#1:
01-09-2013, 09:47 AM
Mysterious swtich found
Car: 2003 Legacy GT BL5
I was investigating my air con/radio unit today and when i removed the gear stick cover and ash tray, i noticed a small switch on the right. I couldnt see where it led to after much effort! But i've no idea what it does if I switch it off.
Anyone else know what it could be?
I tried and considered the following: Alarm Bypass, Ignition bypass, Boost controller switch, ABS off swtich, Hidden lights....
Pics to follow soon!
#2:
01-09-2013, 10:26 AM
Title: Kafka was an optimist.
Car: Subaru Legacy Wagon Diesel 2010
Trunk opening inhibit switch?
To prevent someone to open the trunk from inside the car.
#3:
01-09-2013, 10:30 AM
Car: 05 LGT BrenTuned
Be careful, that's the passenger seat ejection switch.
#4:
01-09-2013, 02:36 PM
Im not gonna lie, didnt sit in either front seat while fiddling with it :-p
Do scoobys have a Trunk opening inhibit switch? (or is that a joke?)
#5:
01-09-2013, 02:43 PM
Car: 07 Spec.B BNR16G, TurboXS tuned
No, but they do have a keylock on the trunk release, which is down by your left foot.
My guess is a previous owner of your car put that switch in.
#6:
01-09-2013, 02:48 PM
Title: Whut, who me?
Car: It runs 12's
Picture?
#7:
01-09-2013, 05:05 PM
Title: Delta Machine
Car: BSM05
sounds like an aftermarket alarm valet switch that no one ever really installs properly... or needs...
#8:
01-09-2013, 06:50 PM
Title: Contributing V.P.
Car: 2005 LGT Wagon Limited 5EAT
Originally Posted by GTTuner
Picture?
#9:
01-14-2013, 03:46 PM
Sorry for the delay, had a crazy weekend. Here it is,
Its located on the bottom right behind where the ashtray is, under the AC unit. my car is RHD so i'm guessing it was put on that side for a reason....
#10:
01-14-2013, 04:33 PM
Title: Duke
Car: 05 Legacy GT w/ STi 6MT~07 Solstice GXP
See if the wires goes to the place that the green connectors are. The ones you put together to Flash new maps to the ECU.
I did that to mine, make it easier to flash maps.
Still rocking the Original Motor & VF-40 Turbo with 15k OCI. Member of the 200K + club. Currant mileage:224628
#11:
01-14-2013, 04:39 PM
if they do go there, why the on/off switch?
#12:
01-14-2013, 04:49 PM
Car: BSM05
Toggle the ability to write to the ecu but that still looks like a valet switch... Very after market and definitely not stock
#13:
01-14-2013, 04:59 PM
Title: Duke
So you can flick a switch to flash & then drive after you loaded a new map. Instead of crawling under the dash & pulling the green connectors out from under the carpet in the foot well. To connect & unconnect the green connectors.
Green connectors are only together when flashing you ECU.
#14:
01-16-2013, 04:13 PM
Thanks hammer! Mystery..... Solved ;-)
Now.... whats the noise from my rear window sill? :-p
Don don dooonnnnnnnnnnnnnnnnnn
#15:
01-17-2013, 02:57 PM
Car: '06 LGT 5mt w/103k STG2 @18.25psi
That's brilliant.. and elegant. My tuner would appreciate that switch very much.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
