Reload this Page Review my blown turbo shortblock replacement plan
#1: 12-05-2012, 12:16 PM
 pikandchute
Send a private message to pikandchute Find all posts by pikandchute Reply With Quote
I picked up a 2005 LGT with a blown turbo, 180k for cheap. The car was running smoothly when I bought it but making no boost. I pulled the turbo, and both turbine and compressor are damaged. I found metal flakes in the oil, then pulled the pan and found more metal flakes in the pan. Between the extensive damage to the turbo, knowing that the car was driven for at least 100 miles or so with blown turbo, and the metal flakes, I have decided that I need a new short block.
Here is what I am planning on buying for the motor:
Used 07 STI EJ257 short block, 11k miles, includes water pump - pulled from a totaled STI
2 new idlers, new tensioner, new timing belt
New oil cooler
New oil pump or rebuild using my current pump housing
New cam seals and valve cover gaskets
040 thickness head gaskets (I believe this will lower the EJ257 compression from 8.4:1 to about 8.1:1. With resurfaced heads, I'm hoping this will leave me pretty close to stock 8.2:1 compression)
My plan is to take the replacement short block with the parts listed above to a machine shop along with the current long block. I will have them disassemble the current long block, rework current heads as needed, and reassemble on the replacement short block. The cylinders compression tested within 5psi and motor ran smoothly, so I'm hopeful that heads are still OK. I will also thoroughly clean my current oil pan and intake manifold.
In addition to the motor itself. I will get the following:
New oil feed line and drain tube - considering IP&T oil feed
Used Catless uppipe
New turbo inlet
Used stock intercooler
Examine clutch and replace if needed
New turbo - I am still deciding, but I don't want to make this discussion about turbo selection or supporting mods. I know that it will be VF52/16g or smaller (possibly stock) and that I will initially run stock fueling, intercooler, clutch, and downpipe with custom, safe tune.
Is there anything I'm missing or general feedback on this plan?
pikandchute
Find More Posts by pikandchute
#2: 12-05-2012, 02:29 PM
 mattg
mattg's Avatar
Title: Brass Monkey
Car: '05 Limited 5MT Stg 3+
Send a private message to mattg Find all posts by mattg Reply With Quote
I think most people would suggest using an aftermarket oil pickup as the OEM part can fail. Killer B, Moroso & one other company make one I believe.
mattg
Find More Posts by mattg
#3: 12-05-2012, 04:38 PM
 Max Capacity
Max Capacity's Avatar
Here's my thread, it may help.
http://legacygt.com/forums/showthrea...-r-184106.html
Let the machine shop clean the oil pan and all parts that the oil touches.
Max Capacity
#4: 12-06-2012, 11:58 AM
 pikandchute
Thanks for the feedback guys. I ended up locating a 2012 WRX longblock, uppipe, intercooler, turbo inlet, and bpv and decided to go that route. I will look into the Killer B pickup and have the oil pan professionally cleaned as I don't won't to take any risks with the new block.
Plan now is to locate a VF52 to match the WRX longblock, copy over the tables from a WRX ECU and tune from there.
pikandchute
#5: 12-06-2012, 12:05 PM
 700watts
700watts's Avatar
Car: racer-x is faster + 00 4Runner (dogs)
Send a private message to 700watts Find all posts by 700watts Reply With Quote
the only thing I can say is, you'll out grow that turbo pretty quickly...I would suggest a larger turbo and low boost. If your spending the money spend a little more and not have to come back to that.
700watts
Find More Posts by 700watts
#6: 12-07-2012, 03:55 AM
 wurkenman
wurkenman's Avatar
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
I have a used TMIC off my 05 LGT when I did my full STI build. I went with FMIC. Intercooler is your for 60 shipped.
Tery
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
wurkenman
Find More Posts by wurkenman
#7: 12-07-2012, 08:34 AM
 2manysubies
2manysubies's Avatar
Car: '13 BRZL,05 LGTL Stg3+,05 LGTLW+3 subies
Send a private message to 2manysubies Find all posts by 2manysubies Reply With Quote
+1 for 700watts turbo idea. Live with the slower spool(bigger turbo) and drive the car first, if ya gonna play, keep it in a lower gear, Recommend EBCS as it lets turbo spool faster(at least in mine) my .02
Mac
Later on have your tuner bump it up! (trust me, you will!)
2manysubies
Find More Posts by 2manysubies
#8: 12-12-2012, 12:02 PM
 ripemeat
Title: Banned
Car: Saxual content
07 sti pistons are notorious, it's a pretty well-known thing on nasioc. if you're going to split the block it would be well worth replacing with quality forged units....even if your compression is fine now.
ripemeat
Find More Posts by ripemeat
#9: 12-12-2012, 12:42 PM
 mwiener2
mwiener2's Avatar
Title: Trunk Monkey Chief
Car: 2005 Rocketback, 2010 Clown Car
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
Hear this all the item on forums and from vendors. Never hear about it from actual shops or personal experience.
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
mwiener2
Find More Posts by mwiener2
#10: 12-13-2012, 01:36 PM
 m sprank
m sprank's Avatar
Title: Vendor III
Send a private message to m sprank Find all posts by m sprank Reply With Quote
I have seen the OEM pick ups fail. I have posted pix of failed OEM pickups I removed. I even personally know a pilot who used an EJ25 engine in a home made gyro copter. His pick up failed at 300ft elevation. Scary experience having to crash land when your motor oil starves.
It does not happen all the time, but it happens.
m sprank
Find More Posts by m sprank
#11: 12-13-2012, 01:52 PM
 ripemeat
Title: Banned
Car: Saxual content
It's worth the extra $100, moroso, covert, and killer b make an aftermarket variant for the ej25.
ripemeat
