Reload this Page Cold start-Whining noise
#1: 01-03-2013, 12:05 PM
 subarulegay
subarulegay's Avatar
Car: 07 Legacy 2.5i
Send a private message to subarulegay Find all posts by subarulegay Reply With Quote
Guys I need your help,
we've been getting some -20 celcius weather and when ever I start it for the first 5 seconds of the engine running it is as if there is a loud belt whining noize. The belts were changed this summer with gates belts.
Just wondering if there is anything to do to avoid the squealing noise or what could cause it.
subarulegay
Find More Posts by subarulegay
#2: 01-03-2013, 12:54 PM
 ripemeat
Title: Banned
Car: Saxual content
tighten the belt a little
ripemeat
Find More Posts by ripemeat
#3: 01-03-2013, 01:07 PM
 mwiener2
mwiener2's Avatar
Title: Trunk Monkey Chief
Car: 2005 Rocketback, 2010 Clown Car
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
It's a common problem. It's not the belts. Never been able to figure out exactly what it is.
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
The Following User Says Thank You to mwiener2 For This Useful Post:
derooi_07 (01-04-2013)
mwiener2
Find More Posts by mwiener2
#4: 01-03-2013, 01:11 PM
 gear_monkey
Send a private message to gear_monkey Find all posts by gear_monkey Reply With Quote
I didn't think it was the belts either because mine did the same thing two days ago and I have just put new belts on myself...if I tighten them anymore I'm afraid they will snap.
gear_monkey
Find More Posts by gear_monkey
#5: 01-03-2013, 01:16 PM
 Max Capacity
Max Capacity's Avatar
Are you sure it's not the starter hanging up for a couple of seconds ?
That's a common problem too.
You need to grease the starter shaft that the gear slides on to engage the FW.
mwiener2 (01-03-2013)
Max Capacity
#6: 01-03-2013, 01:35 PM
 robinlsb
robinlsb's Avatar
Title: My new race "car"
Car: 05 mt wagon stage 5 suspension
Send a private message to robinlsb Find all posts by robinlsb Reply With Quote
Not to worry. Mine has always done that, with no problems down the road since new.
It sounds terrible, but the engine is still fine.
"Belief does not make truth. Evidence makes truth. And belief does not make evidence."
robinlsb
Find More Posts by robinlsb
#7: 01-03-2013, 01:56 PM
 Nolmers06LGT
Nolmers06LGT's Avatar
Car: '06 LGT 5mt w/103k STG2 @18.25psi
Send a private message to Nolmers06LGT Find all posts by Nolmers06LGT Reply With Quote
Isn't that the beginning of the TOB failure? When mine went I thought it was a belt squeal at first. Find a vid of the TOB noise to verify its not that.
Nolmers06LGT
Find More Posts by Nolmers06LGT
#8: 01-03-2013, 02:05 PM
 robinlsb
robinlsb's Avatar
Nope TOB squeal occurs at any Temp
robinlsb
#9: 01-03-2013, 02:35 PM
 -Samurai-
-Samurai-'s Avatar
Car: '05 Subaru Legacy GT Limited
Send a private message to -Samurai- Find all posts by -Samurai- Reply With Quote
Mine does this as well. No idea what is is. I had a 2000 Toyota Celica that also did this at very cold temps but never had a problem caused by it. Still a mystery. Sounds really bad but goes away in like 3 seconds. Very odd.
-Samurai-
Find More Posts by -Samurai-
#10: 01-03-2013, 02:40 PM
 Nolmers06LGT
Ahh.. So it was just a coincidence that my TOB went when the weather started to cool. Mine sounded the worst when it was cold.. but the cold had nothing to do with it? Interesting.
Nolmers06LGT
#11: 01-03-2013, 02:42 PM
 PeterJMC
PeterJMC's Avatar
Title: Lvl 63 Night Elf Dwarf Paladin
Car: '10 Toyota Prius: Racecar Edition
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
Mebe a freezing idler pulley due to cold temps?
'10 Prius: Racecar Edition
PeterJMC
Find More Posts by PeterJMC
#12: 01-03-2013, 03:03 PM
 robinlsb
robinlsb's Avatar
Drive until it is warm. Then start it up, listen, put in gear. If it whines TOB. If not, then go right ahead and replace parts for no reason
robinlsb
#13: 01-03-2013, 05:46 PM
 Nolmers06LGT
Thanks for the sarcasm.. Good thing I already replaced the TOB 3 months ago.. and good thing I didn't get your advice then. My TOB disintegrated when I touched it. I'm lucky it waited to spill bearings until AFTER the car was on jackstands.
Once again, thanks for the help!
Nolmers06LGT
#14: 01-04-2013, 10:48 AM
 robinlsb
robinlsb's Avatar
I presumed you knew how to drive a standard shift. My bad If you are going through TOBs, like they are water, then the problem is with the operator.
If your TOB is toast after three months, then YOU have a problem.
robinlsb
#15: 01-04-2013, 10:55 AM
 racso_dor
racso_dor's Avatar
Car: 2005 Legacy GT
Send a private message to racso_dor Find all posts by racso_dor Reply With Quote
increase the volume of your radio while you turn your car on ...abakadabra you hear no more noise
racso_dor
Find More Posts by racso_dor
