Go Back   Subaru Legacy Forums > Technical Forums > Transmissions
Reload this Page 5EAT TCU Reset w/FreeSSM
#1: 02-27-2013, 08:33 AM
 FunkyMonkey
FunkyMonkey's Avatar
Car: 05 LGT
Send a private message to FunkyMonkey Find all posts by FunkyMonkey Reply With Quote
I saw several posts on this put I want to just make sure I am doing this correctly.
1. Connect cable to car
2. Configure cable with FreeSSM
3. Select Transmission
4. Select "Clear Memory 2"
5. Drive car, car relearns shift points.
IS THIS CORRECT ?
THANK YOU
FunkyMonkey
Find More Posts by FunkyMonkey
#2: 02-27-2013, 08:37 AM
 laff79
laff79's Avatar
Title: Big Ern
Car: '05 ABP Legacy GT
Send a private message to laff79 Find all posts by laff79 Reply With Quote
Yes. For the first few miles, do some WOT driving. Really beat on it for a bit. I was told that putting in sport mode and manually going through the gears shifting at 5-5500 also does the trick.
laff79
Find More Posts by laff79
#3: 02-27-2013, 01:04 PM
 FunkyMonkey
Car: 05 LGT
I have also heard to clear memory 1 ? What does that do ?
FunkyMonkey
#4: 02-28-2013, 08:06 PM
 nimrod685
nimrod685's Avatar
Car: 08' LGT
Send a private message to nimrod685 Find all posts by nimrod685 Reply With Quote
Sayyyyy whaaat? I guess I need to do some research on this. Been having tranny problems not sure what they are
nimrod685
Find More Posts by nimrod685
#5: 03-15-2013, 10:51 AM
 notthesnail
notthesnail's Avatar
Car: 2006 Legacy GT Wagon Ltd
Send a private message to notthesnail Find all posts by notthesnail Reply With Quote
Memory 2 is all you need to clear. You'll experience slipping and slam shifts as it learns. Drive as many different scenarios as you can (city, highway, fast, slow, aggressive, meek, full auto, sport, manual).
The Following User Says Thank You to notthesnail For This Useful Post:
laff79 (03-16-2013)
notthesnail
Find More Posts by notthesnail
#6: 03-16-2013, 07:02 AM
 FunkyMonkey
Car: 05 LGT
Perfect. I did mem2 only. Its shifting better. Thanks
FunkyMonkey
#7: 03-16-2013, 10:46 PM
 volodyalysak
volodyalysak's Avatar
Car: 2005 Subaru Legacy GT Limited
Send a private message to volodyalysak Find all posts by volodyalysak Reply With Quote
What if i disconnect battery and step on brakes ? Will this reset tranny as well as the ECU ?
I have harsh shifts when cold from 1-2 2-3 . When it warms up to operating temperature it is smooth.
volodyalysak
Find More Posts by volodyalysak
#8: 03-20-2013, 09:18 AM
 notthesnail
Power loss should not reset the learned codes in the TCU. Once you do reset the codes, there are two re-learn options: Natural (described above), and Programmed, which has you manually rowing through the gears at prescribed throttle angles. Post 40 of another recent thread has this procedure in detail.
notthesnail
#9: 03-29-2013, 07:32 AM
 Joeboo98
Send a private message to Joeboo98 Find all posts by Joeboo98 Reply With Quote
I just got my '05 GT and I have found that when I am driving it that when I am stopped for a light or something that the car is still trying to go. I don't know if I do a reset on the TCU if that would fix that problem or if it would be a different problem. I just got a Cobb Accessport for the car. I haven't played with that yet but can you do the reset on the TCU with the accessport or what do I need to connect to the car to reset the TCU.
Joeboo98
Find More Posts by Joeboo98
#10: 03-30-2013, 06:40 AM
 volodyalysak
So you saying, that you have to press brakes harder to keep it from rolling ? I have the same issue, and i think it is throttle position sensor or gas pedal sensor. Mine is +7% at idle. Try to lift your gas pedal UP while at stop light, and see if something changes.
volodyalysak
#11: 03-30-2013, 09:07 AM
 Joeboo98
I will try that to see if that helps. I was just hoping it wasn't the transmission. A sensor is a easy fix then the transmission.
Joeboo98
#12: 03-30-2013, 10:26 AM
 FunkyMonkey
Car: 05 LGT
I dont think accessport has anything to do with ur TCU dude. U have to use FreeSSM to reset ur TCU, but I doubt ur issue has anything to do with TCU reset. Sounds like Accessport settings
FunkyMonkey
