Reload this Page Cable trans to hydraulic trans swap
#1: 01-05-2013, 04:40 PM
 PINESMOKER
Car: 98 Legacy GT
Send a private message to PINESMOKER Find all posts by PINESMOKER Reply With Quote
So I have a 98 LGT with a bad transmission. (Hydraulic type) Went to the junk yard found a (cable style) Legacy (94 I think )transmission with the right gear ratio 4.11s. Installed it with the original fork form my LGT, but the slave cylinder is not tight against the fork. Any ideas?.. What am I missing? Please help
PINESMOKER
Find More Posts by PINESMOKER
#2: 01-05-2013, 08:29 PM
 johnegg
johnegg's Avatar
Car: 98 obw, 97 GT w/ ej22, '01 H6 VDC
Send a private message to johnegg Find all posts by johnegg Reply With Quote
the good news , the trans should work.
bad news, you have to pull it to correct it. (or maybe the engine.)
there is a different pivot point in the trans bell housing for the clutch fork. the casting is / should be already in the housing, but you probably will have to drill? and tap the bolt hole. once you move the clutch fork pivot point you should be good to go.
johnegg
Find More Posts by johnegg
#3: 01-05-2013, 10:10 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
This video shows a few differences between the push and pull type transmission like johnegg is talking about:
Subaru transmission basics.wmv - YouTube
monkeyposeur
Find More Posts by monkeyposeur
#4: 01-05-2013, 11:14 PM
 PINESMOKER
Car: 98 Legacy GT
Yes I moved the pivot to the top position to match the transmission that came out. Do I need to move the pivot to the lower position? Everything matched perfectly.
PINESMOKER
#5: 01-06-2013, 06:34 AM
 johnegg
johnegg's Avatar
ok, i may have spoken too soon.
cable vs. hydraulic will not keep the trans from working.
push vs. pull will keep the trans from working.
hope i didn't foul things up.
johnegg
#6: 01-06-2013, 06:41 AM
 Sludgeroo
Sludgeroo's Avatar
Car: 1999 Lesbian Moving Van
Send a private message to Sludgeroo Find all posts by Sludgeroo Reply With Quote
You can drill and tap, but id start the tap in a drill press or a mill so its perpendicular perfectly to the plane its mounted on
Sludgeroo
Find More Posts by Sludgeroo
#7: 01-06-2013, 08:17 PM
 PINESMOKER
Car: 98 Legacy GT
There are two holes that the pivot can go into. My original trans had it in the upper. The cable trans that it in the lower. I moved to the upper pivot to match my original and now there is slop between the fork and my slave cylinder.
PINESMOKER
#8: 01-06-2013, 09:05 PM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
go under the dash and f with the master, thats what fixed all my issues
Originally Posted by Stang70Fastback View Post
Clearly, the solution to shit breaking is to break more shit until the shit works again.
I'm Dumber Then I Seem, Remember That, I Won't.
Swagon_Wagon
Find More Posts by Swagon_Wagon
#9: 01-07-2013, 07:41 PM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
I did not have to drill / tap the hole on the last swap I did. All it took was using a 22mm socket to take off the pivot ball and then it threaded right into the other spot.
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#10: 01-11-2013, 05:06 PM
 PINESMOKER
Car: 98 Legacy GT
No problems with the transmission just shotty pressure plate thanks Sachs... For the headache... So after closer review it was pressure plate. After bolting it to the flywheel the little fingers where to flat. Back to the part store matched to another and wam bam Thank you ma'am. Now I have found that I have a bad head gasket.
PINESMOKER
#11: 01-11-2013, 08:47 PM
 monkeyposeur
Car: 95 BK, 93 SS!
You are now part of the failed HG club. Welcome.
monkeyposeur
#12: 01-11-2013, 09:02 PM
 PINESMOKER
Car: 98 Legacy GT
Thanks
PINESMOKER
