#1:
12-25-2012, 03:49 PM
Learning View help
Title: Wagonmeister
Car: 06 RalliSpec'd GT Wgn 5EAT
Just switched back to 91oct tune from e85 tune as the local pump is down for a month with tank repairs.
How does my learning view look to you after 100 miles? I appreciate all the help. I am most concerned about the a/f learning of negative 13.30, -13.30 and -14.00
Code:
CAL ID:A2WF200C
Description: 06 USDM Legacy GT AT
ECU ID:xxxxxx3106
IAM 1.0000
A/F Learning #1:
0 - <5.60 5.60 - <10.00 10.00 - <95.00 95.00+
-13.30 -13.30 -14.00 0.00
FLKC Table 0 - <0.85 0.85 - <1.10 1.10 - <1.35 1.35 - <1.60 1.60+
0 - <1650 0.00 0.00 0.00 0.00 0.00
1650 - <2600 0.00 0.00 0.00 0.00 0.00
2600 - <3200 -1.00 0.00 0.00 0.00 0.00
3200 - <4000 0.00 0.00 0.00 0.00 -0.15
4000 - <4800 -0.50 0.00 0.00 0.00 0.00
4800 - <5800 0.00 0.00 0.00 0.00 0.00
5800+ 0.00 0.00 0.00 0.00 0.00
#2:
12-26-2012, 11:46 AM
Title: Banned
Car: Saxual content
did you switch maps too? or just fuel? if you did switch maps- it looks good except for the injectors that aren't tuned for. those trims look just like what would happen if you put big injectors in and didn't touch the tune. if you didn't switch maps- you're not knocking enough to start to worry. but then again, if it's the same map as e85 and you're barely knocking on 91, one would think the tuner did not reap the benefits of e85 in terms of timing advance, which would be a shame.
#3:
12-26-2012, 12:13 PM
Title: Wagonmeister
Swapped tunes w fuel change. Tuner says I must have an air leak, but e tune was great before the switch and LV before tune switch was clear.
#4:
12-26-2012, 12:27 PM
Title: Banned
Car: Saxual content
air leaks usually aren't consistent(almost identical) along all the closed loop the fuel trim ranges, larger injectors do. what you can do is look in both of the maps and see if the injector latency's and scalar are the same on both maps, as well as the maf scale.
#5:
12-26-2012, 09:49 PM
Title: Vendor III
Car: Infamous1 Stg3 08 5EAT + Stg3.5 08 SpecB
either something is up with the tune, you have some odd mix of fuel still, or you sprung a good leak.
12-26-2012, 09:55 PM
Title: Wagonmeister
Update:
Tuner called it It was an air leak. Visual inspection showed the T-clamp from TMIC to throttle body hose wasn't tightened when the motor was done 1,100 miles ago....
So short drive showed this:
Code:
CAL ID:A2WF200C
ECU ID:4512503106
IAM 0.8750
A/F Learning #1:
-15.00 -0.10 -2.60 0.00
1650 - <2600 -1.00 0.00 0.00 0.00 0.00
2600 - <3200 0.00 0.00 0.00 0.00 0.00
3200 - <4000 0.00 0.00 0.00 -0.50 0.00
4000 - <4800 0.00 0.00 0.00 0.00 0.00
Then tuner asked about voltage drop at idle due to dying alternator or battery.....
Looks like my Braille 11lb battery is not liking winter. Time for a real winter battery.
Thanks for the help everybody.
#7:
12-26-2012, 10:14 PM
Title: Vendor III
Glad you got it all sorted out.
12-27-2012, 07:15 AM
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
I'm assuming you reset your ECU after having that clamp fixed? Because your IAM is at 0.8750 and you're still pulling timing, and your A trim is still -15.
#9:
12-27-2012, 07:20 AM
Title: Banned
Car: Saxual content
idle battery voltage effects injector pulse widths, that's what he was referring to with his superduper lightweight battery
The Following 2 Users Say Thank You to ripemeat For This Useful Post:
#10:
12-27-2012, 07:52 AM
Title: Nerd^2
Oh, I see I see...
#11:
12-27-2012, 05:22 PM
Title: Wagonmeister
So, Interstate Mega Tron battery shows 13.6v at idle now rather than the 11.2 that my Braille was showing.
Simple test drive around neighborhood, 2nd gear light driving reveals:
Code:
CAL ID:A2WF200C
ECU ID:4512503106
IAM 1.0000
A/F Learning #1:
-4.00 -0.30 -0.30 0.00
3200 - <4000 0.00 0.00 0.00 0.00 0.00
#12:
12-27-2012, 06:41 PM
Title: Vendor III
Low voltage causes all sorts of issues. You can even brick an ECM with low voltage.
The Following User Says Thank You to m sprank For This Useful Post:
#13:
12-28-2012, 10:11 AM
Title: Banned
Car: Saxual content
I know flashing with low voltage can result in bricks, but what other ways?
#14:
12-28-2012, 09:02 PM
Title: Vendor III
Driving with low voltage can cause it. Any low voltage situation can cause the electronics to go bad. I have seen an LGT with a bad alternator brick the ECM driving. Died driving down the road.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
