08-18-2012, 10:08 PM
2012 Legacy GT - another strange noise issue
Hello everyone, another problem I have encountered with my 2012 Legacy GT.
When I switch gears after 3000 rpm, I hear a horn like noise. What could this be? Should I worry about it? I only have 6200+ kms on the GT. Any thoughts? Thanks
It's pretty much like nuclrxn's problem:
http://legacygt.com/forums/showthrea...ml#post3632147
08-18-2012, 10:12 PM
Take it back to the dealer for a warranty repair. Sounds like someone wired your horn to your neutral safety switch.
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
08-19-2012, 10:29 AM
Are you accelerating when this happens? It could be that dang TMIC coupler.
08-19-2012, 04:21 PM
The sound happens when I accelerate.
08-19-2012, 04:59 PM
Car: '10 LGT , '96 Outback
Sounds like what minuccims has suggested. That's my bet too.
If you don't mind working on your car yourself, it's worth checking out, fix is pretty easy.
The couplers are notorious for allowing the Intercooler to slip out of the hoses under repeated boost cycles. The fix is to remove the couplers (don't put them back on), wipe down the mating surfaces with a solvent (like CRC Throttle Body Cleaner) to remove any oily residue, then reinstall Intercooler ... line everything up and tighten her up. Here's some pics for your reference.
Good Luck
08-19-2012, 05:34 PM
Car: 2010 LGT & 2009 FXT
08-19-2012, 06:05 PM
Car: 2010 Subaru LGT - Stage 1
Originally Posted by acumenhokie
Each time I see that video, I laugh.
08-19-2012, 10:00 PM
Pulled off the IC and trimmed the rubber piece, tightened everything up and test drove it. No more goose noise. Thanks for the help again.
08-21-2012, 04:14 PM
Title: Teaser of the G
Car: 2012 Legacy GT
I watched the video cuz I was having a bad day at work....and I laughed too. Thanks!! I needed that.
12-03-2012, 10:19 AM
Car: 2012 BM9 2.5GT
Good Luck
I'll be doing this mod tonight since the "horny" noise came back!  Ah, well. Not that critical.
