Reload this Page Twinscroll VF36/GT2871 hybrid dyno tune results
#1: 12-20-2009, 07:16 PM
 unclemat
Title: Twinscroll troll
Car: 05 LGT wagon 11MT
Send a private message to unclemat Find all posts by unclemat Reply With Quote
Ok, so I finally decided to take the car for a dyno tune at EFI Logics. Car was previously road tuned by a friend with excellent results, but Chris was able to extract some more power and make the car feel smoother. Btw, he is an excellent tuner and provides great customer service. Highly recommended.
Relevant mods: VF36 twinscroll ball-bearing turbo w/GT2871 compressor wheel (same wheel as in AVO380) w/15 lbs. AVO wastegate actuator, JDM STI twinscroll EL headers/uppipe, AVO catted downpipe, Perrin Y-mid with extra straight-thru Mangaflow muffler welded in, STI quad-tip cans, AVO CAI, Perrin inlet, 08 STI intake manifold/TMIC, TGV deletes, DW 740cc injectors, AVO fuel pump, Prodrive BCS. 08 STI 6MT transmission - 4th gear pulls on the graph.
The numbers are not too impressive, although this is not an optimistic dyno (stock STI puts 240 whp on it) - 292 whp peak (note the graph is corrected, it put 310 whp uncorrected, but it was pretty cold day, probably less than 40F in the dyno bay), but the power band is really nice. The car responds incredibly quickly and is a hoot to drive. Chris said something is holding the turbo back, likely restrictive exhaust (I wanted to swap the quad-tips for stright-thru Prodrives, but didn't have time to do it).
Dotted lines are the baseline, solid lines are the final tune.
The info has been also uploaded into their dyno database.
Comparison with 2008 SpecB stock (comparision should be made with SpecB because of the 6MT tranny):
And versus EFI's shop stage II SpecB:
And a comparison vs. an AVO380 on a 09 WRX (not clear what intercooler it used):
Check my for sale threads: rear axles, other stock parts
unclemat
Find More Posts by unclemat
#2: 12-20-2009, 07:24 PM
 Darkness of Death
Darkness of Death's Avatar
Title: Black Magician
Car: 11 second B Spec
Send a private message to Darkness of Death Find all posts by Darkness of Death Reply With Quote
that's not bad. the dyno i pulled on, an STi pulls only 198whp
why didnt' you pull on 3rd?
Darkness of Death
Find More Posts by Darkness of Death
#3: 12-20-2009, 07:29 PM
 unclemat
With the 6MT gearing typically the 4th gear is used in dyno tuning.
unclemat
#4: 12-20-2009, 07:43 PM
 Darkness of Death
i think my pulls were with 3rd (6mt)
Darkness of Death
#5: 12-20-2009, 07:45 PM
 JoeFromPA
JoeFromPA's Avatar
Car: 06 Civic SI, 08 LGT 5-spd
Send a private message to JoeFromPA Find all posts by JoeFromPA Reply With Quote
Looks like a beaut UM. It's showing peak torque hitting at ~3200 rpms....how big is this turbo compared to the JDM LGT twinscroll?
If I'm reading you right, you are hitting 300 whp on a twinscroll BB turbo with, essentially, an opened up exhaust, better inlet, CAI, and fuel support. No upgraded intercooler, pump gas.....?
Really nice.
Joe
JoeFromPA
Find More Posts by JoeFromPA
#6: 12-20-2009, 07:47 PM
 unclemat
The compressor wheel in theory is 44 lbs/min (20g size), but is limited by the compressor housing (stock VF36) and probably the exhaust housing. This is much bigger turbo than stock JDM LGT, even without the upgraded wheel. The stock wheel is VF39/VF52 size.
This is pump (93) gas. It has upgraded intercooler - 08 STI intake manifold and 08 STI stock intercooler.
unclemat
#7: 12-20-2009, 08:21 PM
 ScoobySTi07
ScoobySTi07's Avatar
Title: King Shenanigan
Car: Yeah, it was red :(
Send a private message to ScoobySTi07 Find all posts by ScoobySTi07 Reply With Quote
Great numbers man.
It seems unlikely that the mufflers are the restriction but maybe. Looking at the rest of your upgrades I'm having a tough time seeing where the restriction might be. Could be the cat. Did you go with AVO's ceramic or metal cat? Does Boston require emissions tests?
The Ridiculousness is no more But you can have your very own piece of it. **The Ridiculous Part Out.**
ScoobySTi07
Find More Posts by ScoobySTi07
#8: 12-20-2009, 08:23 PM
 unclemat
Metal cat. But it's close to the turbo, so maybe that's not helping. I'll swap the muffers and have it retuned (also with alcohol injection, so we will see).
unclemat
#9: 12-20-2009, 08:40 PM
 ScoobySTi07
The metal cat is the higher flowing of the two but yeah you could still be seeing some back pressure build up especially with where AVO put the cat.
Have fun with the meth. Just don't blown anything up.
ScoobySTi07
#10: 12-20-2009, 08:41 PM
 unclemat
Built engine + 6MT + ACT clutch. Should take it...
unclemat
#11: 12-20-2009, 08:49 PM
 ScoobySTi07
Should is always a fun word.
ScoobySTi07
#12: 12-20-2009, 10:03 PM
 LittleBlueGT
LittleBlueGT's Avatar
Title: RS4 killer
Car: 05 Atlantic Blue non-limited GT MT
Send a private message to LittleBlueGT Find all posts by LittleBlueGT Reply With Quote
I am in for some road logs, I can learn more form them.
If you want to check back pressure in the exhaust, you can do it for about $20.
Get a MPT - barb hose adapter, some heat resistant hose, and a cheap pressure gauge (up to 15 psi for good resolution).
Then run the hose through an open window, in the car have the gauge, in the DP (where the O2 sensor would normally go) thread in the adapter.
Quickly go out and do a WOT run. I did this, and got in about 5 WOT runs before the heat killed the gauge. At WOT above about 4000 rpm my relative pressure in the DP was 4-5 psi. It was pretty consistent.
I don't know if that is good or bad, but it gives you a starting point.
Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!!
LittleBlueGT
Find More Posts by LittleBlueGT
#13: 12-20-2009, 10:35 PM
 f1anatic
f1anatic's Avatar
Title: Das Cruise Meister
Car: Legacy GT spec C & Forester XP
Send a private message to f1anatic Find all posts by f1anatic Reply With Quote
very nice numbers...and i bet no noticeable lag.
f1anatic
Visit f1anatic's homepage!
Find More Posts by f1anatic
#14: 12-21-2009, 07:35 AM
 unclemat
No, no lag, really, this thing flies. Full boost at ~2900k rpm in 4th. Even in 2nd or 3rd, punching it at 3k makes it take off right away.
unclemat
#15: 12-21-2009, 07:55 AM
 unclemat
Thanks. For some time I was thinking about getting exhaust backpressure tester. Just ordered
one
one one
, we'll see what it reads.
unclemat
Similar Threads
VF40 18g dyno results collegemt Tuning 81 08-23-2009 11:30 AM
Dyno Tune Results djseth@mac.com Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 16 05-28-2008 11:10 AM
FS in WA: TXS UTEC w/ DYNO stage 2 tune from PDX team23jordan Member Classifieds - ARCHIVE 21 08-13-2007 11:52 AM
LGT Dyno Results ShaggyGT Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 9 12-05-2004 09:06 PM
