Go Back   Subaru Legacy Forums > General Forums > Subaru News & Rumors
Reload this Page Dealer Recall-Flashing the ECU
#1: 12-18-2012, 05:58 AM
 EdC
Car: 2011 Legacy GTL
Send a private message to EdC Find all posts by EdC Reply With Quote
I received an email from my dealer requesting I bring my car in for a factory adjustment to the ECU, This is correct coolant temperature readout.
Do you think this will affect the Cobb program installed on my ECU?
Thanks,
EdC
EdC
Find More Posts by EdC
#2: 12-18-2012, 06:59 AM
 urfsin
urfsin's Avatar
Title: 2x Rally X Champ
Car: Grocery Getter
Send a private message to urfsin Find all posts by urfsin Reply With Quote
Yes. Uninstall the Cobb then take it to the dealer...reinstall Cobb when you get home.
Slide It Sideways
urfsin
Find More Posts by urfsin
#3: 12-18-2012, 08:24 AM
 MrTris
MrTris's Avatar
Car: 05 SWP LGT 5EAT
Send a private message to MrTris Find all posts by MrTris Reply With Quote
@OP - Having the AP installed 'locks' the ECU from further writing/modification and technically voids your warranty. In order to properly fix the issue described in the TSB, your ECU needs to be writeable so that the dealer can reflash it. As was said, uninstall/un-marry your CobbAP, get the repairs done, and then reinstall the AP afterward.
MrTris
Find More Posts by MrTris
#4: 12-18-2012, 09:20 AM
 fishbone
fishbone's Avatar
Title: Smooth like Keith Stone
Car: 05 Legacy GT
Send a private message to fishbone Find all posts by fishbone Reply With Quote
Wait what?
So you take it in to the dealer, they reflash the ECU and then you wipe it and reflash it back to Cobb's tune? Unless I am misunderstanding what I am reading, you would essentially revert the dealer's changes. If you're worried about warranty issues, then proceed as outlined above. If not, sounds like a waste of time unless again, I misunderstood what is being done.
fishbone
Find More Posts by fishbone
#5: 12-18-2012, 10:27 AM
 eckseleven
eckseleven's Avatar
Car: '12 LGT 289whp/348wtq, '12 OB CVT
Send a private message to eckseleven Find all posts by eckseleven Reply With Quote
http://legacygt.com/forums/showthrea...&highlight=wqc
eckseleven
Find More Posts by eckseleven
#6: 12-18-2012, 12:30 PM
 ssbtech
Send a private message to ssbtech Find all posts by ssbtech Reply With Quote
Er.. since when? My dealer had no problem flashing the ECU when my AP was married to it. It did however prevent me from using the AP afterwards since the AP was still married to the ECU which it no longer recognized due to the flash.
ssbtech
Find More Posts by ssbtech
#7: 12-18-2012, 12:35 PM
 ssbtech
Originally Posted by fishbone View Post
Wait what?
The dealer flash may or may not overwrite the entire ECU. It may just update the coolant temp monitoring logic or it may be an entire new flash, including the tune.
Either way, it's best to uninstall the AP (unless you have mods that would cause problems without the tune) let the dealer update, then re-flash with the AP.
The AP *should* just update the "tune" and not touch the new dealer-updated coolant monitoring logic.
ssbtech
