Go Back   Subaru Legacy Forums > General Forums > Pre-purchase Questions
Reload this Page Performance "mod-ability" of 05-09 Legacy GT
Thread Tools
12-12-2012, 06:30 PM
Performance "mod-ability" of 05-09 Legacy GT for road racing
 Chevy Nick
Send a private message to Chevy Nick Find all posts by Chevy Nick
I'm looking for a car that I can beat "like a rented mule" on a road course and not feel bad about if I drive off track pushing it to the edge.
There seems to be a lot of potential with an 05-09 Legacy GT with turbo 2.5 motor. I intend to drive this car for 30 minutes at a time on a road course. I have a couple of general questions:
  • Brakes - are there serious track/race brake setups available? race brake pads, big brake kits, brake cooling kits, etc...
  • Suspension - are there serious suspension parts for road racing available?
  • Transmission/driveline durability - I have heard the WRX 5 speed transmissions are very fragile and can break easily. Are legacy transmissions more robust?
  • Engine power potential - I have also heard you can add bigger injectors, intercooler, up the boost to make really good power on these motors. Are these 2.5 turbo motors easy to mod and reliable at 300+hp?
  • Legacy B-spec: Are these cars worth the extra money? or while I just be removing those parts anyway?
Chevy Nick
Find More Posts by Chevy Nick
12-12-2012, 06:32 PM
 blongo804
blongo804's Avatar
Car: 05 Kinugawa TD06SL2/18g 5EAT
Send a private message to blongo804 Find all posts by blongo804
After I read the first line of this thread, I must say you should look into a different vehicle.
/thread
The Following 6 Users Say Thank You to blongo804 For This Useful Post:
andnyleswillriot (12-17-2012), compsurge (12-12-2012), Daniels (12-14-2012), fishbone (12-18-2012), liljonson (12-14-2012), Whatisit (12-14-2012)
blongo804
Find More Posts by blongo804
12-12-2012, 06:42 PM
 Dujo
Dujo's Avatar
Car: 1 of 99 2005 ABP/Tpe LGT Ltd 5MT Wagon
Send a private message to Dujo Find all posts by Dujo
You can get serious brakes for the LGTs, but you need to get larger wheels to fit them into. Brembos and such do not fit in the stock wheels, but there are bbks that fit if you get at least 18s.
There are some pretty decent coilover options in the more expensive range (teins, etc) or you can get cheaper coilovers for that track car handling with the track car ride. There are also all manner of little bits like roll center kits and bushing replacements. There are sway upgrades as well. Pretty decent options.
The stock 5MT is not a strong transmission. It can reasonably hold 275 to 300 awhp and that's about it. Upgraded clutch and flywheel will help that a fair bit, but if you really want the good tranny, you need to do a 6MT swap from a later year.
The EJ255s are generally considered to be a pretty stout motor. You can get that sucker over 500 with forged internals and the proper supporting mods. Stock internals can handle 300+ (at the wheels), but probably not a lot more than 350.
Spec.Bs are nice. I forget the list of upgrades, but you would probably be swapping most of them out. Get a GT and figure out which Spec.B parts you need if you need them (aluminum lower control arms instead of steel, etc). Don't pay the premium and waste your time on the hunt for a spec.b for a track car.
In the end, a WRX would probably be a better choice.
Enjoy! Welcome to LGT.com.
I have no idea what I am talking about.
Dujo
Find More Posts by Dujo
12-12-2012, 06:47 PM
 Dujo
Dujo's Avatar
Take a look at this to see the power potential (great post/thread): http://legacygt.com/forums/showthrea...st-178684.html
The Following User Says Thank You to Dujo For This Useful Post:
Dujo
12-12-2012, 06:55 PM
 compsurge
compsurge's Avatar
Car: '05 5MT ABP LGT wagon
Send a private message to compsurge Find all posts by compsurge
SUSPENSION
-AST 4100 ($2600) or Racecomp Tarmac 1 coilovers ($2000)
-Full swaybar, endlink and bushings setup $700
BRAKES
-Brembo Swap ~$1200+ for rebuilt calipers, pads, fluid, lines, relocation brackets, rotors
TRANSMISSION
-Don't shock load it or launch it and it will last you a long time (new fluid ~$60-70)
ENGINE
- Stage 2 open source tune $150
- Stage 2 supporting mods (High Flow Catted downpipe, 3" to 2.5" adapter, gaskets) - $400
- TMIC bulletproof mod or stock setup $80 - buy a Process West TMIC if going for a bigger turbo
- Might as well save for a new engine, because sooner or later, it will eat the #4 cylinder.
- Bigger turbo on stock block (Stage 3): 18g hybrid + injectors + pump $2000
- Stage 3 e-tune $200 + Wideband cost
It's a Spec.B, and only get a 6MT unit. You'll wish it had a variable center diff and front LSD.
TIRES
-$1000+
The Following User Says Thank You to compsurge For This Useful Post:
Chevy Nick (12-12-2012)
compsurge
Find More Posts by compsurge
 compsurge
compsurge's Avatar
False.
Nrw (12-13-2012)
compsurge
12-12-2012, 07:07 PM
 Dujo
Dujo's Avatar
^ My understanding was that stock 5MT was fine for stage 2, but not really stage 3. What's it good up to then, please?
Dujo
12-12-2012, 07:12 PM
 joeleodee
joeleodee's Avatar
Car: 1863 Covered Wagon Deluxe
Send a private message to joeleodee Find all posts by joeleodee
Really depends on how you drive it. A number of 350+ whp folks who run the stock 5mt without issue. They also don't dump the clutch from 4000 or more rpm every time they take off. For road course use like the OP is suggesting, I'd assume a well maintained stock 5mt would exhibit good longevity in such an application.
The Following 2 Users Say Thank You to joeleodee For This Useful Post:
compsurge (12-12-2012), Dujo (12-12-2012)
joeleodee
Find More Posts by joeleodee
12-12-2012, 07:23 PM
 compsurge
compsurge's Avatar
There are also forum users with over 400 whp on the 5MT.
The general consensus is to avoid WOT in 5th, however. On a road course, this is probably a moot point since you probably will not need to get to those speeds.
Dujo (12-12-2012)
compsurge
12-12-2012, 08:09 PM
 Chevy Nick
Thanks for the initial info everyone.
Just to confirm; Spec.B is not worth the extra cost, GT model with 5-speed is better value? more durable?
Does anyone run a 5 or 6 point harness with these cars? Aftermarket seats a problem? I've seen cars with STI seats swapped in, is that easy to do?
Chevy Nick
12-12-2012, 08:30 PM
 05wagongt
05wagongt's Avatar
Car: 2005 legacy gt wagon
Send a private message to 05wagongt Find all posts by 05wagongt
If you want all that, for using and abusing at the track, just get an sti
The Following 2 Users Say Thank You to 05wagongt For This Useful Post:
doccrowley (12-12-2012), stanjk3 (12-18-2012)
05wagongt
Find More Posts by 05wagongt
12-12-2012, 09:09 PM
 compsurge
compsurge's Avatar
You should look at an IROC Camaro with an LS and T56 swap with suspension if you want a beatable track car. Maybe.
compsurge
12-13-2012, 07:55 AM
 Chevy Nick
I need a wagon or something that is practical for hauling stuff. I already have a dedicated track car for speed, just looking for something practical, fun, and affordable.
Chevy Nick
12-13-2012, 07:58 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Car: 2013 NC3 CLUB, 05 OB 3.0R
Send a private message to whitetiger Find all posts by whitetiger
if you want to "beat the car like a rented mule" then the 6mt in the spec be is preferable. It will take launching better. the 5mt can hold 300+ whp but it cant take the shock of launching the car at high tq levels like the 6mt can. trust me.
and if you want road race suspension, i have a set of AST's for sale.
4-Time NNJR ESP Season Champion -15 ESP
3rd Place in 09' Pax Championship/Driver of the Year
2012 Northeast Divisional Champion in ESP
whitetiger
Find More Posts by whitetiger
12-13-2012, 08:00 AM
 underground000
underground000's Avatar
Title: Bus Wanker!
Car: 08 LGT
Send a private message to underground000 Find all posts by underground000
Theres a reason why SRRT (subaru road racing team) went from a SpecB to an STi for racing and they're doing a lot better in the STi
5eat downshift rev match
Powder coated wheels: completed
underground000
Find More Posts by underground000
Thread Tools
