Reload this Page Intercooler Leak
Page 1 of 3 1 23 >
#1: 12-12-2012, 09:23 PM
Intercooler Leak
 IceCold81
IceCold81's Avatar
Car: 2005 Subaru Legacy GT
Send a private message to IceCold81 Find all posts by IceCold81 Reply With Quote
Hey all, I've been looking around for some threads on this topic and found SOME info, but it's tough to pin point if directly relative to what I'm seeing?
I've had what looks to be an decent seeping of some sort on my intercooler for some time... Car seems to run fine, boost fine (As far as I know) But being an inter cooler and seeing this level of grunge around the bottom bottom left/passenger corner of the inter cooler, what would some of you make of this? Has anyone else had a similar issue with there stock cooler? I was already planning on replacing in the near future, but I'm curious about the seemingly "OIL LIKE" leak I'm seeing.
My ride is a 2005 LGT with about 100k on it... Compression test done, was within scope/healthy etc. and not overly experienced with the turbo system to know what to expect with something like this? Wouldn't mind to hear some feedback if you'd feel like contributing.
IceCold81
Find More Posts by IceCold81
#2: 12-12-2012, 11:51 PM
 .blackgt.
.blackgt.'s Avatar
Car: hovercraft-SOLD camper-all sexed up
Send a private message to .blackgt. Find all posts by .blackgt. Reply With Quote
Seems like its your end tank on the stock intercooler.
I think there are a few in the FS section. Replace and have fun.
.blackgt.
Find More Posts by .blackgt.
#3: 12-13-2012, 12:26 AM
 IceCold81
IceCold81's Avatar
You think this "Gunk" visible in this pic, is maybe just the air/engine bay grime/moisture combination causing this kind of look?
IceCold81
#4: 12-13-2012, 05:02 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Clean it the best you can and see how fast it comes back.
The Following 4 Users Say Thank You to Max Capacity For This Useful Post:
.blackgt. (12-13-2012), AZP Installs (12-16-2012), Dujo (12-16-2012), IceCold81 (12-13-2012)
Max Capacity
#5: 12-13-2012, 05:33 AM
 IceCold81
IceCold81's Avatar
I was actually thinking about doing EXACTLY that... Just to see exactly what I'm working with. Good call!
I mean it IS almost a 100k miles and never been touched ha, who knows.
IceCold81
#6: 12-13-2012, 06:05 AM
 ripemeat
Title: Banned
Car: Saxual content
Find all posts by ripemeat Reply With Quote
it's separating and leaking under boost. Get a new one.
The Following 2 Users Say Thank You to ripemeat For This Useful Post:
.blackgt. (12-13-2012), IceCold81 (12-13-2012)
ripemeat
Find More Posts by ripemeat
#7: 12-13-2012, 07:53 PM
 .blackgt.
.blackgt.'s Avatar
They can be had for cheap, so do your wipe clean and observe test, and then replace accordingly.
My vote goes to a definite leak.
The Following User Says Thank You to .blackgt. For This Useful Post:
.blackgt.
#8: 12-13-2012, 08:22 PM
 IceCold81
IceCold81's Avatar
So should I be worried that it seems so grimy near the leak? Seeing as it's an air to air leak? Or Is the grime maybe due to the heated/cooling affect of the air to the exterior (Condensation/moisture) and the engine bay grime over time maybe making it look like that?
Yea I'm assuming leak for sure as well, I'm curious to see just how bad it is after cleaning
IceCold81
#9: 12-14-2012, 12:21 AM
 .blackgt.
.blackgt.'s Avatar
Looks like some oil residue coming from the leak. This happens (oil in intercooler). I am sure others can chime in as to why this occurs.
.blackgt.
#10: 12-14-2012, 01:55 AM
 IceCold81
IceCold81's Avatar
Yea I'd like to hear some perspective pertaining to that...
IceCold81
#11: 12-14-2012, 06:24 AM
 ripemeat
Title: Banned
Car: Saxual content
the inlet, turbo, and intercooler system circulates small amount of oil (called blow-by). If you have a leak, you'll see the oil seep out. that is the classic spot where the ic separates for these cars.
ripemeat
#12: 12-14-2012, 06:48 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Send a private message to BarManBean Find all posts by BarManBean Reply With Quote
Pm'ed you and whatnot. What folks are telling you here is spot on.
BarManBean
Find More Posts by BarManBean
#13: 12-14-2012, 08:36 AM
 mustangendsley
mustangendsley's Avatar
Car: 2005 2.5 GT Limited, Stage 2
Send a private message to mustangendsley Find all posts by mustangendsley Reply With Quote
Mine did the same and i just went with the avo one and did not worry about trying to fix the old one. Mine was worse than yours also. Just get a new one original or a avo one.
mustangendsley
Find More Posts by mustangendsley
#14: 12-14-2012, 04:16 PM
 Mill
Car: 2005 Legacy GT 5eat
Send a private message to Mill Find all posts by Mill Reply With Quote
Checked mine as well and it looks like this too, but on the bottom instead of the top.
Came off the car at about 120k. I didnt notice any leaking issues though when I was stock.
Upon closer inspection it does appear that the tabs have come unbent and the plastic sticks out further compared to the other end. I'm glad I noticed this before I sold it.
Mill
Find More Posts by Mill
#15: 12-14-2012, 08:21 PM
 IceCold81
IceCold81's Avatar
Is any "Blow-by" or "Leak" mentioned regarding oil in that system, tend to flag major concerns? Or just kind of what our cars do?
IceCold81
Page 1 of 3 1 23 >
