Go Back   Subaru Legacy Forums > Vendor Specific Forums > BrenTuning
Reload this Page Ask the Tuner Thread!
Page 1 of 4 1 23 > Last »
#1: 12-27-2012, 01:19 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
Send a private message to BrenTuning Find all posts by BrenTuning Reply With Quote
Simple topic here.....
Have a question about recommend parts, or setups that tune well?
Have a question about mod paths that equal your goals or xxx whp?
Have a question about reliability or maintenance for best possible tuning numbers?
Just ask them here. This applies to anyone.
Disclaimer: We do not discuss self tuning help methods.
BrenTuning LGT E-Tune / Dyno Specialists
Email: sales@brentuning.com
Phone: 508.762.1769
Facebook: www.facebook.com/brentuning (LIKE US TODAY)
The Following 2 Users Say Thank You to BrenTuning For This Useful Post:
Dujo (12-27-2012), LosAngelesLGT (12-27-2012)
BrenTuning
Find More Posts by BrenTuning
#2: 12-27-2012, 01:32 PM
 ripemeat
Title: Banned
Car: Saxual content
Is a new turbo oil feed line with an aftermarket filter really necessary?
ripemeat
Find More Posts by ripemeat
#3: 12-27-2012, 03:01 PM
 HipsterDoofus
HipsterDoofus's Avatar
Title: Better driver than
Send a private message to HipsterDoofus Find all posts by HipsterDoofus Reply With Quote
what do I do if I find out my tuner is stealing maps out of cars that other shops tuned and putting them in my car and then charging me full price for it?
HipsterDoofus
Find More Posts by HipsterDoofus
#4: 12-27-2012, 03:05 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
With a new turbo install, it is ALWAYS recommended. Not worth destroying a new turbo.
Phone: 508.762.1769
BrenTuning
#5: 12-27-2012, 03:10 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
If it is true, you should be able to prove it with copies of both roms of said tuner. You will find that alot of tuners rapidly losing market share and their customers start rumors that others steal their maps but can't prove it or back it up as it's not true.
We've done plenty of reads of cars that were "dyno tuned" for $500 that had an OSECUROMS / XPT free rom on it with 99% of the original data contained.
Good luck with finding out the culprit
Phone: 508.762.1769
BrenTuning
#6: 12-27-2012, 03:19 PM
 EssTeeAai
EssTeeAai's Avatar
Car: '05 LGT sedan & '06 2.5i wagon
Send a private message to EssTeeAai Find all posts by EssTeeAai Reply With Quote
EL or UEL header, and why? And will I need to retune after this bolt-on?
The Following User Says Thank You to EssTeeAai For This Useful Post:
Dujo (12-27-2012)
EssTeeAai
Find More Posts by EssTeeAai
#7: 12-27-2012, 03:26 PM
 spec.B Dream
Car: 08 spec.B
Send a private message to spec.B Dream Find all posts by spec.B Dream Reply With Quote
Why is it that my tune drifts? I work for a while, get everything dialed in to where logs and Learning Views are clean for several weeks, and then ignore the tune for a while. I pull a Learning View a few months later, and IAM has dropped and learned AFR is out greater than 5%. This has happened several times. It is like I need to get a new tune every six months.
spec.B Dream
Find More Posts by spec.B Dream
#8: 12-27-2012, 04:02 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
Could be many things, but we can't troubleshoot others tunes.
Phone: 508.762.1769
BrenTuning
#9: 12-27-2012, 04:03 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
A proper EL header will make great mid to top end and allow far more aggressive ignition settings. Placing both on untuned with make similar power. A good tuner can do alot more with a big tube EL header.
We recommend the Invidia Race header big tube 1.5 scroll for EL. And Tomei for UEL. A retune is key for getting the most out of this modification.
Phone: 508.762.1769
BrenTuning
#10: 12-27-2012, 05:22 PM
 Umass94
Umass94's Avatar
Title: I8A4RE
Car: 06 OBXT 5MT, stg. 2
Send a private message to Umass94 Find all posts by Umass94 Reply With Quote
For a stage 2 tune, does an aftermarket TMIC make a big enough difference to justify the $600 price? Assume cat less up pipe, high flow catted down pipe, and AVO mufflers. Thanks.
Here's proof: Just 1 minute after buying my OBXT, I had 7 phone calls from insanely hot women, and got 7 dates out of it. Coincidence? I think not.
Umass94
Find More Posts by Umass94
#11: 12-27-2012, 07:04 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
With a proper retune, absolutely. A cheap Perrin unit does the job.
For best results when tuning a good FMIC does an even better job.
Phone: 508.762.1769
BrenTuning
#12: 12-27-2012, 07:59 PM
 Dujo
Dujo's Avatar
Car: 1 of 99 2005 ABP/Tpe LGT Ltd 5MT Wagon
Send a private message to Dujo Find all posts by Dujo Reply With Quote
So the owners manual says that 91 octane or better is required for the LGTs from the factory. My understanding is that it was okay to put 87 in occassionally in a pinch assuming the ecu will just pull some timing (lower IAM?).
Is this still true with an aftermarket tune or is it now less safe to use a lower octane rating? Dependent on the tune or tuner? Totally safe in all cases for all tuners? How about your tunes specifically?
For example, let's say I was stage 2 and I put 93 in when I brought my car in to be BrenTuned. Then I get stuck out in the backwoods of Maine and all the local guy has is 87. Safe? Safe if I don't push it? Safe all day long and I just wont make my normal 93 power? Or totally unsafe and I should call AAA to bring me 93 from civilization?
I have no idea what I am talking about.
Dujo
Find More Posts by Dujo
#13: 12-28-2012, 07:55 AM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
We don't recommend any sort of 87 octane in these cars at all. Not even the factory tune. We give IAM alot of range but the knock correction range will be severe even in the cruise range (off boost). Most off path gas stations around here have at least 91.
I would limp it as much as possible to the nearest 93 station.
Phone: 508.762.1769
The Following User Says Thank You to BrenTuning For This Useful Post:
Dujo (12-28-2012)
BrenTuning
#14: 12-28-2012, 10:31 AM
 EssTeeAai
EssTeeAai's Avatar
Can any benefit be achieved from tuning a stock NA Subaru 2.5 motor?
And I don't necessarily mean power gains; how about better fuel mileage?
Or is it a complete waste of time and money?
EssTeeAai
#15: 12-28-2012, 12:59 PM
 BrenTuning
Title: Vendor III
Car: 628whp E92 M3
We've mapped a bunch of them. On premium fuel they make some power, on 87 they are already pulling timing. We can make the drive-ability 100 times better however. Anyone who has gotten it done was very happy with it.
Phone: 508.762.1769
BrenTuning
