Reload this Page Insanely tight PCV... ??
#1: 12-16-2012, 09:37 AM
 Adoniram
Adoniram's Avatar
Title: SupremeGalacticCommander
Car: 05 LGT LTD
Send a private message to Adoniram Find all posts by Adoniram Reply With Quote
Has anyone replaced this thing successfully? How tight was it on your car? I've sprayed this thing with liquid wrench for a day, and can't get it to budge. I'm afraid if I use a breaker bar, I'll end up destroying the plastic housing that it sits in...
Adoniram
Find More Posts by Adoniram
#2: 12-16-2012, 11:48 AM
 Windy Road
Windy Road's Avatar
Title: I brick ECU's
Car: Stage 2.95 Grandpa Cruiser with Navi
Send a private message to Windy Road Find all posts by Windy Road Reply With Quote
I took mine out and put the piece in a vise. I got the PCV out of the housing but I ended up dropping the damn thing 4 feet and it broke. I would just buy the whole unit as they are cheap for the 05-06.
Windy Road
Find More Posts by Windy Road
#3: 12-16-2012, 08:15 PM
 20lgt06
20lgt06's Avatar
Car: 2007 lgt BrenTune 334whp@375wtq
Send a private message to 20lgt06 Find all posts by 20lgt06 Reply With Quote
Dito I broke mines cheap to replace the plastic
elbow
20lgt06
Find More Posts by 20lgt06
#4: 12-16-2012, 08:59 PM
 compsurge
compsurge's Avatar
Car: '05 5MT ABP LGT wagon
Send a private message to compsurge Find all posts by compsurge Reply With Quote
Replace whole unit. Is there any reason why you are taking it out?
compsurge
Find More Posts by compsurge
#5: 12-17-2012, 08:00 AM
 Adoniram
Adoniram's Avatar
Car: 05 LGT LTD
I was doing a 60k service on my car and thought it would be a good idea to replace. I did just about everything else (tranny and diff fluids, flushed brakes, replaced spark plugs, cleaned air filter, replaced AT filter, changed oil, replaced leaking valve cover gaskter, etc etc etc)
The housing looks like a pain to get out, and the hoses all seem like they're about 1 ft-lb of torque from cracking, so I'm afraid I'll have a lot more to replace than just the valve
Adoniram
#6: 12-17-2012, 10:17 AM
 compsurge
compsurge's Avatar
You don't replace the PCV unless the system is malfunctioning. It's not a service item like Honda/Mazda/etc.
Problem solved.
compsurge
#7: 12-17-2012, 11:23 AM
 Adoniram
Adoniram's Avatar
Car: 05 LGT LTD
I'm gonna go with that plan. Thanks!
Adoniram
#8: 12-17-2012, 01:55 PM
 compsurge
compsurge's Avatar
You may want to take a peek in the pcv crossover tube though for signs of oil and water condensation (take the vent hoses that go to the heads off).
You're in Texas, so I doubt this is an issue for you. Us cold weather folks have issues with this on short drives and blowby.
compsurge
