Reload this Page Flashing Cruise Light; Not Working
#1: 05-23-2012, 04:01 PM
 Roche
Roche's Avatar
Car: 2005 Legacy LGT
Send a private message to Roche Find all posts by Roche Reply With Quote
I tried using cruise a couple of days ago after work and the second I
turned it on, the light just flashed.
I couldn't do anything with it, i tried shutting it off, setting it etc but it flashed for the 70 minutes home and I'm not sure if I should use it again and what went wrong.
As for the song... I wanted to listen to something with a good beat and Eddie Money wasn't going to cut it
http://www.youtube.com/watch?v=PG4vKL3PVVA&list=UU5NpWk_-mZ1ESYAg3CkEkfA&feature=plcp
Edit:
I can't figure out how to embed the video and I also couldn't make it shorter
Roche
Find More Posts by Roche
#2: 05-23-2012, 04:11 PM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Do you have a Check engine light also ?
I seem to recall this happening to someone here before a couple years back.
May be PM someone like ClimberD@hexmods or BAC5.2 They may know. bmx045 may know the answer too.
175,000+ miles, 5/20/12 new ej257 short block, 8/20/11 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. Also CHECK YOUR OIL, these cars use it.
Max Capacity
#3: 05-23-2012, 04:29 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Send a private message to BarManBean Find all posts by BarManBean Reply With Quote
Incoming Check Engine Light!
Flashing cruise happened to me before the CEL kicked in when my front O2 sensor was busted. I think it's kind of like a "soft" CEL...ECU senses something is wrong, but takes the time to be sure before throwing a CEL--in the meantime you get the flashing / non-functional cruise (which will persist when the CEL shows up).
See if you can pull the code. If you can do a learning view it will probably tell you.
BarManBean
Find More Posts by BarManBean
#4: 05-23-2012, 04:34 PM
 Max Capacity
Title: Gearhead
The guy's at the auto parts stores will read the codes for free if you need.
Max Capacity
#5: 05-23-2012, 07:02 PM
 Roche
Roche's Avatar
No engine light, hopefully not ever.
Thanks for the sources
I only have 300 miles until the warranty is up but they're going to
say there's nothing wrong
Roche
#6: 05-23-2012, 07:21 PM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
What he said. When my front o2 went it would first start with a flashing cruise under certain situations. Plugged my code reader in and it showed up as the front o2 each time. Go get your codes read. Buy the new part. Install it. Be happy.
Nrw
Find More Posts by Nrw
#7: 05-23-2012, 07:26 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Tell them to go fly a kite if they say nothing is wrong. Something is wrong, and the code that can be read will tell you exactly what IS wrong, lol.
BarManBean
#8: 05-23-2012, 09:24 PM
 HAMMER DOWN
HAMMER DOWN's Avatar
Title: Duke
Car: 05 Legacy GT w/ STi 6MT~07 Solstice GXP
Send a private message to HAMMER DOWN Find all posts by HAMMER DOWN Reply With Quote
Depending on the OBDII scanner. If no engine light is on. You need to select option "Pending Trouble Code" This is a trouble code that the ECU stored, but the problem hasn't accrued long & or often enough to "set" the trouble code & engine light.
Mike
HAMMER DOWN
Find More Posts by HAMMER DOWN
#9: 05-23-2012, 09:37 PM
 Boost_Doc
Boost_Doc's Avatar
Car: 05 BSM GT Limited
Send a private message to Boost_Doc Find all posts by Boost_Doc Reply With Quote
Soft codes will always be stored before the check engine light will come on. A scanner will show pending codes and hard set codes. I am not sure what auto parts store use, but it should read pending codes. I have a matco tools little pocket scanner that can read both. Go get it checked.
P.S. If here is a pending code that means something failed, the dealership cannot say no to that. I am a service advisor at one haha
Boost_Doc
Find More Posts by Boost_Doc
#10: 05-24-2012, 02:13 AM
 nightspeed98
nightspeed98's Avatar
Car: 2012 LGT Graphite Gray Metallic
Send a private message to nightspeed98 Find all posts by nightspeed98 Reply With Quote
My previous car (09 gt) had blinking cruise light when SI Drive failed (or something like that), dealer found broken crank sensor and crank tooth. I'll doublecheck paperwork if I still have it,
nightspeed98
Find More Posts by nightspeed98
#11: 05-25-2012, 10:59 PM
 yar1
Car: 05 LGT silver
Send a private message to yar1 Find all posts by yar1 Reply With Quote
This happened to me before after i drove through a deep puddle at freeway speeds, but it cleared up later after it dried off/i restarted the car a few hours later.
yar1
Find More Posts by yar1
#12: 05-26-2012, 09:13 PM
 Roche
Roche's Avatar
A little update:
Cruise works now, but the really odd thing is that when it's set,
the car keeps jolting like its letting off the gas and then stomping back on it
simultaneously. However, it's not because I look at my MPGs and the RMPs and they dont change unless its going uphill.
Any ideas?
Roche
#13: 05-26-2012, 09:16 PM
 Boost_Doc
Boost_Doc's Avatar
Still no pending codes?
Boost_Doc
#14: 05-26-2012, 09:34 PM
 mumblinaviator
mumblinaviator's Avatar
Car: '07 Spec.B 18g Cryo Tuned
Send a private message to mumblinaviator Find all posts by mumblinaviator Reply With Quote
Originally Posted by Roche View Post
A little update:
Any ideas?
Don't use cruise until it's fixed?
Get the codes read. If you're hard pressed to get the cruise working, try un hooking the negative battery terminal to reset the ECU.
I've had all of my lights: cruise, Si Drive, traction control, and CEL all come on at once when I was swapping fuel pumps, a battery disconnect will clear it all.
mumblinaviator
Find More Posts by mumblinaviator
#15: 05-27-2012, 07:51 AM
 king_j
king_j's Avatar
Car: 2005 LGT 5MT
Send a private message to king_j Find all posts by king_j Reply With Quote
Dealer warranty is almost up? Extend it. Flashing cc light for me meant a bad valve.
king_j
Find More Posts by king_j
