Reload this Page Radio is on but has no sound
#1: 10-02-2011, 03:52 PM
 rosie
Send a private message to rosie Find all posts by rosie Reply With Quote
My radio has no sound. Everything else works when on. I checked all the connections behind the radio - no problems. What's wrong?
rosie
Find More Posts by rosie
#2: 10-02-2011, 04:26 PM
 biketowork
biketowork's Avatar
Car: 2009 Legacy Special Edition
Send a private message to biketowork Find all posts by biketowork Reply With Quote
Could be the amp. Did you check under your passenger seat?
biketowork
Find More Posts by biketowork
#3: 10-02-2011, 05:17 PM
 rosie
No, what should I look for?
rosie
#4: 10-02-2011, 06:25 PM
 biketowork
biketowork's Avatar
If your car has the amp, it will ba a black box under the passenger seat. You can see it by moving the passenger seat forward and looking in from the rear seat.
The wiring for it goes in in the front, which makes me think that someone may have shoved something under the seat from the front and knocked a wire loose there. Move the seat all the way back and use a flashlight to check the connections there.
ID:	106253   Click image for larger version
biketowork
#5: 10-02-2011, 07:28 PM
 rosie
Thanks for the photos. Is the amp obvious to see? I had to really look under the seat with a flashlight - my hand barely fits. Whatever cables are there seem to be connected.
rosie
#6: 10-03-2011, 09:23 PM
 sixstarslegacy
Car: 2008 Legacy
Send a private message to sixstarslegacy Find all posts by sixstarslegacy Reply With Quote
i had the same problem with my 08 legacy 2.5 2 weeks ago. i just bought a new stereo from crutchfield.co and its waaaay better than the stock.
sixstarslegacy
Find More Posts by sixstarslegacy
#7: 12-09-2012, 11:15 PM
 reimond
reimond's Avatar
Send a private message to reimond Find all posts by reimond Reply With Quote
Any answers on this? I have an 07 LGT, my radio displays perfectly as if its working, switches between radio stations, climate control works, turns on and off, but I get absolutely no SOUND! I have an OEM sub as well. Any ideas?
reimond
Find More Posts by reimond
#8: 12-10-2012, 05:19 AM
 specialB
specialB's Avatar
Title: Contributing V.P.
Car: GT Spec.B #449, VF52 cornfed
Send a private message to specialB Find all posts by specialB Reply With Quote
Did your try unplugging it and plugging it back in again? Seriously disconnect the battery and reconnect
Sent from my DROID RAZR using Tapatalk 2
specialB
Find More Posts by specialB
#9: 12-13-2012, 07:42 PM
 claymore_6r
claymore_6r's Avatar
Car: 08' SWP GT, 96' Concord, 00' 2.5rs
Send a private message to claymore_6r Find all posts by claymore_6r Reply With Quote
if that don't work..Check the fuse.
claymore_6r
Find More Posts by claymore_6r
#10: 12-17-2012, 08:07 AM
 reimond
reimond's Avatar
Yea... I've checked all fuses and disconnected/reconnected the battery 2x.
reimond
