10-31-2012, 03:51 PM
Tomioka turbos
Car: Blue one and a red one
I was wondering if anyone has any real world experience with them? I'm looking at either an Tomioka 18g or vf48 for my 05.
11-10-12 Purchased a Tomioka TD05-18G Pics below
11-17-12 Turbo installed Pics below
11-18-12 Turbo removed due to failure... WTF (Pics and Video added)
11-09-2012, 12:48 PM
Car: 2008 Spec-B, Infamous Tuned!!!
Nothing wrong with them but the VF48, imo. The OEM STI VF48 is almost inbetween an 18g and a 20g from I've seen. Close call, maybe just whichever is cheaper.
11-10-2012, 06:02 AM
Title: The one they love to hate
Location: INFAMOUS PRIME....I hail from the realm of SoCal
Car: 03' Z06 and 90' Honda EE
Not quite, I would say MAYBE the 16g and 18g. But on average the vf52 does better than the vf48.
11-10-2012, 12:01 PM
Went with a Tomioka for peace of mind. Not enough of a price difference to justify a buy a used turbo.
The Following User Says Thank You to Cone_Killer For This Useful Post:
11-12-2012, 06:13 PM
Car: '11 WRX sedan
Put up some pics and let us know what it puts down after install. I'm thinking of going with the same one this spring.
11-13-2012, 12:24 AM
Car: 05 Kinugawa TD06SL2/18g 5EAT
I would've went Kinugawa personally. Maybe i'm just biased though...
Which Tomioka did you get?
The Following User Says Thank You to blongo804 For This Useful Post:
11-13-2012, 03:39 PM
11-13-2012, 03:58 PM
Very nice turbo and good choice on size!
Yes my Kinugawa did require a spacer but that was included along with its adjustable wastegate actuator.
11-13-2012, 07:03 PM
The Tomioka also utilizes an adjustable actuator.
11-18-2012, 12:36 AM
Turbo went in today along with new coolant hoses, gaskets, oil drain, and replaced the oil feed filter. Some things I noticed about this "bolt on" turbo:
Compressor outlet flange bolt holes are wrong (too close together)
Right side of the compressor housing hits the crankcase pcv
Coolant return/outlet is turned 45 degrees upward, causing fitment issues
Here are some pics before the install compared to the vf46 that its replacing.
11-18-2012, 08:38 AM
We have a huge problem. After the first set of build quality problems, I should have suspected something else.... So after priming the turbo, pulling the fuel fuse and turning it over 5 times for 5 sec each and oil started coming out of the drain tube, the car was started for the first time. I let it idle for about 10-12min letting the packaging oil burn off but noticed that the smoke coming from the exhaust was far too much to be assembly oil. So I shut it down and left it in the garage overnight to try again this morning. So upon startup this morning, same thing, billowing smoke out of the exhaust. I drove it down the street (out of boost) and the only time it doesn't smoke is under continuous acceleration. It smokes while cruising and initial acceleration. My car has never once even thought about smoking. THIS TURBO APPEARS TO BE BLOWN BRAND NEW!!! Words cant even describe how pissed I am currently. I will be contacting Tomioka and Import Image Racing where this turbo was originally purchased.
11-18-2012, 09:11 AM
Wow, just wow.
11-18-2012, 09:25 AM
Originally Posted by Infamous1
Wow, just wow.
Professionally speaking, do you see any problems with my install procedure?
11-18-2012, 09:35 AM
Like I tell everyone I just tune! I only work on my own cars....But there isn't much science into installing a turbo, it's rather simple. The oil coming out of the drain hose seems like a huge fail. But you didn't go into detail. That's my only "what" concern. Which is a big one, especially once you drove it after that.
11-18-2012, 10:05 AM
I slid the rubber oil drain line up so I could see when oil was coming out of the drain. I turned the engine over without firing until oil was coming out of the drain line (just to make sure the oil had circulated through the turbo before starting). I reconnected the line and started the car.
