Reload this Page 05 LGT banjo bolt removed, no screen
#1: 01-11-2013, 07:44 AM
 dsdavis02
Send a private message to dsdavis02 Find all posts by dsdavis02 Reply With Quote
I bought this car two weeks ago. Havent touched it, repair wise. Was a one owner so cal car. Unmolested.
Dropped off with mechanic today.
He removed the banjo bolt nearest the turbo and said there was no screen and just some oil sludge buildup. So its clean but the filter is missing.
Any insight? It was obviously removed. Or am I mistaken? Just curious.
dsdavis02
Find More Posts by dsdavis02
#2: 01-11-2013, 07:49 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Welcome to the forum.
You are mistaken.
That small banjo is not the one.
You need the one that is on the back of the passenger side head behind #3 cylinder
Your best bet is to get a stubby ratcheting box end wrench from Harbor Fright, you need a 17mm to break it loose.
The Following 2 Users Say Thank You to Max Capacity For This Useful Post:
dustincredible (01-11-2013), Underdog (01-11-2013)
Max Capacity
#3: 01-11-2013, 09:58 AM
 dsdavis02
Ok cool ill get them to re-check at my next appt(fri). fingers crossed!
What does the small amount of sludge buildup on the top bolt indicate?
dsdavis02
#4: 01-11-2013, 10:10 AM
 Max Capacity
Title: Gearhead
A slight leak of the crush washers.
Stop the by dealership and tell the parts guy you want two of the crush washers for it so they can be replaced.
Have your guy do next time.
Max Capacity
#5: 01-11-2013, 11:58 AM
 dsdavis02
Noted.
dsdavis02
#6: 01-11-2013, 12:51 PM
 TheBlackPearl
TheBlackPearl's Avatar
Title: ^ way-rad-stay-wag ^
Car: OBP '05 LGTL Wagon 5EA[wesome]T Stg. 2
Send a private message to TheBlackPearl Find all posts by TheBlackPearl Reply With Quote
From what I understand, any banjo bolt in the lubrication system that has the raised nipple on the top of he head is where a screen filter goes.
The Following User Says Thank You to TheBlackPearl For This Useful Post:
compsurge (01-12-2013)
TheBlackPearl
Find More Posts by TheBlackPearl
#7: 01-11-2013, 01:05 PM
 Max Capacity
Title: Gearhead
The second banjo and filter are behind the Timing belt cover on the front of #2 cylinder, (drivers side).
HAMMERDOWN has file down the top of his and removed the bolt and removed the filter.
I had mine removed when the machine shop was assembling the long block.
The Following User Says Thank You to Max Capacity For This Useful Post:
TheBlackPearl (01-13-2013)
Max Capacity
#8: 01-11-2013, 10:56 PM
 -Samurai-
-Samurai-'s Avatar
Car: '05 Subaru Legacy GT Limited
Send a private message to -Samurai- Find all posts by -Samurai- Reply With Quote
Theres one in there too? Well I better get that one out too. Fixed my P0021 code by removing the destroyed banjo filter on the drivers side AVCS oil line.
-Samurai-
Find More Posts by -Samurai-
#9: 01-12-2013, 07:44 AM
 dsdavis02
I printed a rear engine picture with red lines showing the locations. I'm going to take it to my guy fri. easy and effective.
Do you think they'll charge me again since they did the wrong one initially?
dsdavis02
#10: 01-12-2013, 09:35 PM
 HAMMER DOWN
HAMMER DOWN's Avatar
Title: Duke
Car: 05 Legacy GT w/ STi 6MT~07 Solstice GXP
Send a private message to HAMMER DOWN Find all posts by HAMMER DOWN Reply With Quote
Link to pics. in post;
http://legacygt.com/forums/showpost....&postcount=158
Mike
Still rocking the Original Motor & VF-40 Turbo with 15k OCI. Member of the 200K + club. Currant mileage:224932
The Following User Says Thank You to HAMMER DOWN For This Useful Post:
HAMMER DOWN
Find More Posts by HAMMER DOWN
#11: 01-13-2013, 06:19 AM
 TheBlackPearl
I was hoping you could unbolt that side of the Tbelt cover, darnit.
Thanks for posting that Hammerdown, I'll add it to my list.
TheBlackPearl
