Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Performance Modifications
Reload this Page Hornblasters Shocker in a 96 Subaru Legacy Sedan
#1: 02-20-2012, 11:22 PM
 stevenva
stevenva's Avatar
Car: 96 Fuji Heavy Industries 2.2 L Sedan
Send a private message to stevenva Find all posts by stevenva Reply With Quote
All was easy enough. Finding the appropriate switch was the most difficult. This is the switch I finally found that suited me perfectly. http://parts.digikey.com/1/parts/970...rn91-25bb.html
I like it because it mounts perfectly where the OBD2 port was. I have no need for the OBD2 since it is plugged into my Scangauge2. http://www.scangauge.com/products/scangaugeii/
The kit is from Hornblasters. The horns are the Shocker 4XL train horns.http://www.hornblasters.com/products...r-4-train-horn
Also from Hornblasters is the Viair 20005 compressor/air tank combo. http://www.viaircorp.com/OnRoad/20005.html
All plumbing, fittings ect are included. There is no wiring with the combo I chose.
These photos were taken before all of the hoses were run.
They are loud and obnoxious. Some people ask why did I get train horns for my car. I can't answer their question, but when I demonstrate them, they love it and want some too.
Name:	2 Smallest horns bolted together fire down a hole in engine bay.JPG
ID:	112865   Click image for larger version
Name:	2nd largest horn behind radiator at the bottom.JPG
ID:	112866   Click image for larger version
Name:	3rd largest horn.JPG
Name:	All horns point down to prevent water.JPG
ID:	112868   Click image for larger version
Name:	Comperssor and Tank.JPG
ID:	112869   Click image for larger version
Name:	Engine bay 2.JPG
ID:	112871   Click image for larger version
ID:	112872   Click image for larger version
Name:	obd2 plug was relocated.JPG
ID:	112874   Click image for larger version
Name:	Perforated. galvanized plumbers strap works great.JPG
ID:	112875   Click image for larger version
Name:	Switch is a perfect fit.JPG
Name:	Switch part number.JPG
ID:	112877   Click image for larger version
Name:	Switch revealed.JPG
ID:	112878   Click image for larger version
ID:	112880   Click image for larger version
ID:	112881   Click image for larger version
ID:	112883   Click image for larger version
stevenva
Find More Posts by stevenva
