Reload this Page Romraider Road Dyno won't record
#1: 11-30-2012, 10:41 PM
 volodyalysak
volodyalysak's Avatar
Car: 2005 Subaru Legacy GT Limited
Send a private message to volodyalysak Find all posts by volodyalysak Reply With Quote
Ok, tonight i used vag-com cable and romraider just to see if it works.
I don't know what to log what to look for, but i saw feature Road Dyno, selected 3-rd gear pull from 2K to 6.5 K
Clicked record data - message poped "Accelerate WOT when ready" I did but nothing happened...
I can view all parameters in real time without problem, but it would not show me torque and HP.
05 Legace gt limited 5 speed AT.
Help me out or point me in correct direction, i want to learn something and maybe do stage1 when ready.
volodyalysak
Find More Posts by volodyalysak
#2: 12-01-2012, 10:01 AM
 volodyalysak
Anyone ??? Do i ask something weird ? Just point me to right direction
volodyalysak
#3: 12-01-2012, 10:07 AM
 06silvarubiLGT
06silvarubiLGT's Avatar
Send a private message to 06silvarubiLGT Find all posts by 06silvarubiLGT Reply With Quote
there has been quite a few small issues with rom-raider from what Ive read. You might want to PM someone like Cryo that does e-tunes and see if they cant help you out. Might want to post this in the tuning forum also, may get better response there.
I tried rom-raider once, didnt work, went cobb..
06silvarubiLGT
Find More Posts by 06silvarubiLGT
#4: 12-01-2012, 01:46 PM
 zenfamily
zenfamily's Avatar
Car: 05 Big Winged Legacy GT, 13 Red BRZ
Send a private message to zenfamily Find all posts by zenfamily Reply With Quote
Definitely look into the tuning forum under the stickies. You may also want to try the romraider forum.
zenfamily
Find More Posts by zenfamily
#5: 12-01-2012, 04:09 PM
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
I just do a regular 3rd gear pull log, then on the dyno tab choose "load the file" and RR logger charts the dyno plot. If you can log your pulls fine already just do that. This method gives you time to analyze the data later at your convenience and keeps you from staring at a computer while doing WOT pulls (I use the rear defrost as my start/stop for pulls). I've never tried to do a live dyno session via the software, although I have been able to see the gauges and logging parameters live in RR.
I have zero issues with RR and am quite pleased I didn't waste money on a Cobb AP when all my open source tools do everything both I and my tuner need.
spec.B #163 Build Thread with Pictures
Get CryoTuned!
LGT.com 2006 spec.B Registry Mapped
.:Catalyst:.
Find More Posts by .:Catalyst:.
#6: 12-01-2012, 05:20 PM
 volodyalysak
.:Catalyst:.
Ok, thats totally makes sence, what parameters do yo select in RR to obtain hp and torque ? I read romraider forum, but can't find those.
Thanks
volodyalysak
#7: 12-03-2012, 03:01 PM
 .:Catalyst:.
My tuner has me log the following, and when loaded into the dyno tab on RR logger it displays the HP/Torque curves:
Engine Load 4byte
Engine Speed – RPM
IAM
Ignition total timing
Injector duty cycle
Knock Sum 4byte
Manifold relative pressure *corrected*
Mass Airflow Voltage
Primary Wastegate duty cycle
Throttle opening angle
boost error
AF Sensor #1 Ratio(AFR)
Also make sure you choose the correct car type in the drop down, correct tire size to calculate diameter, temperature, humidity, and elevation. I also factor in how much fuel is in the tank for the weight as well as my own to be as accurate as possible.
Get CryoTuned!
.:Catalyst:.
