Reload this Page hissing noise
#1: 11-02-2008, 08:30 AM
hissing noise
 mazinga
Send a private message to mazinga Find all posts by mazinga Reply With Quote
So last night i hit a deer
i get home and notice the damage is actually minimal, bodywork-wise. however, the grille was toast, front of the hood looks like tinfoil, and when i shut the car off a high-pressure gas hissing noise was heard from the radiator area. however, no steam was observed, and i couldn't pin down the source.
i assumed it was my radiator, and the coolant system. i went in disgusted and figured i'd come out to a puddle of coolant in the morning.
this morning, no coolant loss, car starts ok, so i let it heat up to try and reproduce the hissing noise. i got it into normal operating temp and left it for a while, shut it off, figuring that if it was steam in the coolant system or radiator i would be able to reproduce the sound.
no sound.
question: is there some other gas besides steam from the coolant system that would've made the noise? is the radiator filled with something that could've leaked once and now is depleted?
i'd appreciate hearing from anyone with any insight on this.
thanks ahead of time.
edit: the car is a 2005 Legacy GT base model
mazinga
Find More Posts by mazinga
#2: 11-02-2008, 08:35 AM
 MGV101
MGV101's Avatar
Car: JDM 08MY Legacy 2.0GT Wagon
Send a private message to MGV101 Find all posts by MGV101 Reply With Quote
Is your AC working??
The noise could have been leaking refrigerant.
MGV101
Find More Posts by MGV101
#3: 02-26-2009, 02:44 PM
 bushbelay
Car: 1996 Legacy Wagon
Send a private message to bushbelay Find all posts by bushbelay Reply With Quote
Dang this is an old thread, but oh well.
The other night I noticed my hood wasn’t latched down all the way. I pushed it down; it latched and produced ‘the hiss’. I tried to reproduce mine as well and couldn’t. No fluid, no steam, just this hissing. I am pretty sure it was coming from the radiator. I turned my car off and it was still hissing, touched the back of the radiator and the pitch of the hiss changed.
Anyways, plan on looking at it a little more when I get some time. I think my first start will be to pressurize my system. I will update if I find anything. (mine is a 96 legacy, 2.2)
bushbelay
Find More Posts by bushbelay
#4: 03-23-2009, 09:45 AM
 bushbelay
Found it. . mine was my AC condenser.
bushbelay
#5: 12-21-2012, 11:12 PM
 shroom
Car: '06 2.5i SE 5MT wagon
Send a private message to shroom Find all posts by shroom Reply With Quote
bump.. so i scratched the front of my radiator tonight installing some aux lights. there is now a "hissing" sound coming from where i hit the front of the radiator, where there's a stream of air blowing out. im not losing any fluid, yet anyway. im seeing A/C condenser above me ^^ any other knowledge on the OEM radiator ('06 2.5i) and what I would have hit/should i drive on it if im not losing fluids/etc?
Thanks
shroom
Find More Posts by shroom
#6: 12-22-2012, 06:24 AM
 ripemeat
Title: Banned
Car: Saxual content
Find all posts by ripemeat Reply With Quote
the a/c condenser is the front-most heat exchanger on the car. engine cooling radiator does not have pressurized air in it ( ) and is behind the condenser. unless you need your a/c to work right now, there's no harm in driving it with a punctured a/c condenser.
ripemeat
Find More Posts by ripemeat
#7: 12-22-2012, 12:17 PM
 shroom
no need for a/c in WA right now. feeling like a dumbass that a) my drill bit slipped and b) i didnt know what it slipped into. thanks for the response, i had come to the same conclusion.
cheers
shroom
Similar Threads
Noise at high RPM under load around 4k?!?1 f85stealth Warranty Issues & Problems 19 08-24-2012 11:27 AM
Excessive wind noise from the windshield area due to wiper arm? Kaiser0929 Fourth Generation Legacy (2005 - 2009) 48 01-03-2009 07:51 AM
Noise from the rear suspension f1anatic Suspension/Brakes 3 05-02-2006 11:30 AM
Need opinions, Engine noise. Drakuun Fourth Generation Legacy (2005 - 2009) 36 12-08-2005 07:24 PM
2005 Windshield Wind Noise aredstripe Exterior/Aesthetic 2 03-05-2005 12:54 PM
