Reload this Page installing hella super tones in 98 legacy
#1: 11-25-2012, 02:21 PM
 mbf6182
Title: Banned
Car: 98 Legacy GT
Find all posts by mbf6182 Reply With Quote
im looking to install hella supertones in my 98 legacy gt I just need to know what to buy. I wanna get the pink ones from subimods.com but the bracket and harness are expensive so i wanted to buy them somewhere else. some of the other sites i looked at where i was going to buy those two parts make you specify the year and make of your car and mines never on that list. Help!! I wanna order the stuff asap
mbf6182
Find More Posts by mbf6182
#2: 11-26-2012, 11:59 AM
 golunnova
golunnova's Avatar
Car: 08 QSM LGT 5EAT Stg1
Send a private message to golunnova Find all posts by golunnova Reply With Quote
I'm not the most hands on car guy out there so I bought the hella super tones / harness / bracket from subimods and the install was clean and simple. I personally felt the convenience was worth the price. Just my 2 cents. Good luck with the install.
golunnova
Find More Posts by golunnova
#3: 11-26-2012, 03:59 PM
 LJ08GT
LJ08GT's Avatar
Car: 97 LGT sedan 4EAT
Send a private message to LJ08GT Find all posts by LJ08GT Reply With Quote
i made my own bracket out of flat steel you can get at any hardware store. Cut to length, drill holes and paint it. I don't know what this said harness is, but i didn't use one of them either. All you need is some wire, spade connectors, ring terminal connectors and butt connectors and the crimping tool. You don't need to use the relay that comes with the horns either because the Suby's already use a relay for horn so you just use the existing horn wires.
A friend and i made 3 brackets for WAY cheaper than it costs for one bracket from subimods.com. Just my opinion.
LJ08GT
Find More Posts by LJ08GT
#4: 11-26-2012, 04:04 PM
 Silinc3r
Silinc3r's Avatar
Car: 90 LS, 91 SS, and 05 GT
Send a private message to Silinc3r Find all posts by Silinc3r Reply With Quote
^The harness is what you made to wire them up. They just supply it with the additional cost to make it a little easier of an install. And their relays are the best. But I agree it is a lot cheaper to make your own. It's all about the fit and finish.
Silinc3r
Find More Posts by Silinc3r
#5: 01-08-2013, 08:52 AM
 mbf6182
Title: Banned
Car: 98 Legacy GT
Ok thanks everybody for the advice. I still haven't ordered them but, its a new year and i've got some extra money. We'll see how it goes
mbf6182
#6: 01-08-2013, 09:42 AM
 SBT
SBT's Avatar
Title: Site Majordomo
Rank: Admin
Car: SWP 05 LGTLW 5MT waiting on an S402
Send a private message to SBT Find all posts by SBT Reply With Quote
There's a lot of difference between the 2nd Gen install and the 4th Gen install. Hence the OP's 2nd Gen question. I think his concern is that Subimods doesn't list the complete harness, brace and horns setup that they offer for the newer models.
So many mods, so little time
SBT
Find More Posts by SBT
#7: 01-08-2013, 01:52 PM
 sti_044
sti_044's Avatar
Car: 99 GT Wagon (Black)
Send a private message to sti_044 Find all posts by sti_044 Reply With Quote
Sorry to be off topic, but what is the point of the "relay kit"
I just spliced into my stock horns so I am running stocks and hellas (they might actually be SickSpeed) with no issues what-so-ever. Never understood the purpose of the relay/kit
sti_044
Find More Posts by sti_044
#8: 01-08-2013, 02:19 PM
 Stang70Fastback
Stang70Fastback's Avatar
Car: 1998 Subaru Legacy Outback Limited
Send a private message to Stang70Fastback Find all posts by Stang70Fastback Reply With Quote
You don't need a relay when using our horns, because there is already a relay built into the circuit. The purpose of the relay is to allow the full current to travel directly to the horns without it needing to pass through the switch (in this case, the horn button in the steering wheel) first.
Simply putting the switch in line with the main power to the horns means the switch has to be very heavy duty to be able to manage the current, and is less efficient since the resistance of both the switch and the extra wire length will reduce the volume of the horns. (Even regular disc horns in a car draw a surprising amount of power.)
Our cars already have the relay (you should be able to hear it click when you honk the horn button with the stock horns disconnected) so you simply need to swap the old ones with the new ones.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
sti_044 (01-08-2013)
Stang70Fastback
Find More Posts by Stang70Fastback
#9: 01-08-2013, 03:12 PM
 sti_044
sti_044's Avatar
oh ok, perfect. Thank you very much for the prompt and detailed response.
sti_044
#10: 01-09-2013, 08:31 AM
 mbf6182
Title: Banned
Car: 98 Legacy GT
Yes you are right. Thats what I am concerned about. When I look on installations online its always for 2000 and up. I'm wondering if the wiring is different and so forth. Im a female btw
mbf6182
#11: 01-09-2013, 08:55 AM
 SBT
SBT's Avatar
Rank: Admin
Sorry... gender non-specific "his" - sorry
SBT
#12: 01-09-2013, 01:07 PM
 sti_044
sti_044's Avatar
I just tied into the stock horns. super simple!
sti_044
#13: 01-09-2013, 01:53 PM
 SBT
SBT's Avatar
Rank: Admin
I'd run a 12V line off the battery into a relay and splice into the stock line to provide the on/off trigger for the Hellas. That way, you're not overloading (amperage-wise) the line to the stock horns. The Subimod setup would work for this, with some minor wiring (lengthened/shortened bits), it's essentially the same setup, just different mounting/connection points.
SBT
#14: 01-09-2013, 09:10 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
I'd like to install some Hellas at some point but I want a toggle switch so I can choose between the stock horns and the Hellas. Silly I know, but I would like to be able to have gentle horns and **** you horns. Probably a pita to wire up.
monkeyposeur
Find More Posts by monkeyposeur
#15: 01-09-2013, 09:13 PM
 subikid90
subikid90's Avatar
Title: EJ22T
Car: 97 LGT & 98 LGT
Send a private message to subikid90 Find all posts by subikid90 Reply With Quote
Find a 1st gen steering wheel with the two horn buttons and wire one for the stockers and the other for the hellas. Then you could really f*ck with people and push them both at once...or play music with them haha
-Subikid90
1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR
1998 Legacy GT Limited waiting for EJ22T hybrid swap
subikid90
Find More Posts by subikid90
