Reload this Page Strange rear end leak
Page 1 of 5 1 23 > Last »
#1: 12-02-2008, 06:28 AM
 rodan
rodan's Avatar
Car: '06 'Busa '92 Miata '05 Vette
Send a private message to rodan Find all posts by rodan Reply With Quote
I have a leak, which I believe is from the rear diff, but I can't tell where it's coming from, and am wondering if anyone else has experienced anything similar....
Oil is dripping off the rear diff crossmember on the passenger side, but the entire diff (front and rear seals, and fill) is dry. I've looked under the car with flashlight and inspection mirror, and I can't find where the oil is coming from. It's almost as if someone squirted oil up into the crossmember, but I know that's not possible...
Anyone experience something like this?
rodan
Find More Posts by rodan
#2: 12-02-2008, 08:54 AM
 Ridgeracer
Ridgeracer's Avatar
Car: LGT w/ now OpenSource Mikeyd & MeTuned
Send a private message to Ridgeracer Find all posts by Ridgeracer Reply With Quote
The diff isn't completely fill with oil. Normal service level is only up to the lower part of the fill port in the rear of the assy. Have you confirmed that it's diff fluid and not a brake line.?
Ridgeracer
Find More Posts by Ridgeracer
#3: 12-02-2008, 09:40 AM
 underpowerd
underpowerd's Avatar
Title: HEET Miser
Car: 05 OBP LGT 5EAT UL +PE1818F/20 +HFS-6
Send a private message to underpowerd Find all posts by underpowerd Reply With Quote
cv boot?
underpowerd
Find More Posts by underpowerd
#4: 12-02-2008, 09:51 AM
 Silverstar
Silverstar's Avatar
Car: BRZ 6MT in Sterling Silver
Send a private message to Silverstar Find all posts by Silverstar Reply With Quote
I too have had a strange rear end leak, but only after eating at White Castle.
Tough to say what it is, check all your fluids and see what it low. Top it off, then monitor.
Silverstar
Find More Posts by Silverstar
#5: 12-02-2008, 09:56 AM
 g2redgsr
g2redgsr's Avatar
Car: Silver LGT Limited! STG-2
Send a private message to g2redgsr Find all posts by g2redgsr Reply With Quote
g2redgsr
Visit g2redgsr's homepage!
Find More Posts by g2redgsr
#6: 12-07-2008, 12:20 PM
 rodan
rodan's Avatar
OK, finally got around to getting some pics...
This just baffles me, as there is no place for the oil to come from.
In the first pic, you can see the mounting x-member for the diff on the passenger side. The clean area is where the oil gathers.
Here's a shot from below:
As you can see, the front seal, rear cover, and both CV joints are dry (except for some spatter from the x-member on the passenger side):
Does anyone know if the bushings in the x-member mount have some kind of damping oil in them??
This is where it appears the fluid is coming from, but it just doesn't make any sense! EVERYTHING except for this bushing and the x-member is dry... there are no lines running above this and the x-member is dry on top, as is the entire diff housing.
I'm going to have it in to the dealer for an oil change on Tuesday, and I'll show them what's going on and see if they have any ideas... has anyone experienced this problem?
This is driving me a little nuts!
rodan
#7: 12-07-2008, 12:37 PM
 CTATV
CTATV's Avatar
Title: No, I am a Meat Popsicle
Car: 06Spec.B Stage 3, VF52 coils STi tranny
Send a private message to CTATV Find all posts by CTATV Reply With Quote
have you been eating those chips with olean in them? they had warnings about anal seepage... rear end leak?
CTATV
Find More Posts by CTATV
#8: 12-07-2008, 12:40 PM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
That is very strange. Are you sure it is oil?
Wipe it off and see if it comes back.
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
#9: 12-07-2008, 02:19 PM
 g2redgsr
g2redgsr's Avatar
check everything in line with it ahead of where its leaking because if somethings leaking ahead of it and your moving at 55+ mph it will be hitting that because of the wind, just an idea.
g2redgsr
#10: 12-07-2008, 02:57 PM
 rodan
rodan's Avatar
I did wipe it off, and it came back...
Everything ahead of it is dry. You can clearly see the spatter behind the x-member, but there's nothing in front of it.
I don't eat chips with olean, nor do I have any personal 'leakage' problems...
It's almost as if someone's playing a joke, squirting some oil up there...
rodan
#11: 12-08-2008, 12:20 AM
 underpowerd
Title: HEET Miser
sure looks like diff fluid -- does it smell like it? how is your diff fluid level acting, is the 'leak' fast enough that it would be noticable on the stick? possible hidden crack in the housing where it bolts up to the x-member?
underpowerd
#12: 12-08-2008, 05:37 AM
 SeeeeeYa
SeeeeeYa's Avatar
Car: 2014 Forester XT Touring
Send a private message to SeeeeeYa Find all posts by SeeeeeYa Reply With Quote
What it looks like to me.
SeeeeeYa
Find More Posts by SeeeeeYa
#13: 12-08-2008, 06:23 AM
 rodan
rodan's Avatar
I've checked all around the bolt to the x-member, and if that's where it's coming from, it's leaking through the bolt itself. The top of the x-member is dry.
I don't think it's someone playing a prank. The car is just not accessible for that...
rodan
#14: 12-08-2008, 06:33 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
Check to see if there is a small crack in the rear diff housing in the area of the wetness. ther is no other place oil to come from in that area of the car. so either there is a crack and oil is leaking out, or its a prank.
whitetiger
Find More Posts by whitetiger
#15: 12-08-2008, 06:34 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
you should be able to remove that diff support with ease so you can take a closer look at the rear diff housing in that area.
whitetiger
Similar Threads
how to fit Brembo + R180 rear end on BP/BP + BE supermoose Suspension/Brakes 5 05-22-2011 07:22 PM
Wagon rear fog lamp install unclemat Walkthroughs :: Performance Modifications 21 03-18-2011 08:38 PM
new AVO rear stabilizer bar apexjapan Suspension/Brakes 9 06-18-2008 12:18 AM
AVO's own rear stabi bar for the Legacy and Outback! apexjapan Vendor News 40 10-21-2006 05:25 PM
new 18"wheels and rear end pinging geddyup Wheels/Tires 7 11-02-2005 08:19 PM
