Reload this Page hickup at 2500 rpms
#1: 01-03-2013, 05:58 PM
hickup at 2500 rpms
 colby
colby's Avatar
Car: 97 GT 5spd
Send a private message to colby Find all posts by colby Reply With Quote
I was out of town for a week then I come back and drive and notice just below 2500 rpms to about 3000 I have a loss of power. it has to little peaks between there in the loss of power it seems like so it surges. it is most noticeable in 2nd gear. anyone have something like this happen? I have a ebay scan tool and poked around nothing looked to suspicious. was looking for vacuum leaks and cleaned the egr with no luck. can you use a air compressor to safely check for vac leaks?
colby
Find More Posts by colby
#2: 01-03-2013, 08:39 PM
 colby
colby's Avatar
Car: 97 GT 5spd
bump I'm driving across the state tomorrow and want to try to get it fixed
colby
#3: 01-03-2013, 08:51 PM
 instantfury
instantfury's Avatar
Car: 05 LGT MT 1 of 478 Stage 3 OEM Fueling
Send a private message to instantfury Find all posts by instantfury Reply With Quote
Ignition coil perhaps? I have had somewhat similar symptoms and it turned out it was that. No code for a while, though. Plug in your scan tool or log if you can first start up in the morning.
instantfury
Find More Posts by instantfury
#4: 01-03-2013, 08:53 PM
 Tr00b
Car: 1999 Legacy "L" 5MT, 1997 Jeep Wrangler
Send a private message to Tr00b Find all posts by Tr00b Reply With Quote
Do you have main bearing noise or piston slap?? Sometimes that can set the knock sensor off and derate the engine. the 2000-3000 is a famous place for this to occour.
Apparently there is a way to calibrate your TPS. If the hesistation is consistent, your throttle position sensor could have a dead spot.
Tr00b
Find More Posts by Tr00b
#5: 01-04-2013, 12:27 AM
 colby
colby's Avatar
Car: 97 GT 5spd
I have some piston slap some times cold but didn't notice it starting it the first start. how long should it take to reset the knock sensor if that was the case. the tps doesn't have any dead spots checked with scan tool. it will hesitate at different openings too
colby
#6: 01-04-2013, 04:15 PM
 Tr00b
I have the same hesitation except at lower rpm. It also does hesitate at 2500 ish but less severe. I am going to try another ignition coil hopefully that clears up the problem. my car also leaks around the valve cover gasket seals and oil gets into the spark plugs. I'm not sure if that is causing misfires or not. My car has piston slap as well... But it is marginal.
Tr00b
#7: 01-05-2013, 12:24 AM
 spooln30
Car: 99 Legacy 2.5GT Toyota Supra 2jz/R154
Send a private message to spooln30 Find all posts by spooln30 Reply With Quote
Weird problem but just curious. Is the heat on and is it on defrost? Reason I ask is if its on defrost, which is heat to the windshield only, the AC compressor will kick in just as it would if it were summer and the AC was on. I'm thinking maybe your feeling the surge from this. I know on my 2.2 it was really noticeable when the AC was on. My 2.5 it's still noticeable but not as much.
spooln30
Find More Posts by spooln30
#8: 01-06-2013, 02:48 PM
 colby
colby's Avatar
Car: 97 GT 5spd
its running good now. i changed the oil a few weeks ago and i spilt oil on the cam positioning sensor right below it. sprayed some maf cleaner on it before i left on my trip and got back to Cheney with no hesitation.
The Following User Says Thank You to colby For This Useful Post:
Tr00b (01-06-2013)
colby
#9: 01-06-2013, 09:05 PM
 Tr00b
Ooh... Good call. Mine is drenched in oil!
Tr00b
#10: 01-06-2013, 10:51 PM
 colby
colby's Avatar
Car: 97 GT 5spd
nice should make a big difference. im thinking of putting a little dielectric grease on it hopefully keep this from happening again.
colby
