Reload this Page New DD project
Page 1 of 4 1 23 > Last »
#1: 11-30-2012, 07:35 AM
New DD project
 2.5i 17
2.5i 17's Avatar
Send a private message to 2.5i 17 Find all posts by 2.5i 17 Reply With Quote
I wanted to be more involved with the Legacy forum as I am mostly on the IWSTI.com site. I picked up a 05 Legacy gt 5mt wagon for a new DD. It needed a bunch of work, though should be pretty cool when I'm done.
This is a garage build so things may appear ghetto at times.
I'll also post a few pics of the STI below.
I'll try and keep this updated, here is the current build going on.
2005 legacy GT 5MT
Engine
701 - Casting Block
Manley Piston set 99.5
Subaru ring set
ACL Bearings
Subaru Springs from 08 STI - 08 STI retainers
Heads - 3 angle Intake, Radiused Exhaust - Mild hand port/blend the seats
Ferrea Competition Plus Valves - std size
Gates Timing belt kit
Gates Timing Belt
Covert Oil Pickup tube
2008 STI oil pump
OEM head gaskets
Pauter Rods
Subaru crank - First Gen
ARP head studs
Go Fast Parts :
ATP GT3071 IW
APS - Inlet
GT-Spec Up-Pipe
Grimmspeed ported exhaust manifold and hi flow cross over pipe
HM catted downpipe
Megan Catback V2
Turbo Smart Recirc BOv
KS Tech 73mm intake
KS TGV delete
FMS Front Mount Intercooler
Aeromotive Fuel rails - custom lines
DW Drop in pump
DW 740 side feed injectors
Motive EBCS
Grimmspeed 8mm intake manifold spacers
NKG One step colder plugs
Peterson Catch Can
Cobb Access Port
Tranny
ACT HD disk clutch
Subaru single mass flywheel
Cusco engine mounts
Motul tranny/diff fluid
Suspension
Kartboy endlinks
AVO rear stabilizer mount brace
AVO Rear and front LCA bushings
Interior
JCS cubby pod - 2 52mm center storage pod
AEM - Analog Oil pressure
AEM - Analog Boost pressure gauge
Exterior
ebay lip
STI specs
2008 STI
Engine
New Tune 505whp/470wtq @ 28psi
704 - Casting Block
JE Forged Piston Set 99.5
Subaru ring set/custom oil ring expander to fit 2.5mm
ACL/Cosworth Bearings
GSC Stage 2 Camshafts
GSC Dual Springs - Ti retainers
Heads - Ported/Blended the seats, Radiused Exhaust seats
Gates Racing Timing Belt
Killer B Ulitmate Oil Pickup tube
Kill B oil baffle
Killer B oil pan
New 2008 STI oil pump
OEM head gaskets
Manley H Beam Rods
ARP head studs
ARP case bolts
Tomei Timing Belt Guide
Go Fast Parts :
My favorite. Hill's pro tune from Agile Auto
Agile Auto Custom Rotated kit Full V-Band
HTA GT3076 with .82 Tial Hotside
GT-Spec Unequal Length Headers fabbed up with a V-Band Flange
Turbo Smart 50/50 BOV welded on
44mm Tial external gate
Aquamist HFS-6 50/50 Mix
Custom -4AN Stainless Steel Lines/Fragola Fittings Meth Lines
Howerton Engineering 2 gallon Twin Tank Enclosure
Perrin Front Mount Intercooler
Fuel Lab FPR - older STI Fuel Pulse Dampners
Aeromotive Fuel rails/Fittings -8AN/-6AN
Aeromotive 340 In-tank pump
Injector Dynamics 1,000cc Injectors
P&L 3.5 bar map sensor adapter- AEM 3.5 bar map sensor
Grimmspeed Intake Manifold Black
Grimmspeed TGV delete
Grimmspeed EBCS
Invidia N-1
P&L AVCS line
Peterson Catch Can
Mishimoto Radiator
Cobb Access Port
Perrin pulley
Brad Penn 20w-50
Napa Gold Filter
Motul tranny fluid
Motul rear diff fuild
Taylor Batter Relocation Kit
Tranny
ACT sprung six puck
Beatrush tranny/engine mounts
Torque Solution Drive Shaft Bushings
AVO Tranny Bushings
Whiteline rear diff bushings
Stainless Steel Braided Clutch line
Suspension
AST 4100 Coilovers
Swift 7K Front and 8K Rear Springs
Vorshlag Camber Plates
cusco ladder bar
whiteline subframe bushings
Kartboy - front/rear endlinks
Whiteline front/rear sways 24 f 22 r
kartboy pitch stop
AVO anti lift kit
Whiteline Front A-arm bushings
Whiteline Rear Adjustable Toe Link Arms
GT - Spec trailing arms
Powerflex Rear Trailing Arm Rear bushings
Powerflex Rear Lower Arm inner bushings
factory short shifter with every tic/kartboy bushing
Brakes
DBA 4000 series Slotted Rotors Front and Rear
StopTech Pads
StopTech Stainless Lines
MOTUL 600 Fluid
Wheels
Summer
SSR TYPE F 18/9.5/40 Black
Dunlop star specs 275/35/18
ARP extended studs
Interior
Recaro SPG XL's
Alpine 9886
3 pod gauge A-pillar 52 mm
AEM -oil pressure, wide band o2 and boost.
Aquamist flow Gauge - Need to find a new mount
Exterior
painted tails
Ebay front lip
blacked out windows 20%
Front Mudflaps
Beatrush Underpanel
Spec C roof vent
2.5i 17
Find More Posts by 2.5i 17
#2: 11-30-2012, 07:38 AM
 2.5i 17
2.5i 17's Avatar
Getting Started, pulled the motor and cleaned the bay.
2.5i 17
#3: 11-30-2012, 07:40 AM
 2.5i 17
2.5i 17's Avatar
Interior
2.5i 17
#4: 11-30-2012, 07:41 AM
 2.5i 17
2.5i 17's Avatar
Case split
2.5i 17
#5: 11-30-2012, 07:45 AM
 2.5i 17
2.5i 17's Avatar
Heads done -
Subaru Springs from 08 STI - 08 STI retainers (subaru updated the springs and use much lighter retainers now) Wanted OEM for long haul
2.5i 17
#6: 11-30-2012, 07:49 AM
 2.5i 17
2.5i 17's Avatar
Case halves are back together. I will post pics soon of that. We went with Pauter rods, 99.5 Manley pistons, oem crank and acl bearings. I went with Manley pistons since this is more of a OEM style build, I didn't want to go with with full kill FSR JE pistons. The Manley pistons have more skirt area and are coated.
I'm also going with ARP head studs, a covert pickup and 08 sti oil pump. New gates timing assembly as well.
2.5i 17
#7: 11-30-2012, 07:52 AM
 BoozeRS05
BoozeRS05's Avatar
Car: RBP LegacyGTL Wagon 5mt
Send a private message to BoozeRS05 Find all posts by BoozeRS05 Reply With Quote
There's nothing 2.5i about either of your Subarus..
ABP LGT, AW STi & RBP LGT Wagon
BoozeRS05
Find More Posts by BoozeRS05
#8: 11-30-2012, 07:57 AM
 2.5i 17
2.5i 17's Avatar
Rather than wonder when the tranny will blow (hopefully I will get some miles out of it), I'm looking at either a 6speed swap or some Albins gears. Looks like some guys are putting down a lot more power than I will and they are running strong. I don't plan on tracking this car so as long as my wife doesn't drop the clutch racing red lights, it should be good!
2.5i 17
#9: 11-30-2012, 07:59 AM
 2.5i 17
2.5i 17's Avatar
haha, trying to stay sleeper.
2.5i 17
#10: 11-30-2012, 07:59 AM
 Firepuma
Firepuma's Avatar
Car: 05 lgt wagon stage 4 332/380 wheel
Send a private message to Firepuma Find all posts by Firepuma Reply With Quote
Keep it coming-
Firepuma
Find More Posts by Firepuma
#11: 11-30-2012, 09:10 AM
 racso_dor
racso_dor's Avatar
Car: 2005 Legacy GT
Send a private message to racso_dor Find all posts by racso_dor Reply With Quote
niceeeeeeeeeeee more pics!!!
racso_dor
Find More Posts by racso_dor
#12: 11-30-2012, 09:19 AM
 Geoff400
Geoff400's Avatar
Car: 05 Wagon
Send a private message to Geoff400 Find all posts by Geoff400 Reply With Quote
Nice
Geoff400
Find More Posts by Geoff400
#13: 11-30-2012, 09:32 AM
 2.5i 17
2.5i 17's Avatar
Originally Posted by Firepuma View Post
Keep it coming-
Will do!
Will try and get some more up this weekend of the progress
Originally Posted by Geoff400 View Post
Nice
Thanks!
2.5i 17
#14: 11-30-2012, 10:40 AM
 2.5i 17
2.5i 17's Avatar
Forgot I had two other pictures up. Front Mount Progress.
Valve covers, I also painted the TGV and the catch can the same.
2.5i 17
#15: 11-30-2012, 02:00 PM
 thisisthenewsic
thisisthenewsic's Avatar
Car: 05 legacy gt.
Send a private message to thisisthenewsic Find all posts by thisisthenewsic Reply With Quote
28psi on a non sleeved 2.5l block???? what gas are you running through it???
thisisthenewsic
Find More Posts by thisisthenewsic
