Reload this Page Blew a fuse?
#1: 09-27-2011, 04:05 PM
Blew a fuse?
 Shertz
Shertz's Avatar
Car: 2008 Civic Si Sedan, 2010 Legacy 2.5i
Send a private message to Shertz Find all posts by Shertz Reply With Quote
I think i may have blown the fuse that goes to my cigarette lighter/power outlet...
Like a chump, i don't have the manual to the car - a base 2.5i
Can anyone provide me some assistance on what fuse i'm looking for?
I know how to replace it and know how to buy the correct one, just need help locating the correct one.
Thanks in advance
Shertz
Visit Shertz's homepage!
Find More Posts by Shertz
#2: 09-27-2011, 07:36 PM
 Rutchard
Rutchard's Avatar
Car: 2010 LGT, 2011 VW JSW TDI
Send a private message to Rutchard Find all posts by Rutchard Reply With Quote
Which power outlet? The one inside the center console bin or the one under the radio?
Rutchard
Find More Posts by Rutchard
#3: 09-28-2011, 06:29 AM
 Rutchard
Rutchard's Avatar
Interior fuse panel, to the left of the steering wheel, below the parking brake
There's a guide on the back of the door that says what all the fuses are.
The power outlet under the radio/HVAC is labeled "CIGAR" with a 10A fuse and the power outlet inside the center console is labeled "12V SOCKET" with a 20A fuse. There are spare fuses and a fuse puller inside the other fuse box in the engine bay.
Puller
Spares inside the lid
I've had the "CIGAR" fuse blow several times when using a 12V air compressor.
Rutchard
#4: 09-28-2011, 09:06 AM
 ChasWG
ChasWG's Avatar
Title: Contributing V.P.
Car: 2011 3.6R Limited
Send a private message to ChasWG Find all posts by ChasWG Reply With Quote
So then where is the fuse for the trunk open button? My internal switch to pop the trunk won't open the trunk lid, but the release on my key opens it. That seems a bit odd to me why one still works while the other doesn't. Maybe this is a dealership warrenty issue. But I'll check the fuse first as long as I can find it.
ChasWG
Find More Posts by ChasWG
#5: 09-28-2011, 09:58 AM
 Rutchard
Rutchard's Avatar
Check in the glovebox to see if you locked the trunk. There's a button all the way to the left that says "TRUNK OPENER" Press it once and see if your trunk button by the parking brake works again. (Owners Manual page 2-25)
Its supposed to be so you can lock your trunk & glovebox, then someone with the valet key can't get into them.
Rutchard
#6: 09-28-2011, 12:23 PM
 ChasWG
ChasWG's Avatar
Oh... See, that's what I get for not reading my manual from cover to cover.
Thanks Rutchard, I'll go check right now.
ChasWG
#7: 09-28-2011, 12:31 PM
 ChasWG
ChasWG's Avatar
Yup, that was it. The button was set to "Cancel," which turns off the internal trunk release button. I never knew that was there. Cool!
Thanks again man!
ChasWG
#8: 09-28-2011, 02:50 PM
 Rutchard
Rutchard's Avatar
I've seen a few posts about it over the past few years, hell I didn't even know about it at first. Every other Subaru I've owned has just had a cable release for the trunk, none of this fancy electronic stuff.
Rutchard
#9: 12-12-2012, 12:21 PM
 nuclrxn
nuclrxn's Avatar
Car: 2012 BM9 2.5GT
Send a private message to nuclrxn Find all posts by nuclrxn Reply With Quote
PEC produces the OEM blade-style, low-profile fuses for the 2010+ Legacy
http://www.pecj.co.jp/en/fuse/blade/teihai.html
Here is the patent number (US6359543)?
http://www.google.com/patents/US6359543
nuclrxn
Find More Posts by nuclrxn
#10: 12-12-2012, 12:32 PM
 nuclrxn
nuclrxn's Avatar
Car: 2012 BM9 2.5GT
Here's where you can buy the low-profile, blade-style fuses:
Sears, Metra brand:
http://www.sears.com/search=metra%20...e=CAT_REC_PRED
Amazon, Cooper Bussmann brand:
Amazon.com: COOPER BUSSMANN ATM-LP-20-10 20 Amp Low Profile Fuse: Electronics
Amazon.com: COOPER BUSSMANN ATM-LP-20-10 20 Amp Low Profile Fuse: Electronics Amazon.com: COOPER BUSSMANN ATM-LP-20-10 20 Amp Low Profile Fuse: Electronics
Amazon, Metra brand:
Amazon.com: metra low profile amp fuse: Electronics
Amazon.com: metra low profile amp fuse: Electronics Amazon.com: metra low profile amp fuse: Electronics
eBay, PEC brand (volatile link):
http://www.ebay.com/itm/1000-PEC-Low...-/350452752351
Heuberger Subaru, OEM/PEC brand:
http://heubergersubaruparts.com/part...icleid=1445356
Amazon, Littelfuse brand:
Amazon.com: Littelfuse RBOX1 Redbox MINI Low Profile Fuse Module: Automotive
Amazon.com: Littelfuse RBOX1 Redbox MINI Low Profile Fuse Module: Automotive Amazon.com: Littelfuse RBOX1 Redbox MINI Low Profile Fuse Module: Automotive
Last edited by nuclrxn; 12-12-2012 at 12:51 PM.. Reason: Better, clearer formatting, consolidating posts
nuclrxn
