01-09-2013, 08:35 PM
Anyone used Fix-a-Flat before?
Car: 2011 Legacy 3.6R
I had to deal with two flat tires in the last 5 months and in both incidents neither tire was repairable. I just learned about this fix-a-flat product, does it work on a flat tire that's not repairable?
01-09-2013, 08:46 PM
Car: RMS13 --> 05 Turbo Camry
there is probably a reason why they are repairable..lol
01-09-2013, 08:58 PM
Car: '09 SpecB 18G BrenTuned 347whp, '05 2.5i
Fix a flat is a super temp fix. It usually doesn't work And if it does, it's usually good for just a few miles. Unless you have a REALLY slow leak. It also makes a real plug or patch (especially a patch) difficult and messy.
Better for mower tires IMO.
01-09-2013, 09:05 PM
Car: sz 10.5 jordans
Also it messes up tpms.
The Following 2 Users Say Thank You to slim101 For This Useful Post:
01-09-2013, 09:26 PM
I'm guessing that will gum up the wheel and tpms as well.
How old are your tires?! You drive on the shoulder alot?
01-10-2013, 05:57 AM
Car: 2010 LGT & 2009 FXT
I asked my installer about removing my spare and just using fix-a-flat when I changed tire sizes. He said if I ever bring him a tire that has been exposed to fix-a-flat he will lock his door and send me elsewhere.
Apparently as stated above it's nasty and gets into everything inside the tire.
01-10-2013, 06:44 AM
Title: Whut, who me?
Car: It runs 12's
Not to mention some brands use propane as the propellent and if you cause a spark dismounting the tire you might go home with no eyebrows!
01-10-2013, 06:57 AM
Only way I would use it is if I was stuck in the middle of no where. We have customers come in all the time with that crap in there tires. Like I said before it messes up ur tpms and after time will still leak.
01-10-2013, 07:50 AM
Car: 2012 Legacy 2.5GT GGM
Out of curiosity, what did you end up doing when you increased your tire size?
01-10-2013, 10:59 AM
Car: '10 LGT , '96 Outback
FWIW ... I carry a tire plug kit and small 12v compressor.
The Following 3 Users Say Thank You to BigBopper For This Useful Post:
01-10-2013, 11:02 AM
Title: Engorged, throbbing,
Car: 2009 QSM LGT 5MT stg3
If I wanted to sabotage someone's car, I would fill a tire with Fix-a-Flat rather than slashing one.
01-10-2013, 11:04 AM
Car: 2010 LGT
Use fix a flat in your law mower tires not your legacy. It kills tpms sensors. On the can it says its safe for them but I've changed dozens because fix a flat ruined them.
01-10-2013, 11:06 AM
in college, i worked in a gas station, pumping gas, doing oil changes, and changing tires... Fix A Flat would ruin my afternoon sometimes. lol
01-10-2013, 11:47 AM
Because I went with a smaller sidewall when I increased rim size the installer said I could still get away with the OEM spare in an emergency. Luckily I haven't had to find out whether this is true.
The Following User Says Thank You to acumenhokie For This Useful Post:
