quote
Start pulling fuses to see which one reacts? Is there an alarm system installed?
compsurge
Find More Posts by compsurge
#3: 10-24-2012, 12:58 PM
 06silvarubiLGT
06silvarubiLGT's Avatar
Send a private message to 06silvarubiLGT Find all posts by 06silvarubiLGT Reply With Quote
^^this.. At this point I think you should continue to check voltages over a longer period of time. especially since you know it takes it 4-5 days. Have you followed the ground wire down to frame/or wherever it may go, they do fray sometimes?
06silvarubiLGT
Find More Posts by 06silvarubiLGT
#4: 10-24-2012, 01:13 PM
 Max Capacity
Max Capacity's Avatar
Have you PM'ed members like Frank_ster, m sprank, BAC5.2
I'm sure one of them could be some help.
Max Capacity
#5: 10-24-2012, 02:31 PM
 compsurge
compsurge's Avatar
Also, have you unplugged your battery to see if it discharges over time by itself (just what I'd do)?
compsurge
#6: 10-24-2012, 02:54 PM
 Spec B
Spec B's Avatar
Title: JDM tuner wanna be
Car: Spec B- FP HTA68'd up E-Ocho Cinco Stilo
Send a private message to Spec B Find all posts by Spec B Reply With Quote
I have not taken measurments but I have the same issue (car has 40k miles) i just ordered my 2nd optima yellow top battery. My current battery (2 years old) will not hold a charge at all...it got progressively worse over time. I also bought a battery tender in the hopes of saving my current battery but it will not charge it at all.
Spec B
Find More Posts by Spec B
#7: 10-24-2012, 02:58 PM
 compsurge
compsurge's Avatar
Have you tried a more generic battery from the auto parts store? It could be as simple as not driving enough to keep the battery in good shape. The average lead acid battery needs to be charged within 30-60 days of sitting idle at standard room temperature to retain its life.
compsurge
#8: 10-24-2012, 03:30 PM
 Scooby Fan
Scooby Fan's Avatar
Thanks for the replies.
All the connections are solid and secure...no fraying
The battery does not drain down when not connected to the car
No alarm on the car...just the OEM immobilizer
The draw down measurement is so low I can't see where pulling fuses will tell me anything.
This is the second battery in the car and it reacts exactly like the original.
You can tell from the ultra low mileage (Barely 35,000 miles in 7 years)that the car does not get a lot of driving...a lot of short trips with occasional holiday drives...but... I do drive it almost everyday.
I am going to leave it for a few days in the garage to see what the voltage drops to.
Scooby Fan
#9: 10-24-2012, 04:20 PM
 AkumaMax
AkumaMax's Avatar
Send a private message to AkumaMax Find all posts by AkumaMax Reply With Quote
There has to be a short somewhere. A nicked wire or even a bad connection. I would check out the alternator as well. If you say the battery is good disconnected over time then there is only one other major part that coincides with the battery.
AkumaMax
Find More Posts by AkumaMax
#10: 10-24-2012, 04:55 PM
 Scooby Fan
Scooby Fan's Avatar
Good plan...>I will check that tomorrow.........I suppose it is not impossible that the juice is bleeding back through the alternator, but I think that would show in the "Dark Current" test for amp leakage,,,,as you can see my readings for that are very low compared to recommended specs.
Obviously, what I am hoping for is someone who has had the same sort of problem and readings and has found the solution. I hope it is as simple as driving it more........or maybe driving it to the dealership for a new Subaru
Scooby Fan
#11: 10-25-2012, 01:29 PM
 OBieXT
OBieXT's Avatar
Send a private message to OBieXT Find all posts by OBieXT Reply With Quote
Are you leaving the key in the ignition? Just putting the key in the ignition (even without turning it on) seems to wake up the anti-theft system and it apparently starts polling the chip in the key. This puts a load of about 3/4 amp on the battery. Although this is a small load, over time it is more than enough to run the battery down in a 3-4 day period. Its possible that the contact that senses when the key has been inserted occasionally sticks thus leading to a dead battery.
OBieXT
Find More Posts by OBieXT
#12: 10-25-2012, 01:36 PM
 Scooby Fan
Scooby Fan's Avatar
No....the key is always out and obviously during the test as prescribed in the Subaru service bulletin....Not sure why, but the bulletin requires that the doors be locked too......Probably to arm the security system, but I don't have an alarm. I tested it with the doors locked and unlocked...same results exactly.
BTW....checked the alternator....no problems there.
It is hard to find a leak when the test shows there is no draw more than normal....in fact the Subaru test shows that my car draws down way lower numbers than normal....The quest continues
Scooby Fan
#13: 10-25-2012, 02:18 PM
 compsurge
compsurge's Avatar
Are you the original owner?
Check the trunk for signs of a tow package or something.
compsurge
#14: 10-25-2012, 02:50 PM
 LGT612
LGT612's Avatar
Send a private message to LGT612 Find all posts by LGT612 Reply With Quote
The time consuming way to find a parasitic draw is to hook up an ammeter to the battery, negative side cable, and start pulling fuses and see if the reading fluctuates.
LGT612
Find More Posts by LGT612
#15: 10-25-2012, 02:55 PM
 700watts
700watts's Avatar
Car: racer-x is faster + 00 4Runner (dogs)
Send a private message to 700watts Find all posts by 700watts Reply With Quote
That is your only choice...or you'll be chasing your tail
700watts
Find More Posts by 700watts
Page 1 of 3 1 23 >
