Reload this Page What you think?
#1: 12-25-2012, 05:48 PM
What you think?
 lowwill
lowwill's Avatar
Car: 05 OBXT 5MT
Send a private message to lowwill Find all posts by lowwill Reply With Quote
Found this leak the other day after noticing some smoke from the hood scoop. Turbo has about 13k on it. Got it from turbo kits.com for a hell of a deal. ECS performance installed it. They both share the same building in Windsor CT. It seems to be coming from the bottom oil line. That's where the most gunk seems to be. Just hope it's not a internal seal. Possible blow by? Patiance is up with this car. 05 OBXT 113k
lowwill
Find More Posts by lowwill
#2: 12-26-2012, 08:14 AM
 ripemeat
Title: Banned
Car: Saxual content
those are coolant lines. anyway, is the oil seeping from the topside banjo(oil feed)? does it smell like burned oil or coolant? it's unusual that the compressor bolt pictured is also wet. could be the compressor backing plate causing an oil leak....
ripemeat
Find More Posts by ripemeat
#3: 12-26-2012, 08:59 AM
 lowwill
lowwill's Avatar
Car: 05 OBXT 5MT
Definetly oil. The smell and smoke is the same as when my valve cover was leaking. Compressor wheel?
lowwill
#4: 12-26-2012, 09:02 AM
 ripemeat
Title: Banned
Car: Saxual content
hmm thats a tough one, I'd say snug up the top banjo as they can seep a little if not tight enough, but it looks like oil is coming from the chra to compressor housing connection. bring it back to whateverthatshopis that sold and installed it.
ripemeat
#5: 12-26-2012, 09:20 AM
 lowwill
lowwill's Avatar
Car: 05 OBXT 5MT
Just emailed them. Ill post back
lowwill
#6: 12-26-2012, 09:25 PM
 xt2005bonbon
xt2005bonbon's Avatar
Car: 05 OBXTL MT stage .25 sick of stock cans
Send a private message to xt2005bonbon Find all posts by xt2005bonbon Reply With Quote
Not a pro at this but sometimes it could be as stupid as the copper washers on the banjo bolts not doing their job properly. I know also that you are supposed to replace them with new ones once you take off a banjo bolt. Wouldn't hurt to check them out. There should be two per bolt.
Second (or first) thing I'd do is clean up the area and monitor for further leak.
xt2005bonbon
Find More Posts by xt2005bonbon
#7: 12-26-2012, 09:39 PM
 m sprank
m sprank's Avatar
Title: Vendor III
Send a private message to m sprank Find all posts by m sprank Reply With Quote
Clean the wounded area to find the bleeding.
The Following User Says Thank You to m sprank For This Useful Post:
Chris GTO TT (12-26-2012)
m sprank
Find More Posts by m sprank
#8: 12-28-2012, 06:52 PM
 lowwill
lowwill's Avatar
Car: 05 OBXT 5MT
lmao clean the area and still waiting for a leak to occure. Ill post back
lowwill
