Reload this Page weirdest thing happen today!
#1: 04-13-2013, 09:43 PM
 solidkevlar
solidkevlar's Avatar
Car: 05 subuaru legacy gt
Send a private message to solidkevlar Find all posts by solidkevlar Reply With Quote
today i got into my car and pushed the rear defrost and the horn came on tell i turned it off. so i decided to do it again once i got out of traffic... ya i felt like a ass as the horn blared for like 15 sec at a stop light. this time it took about 5 times before it did it again ,but every time i push it i can hear a click inside the steering wheel. any thoughts?
solidkevlar
Find More Posts by solidkevlar
#2: 04-13-2013, 10:11 PM
 MAP
MAP's Avatar
Car: 05 Legacy GT, 5EAT
Send a private message to MAP Find all posts by MAP Reply With Quote
Sounds like some short. Youre going to have to get a wiring diagram that shows the wiring for both those functions to determine where the wiring comes close to each other. It sounds like the problem could be in the steering wheel if you hear something there. Im assuming both functions have their own relay. Its possible wire energizing the defrost relay is somehow also energizing the horn relay. Tough to figure out without checking a schematic, or cable harness/ connector diagram.
MAP
Find More Posts by MAP
#3: 04-14-2013, 04:47 AM
 Max Capacity
Max Capacity's Avatar
How old is the car battery ?
These cars have been known to do strange things when the battery votlage gets low.
Max Capacity
#4: 04-14-2013, 11:30 AM
 solidkevlar
its old i should change it ...
solidkevlar
#5: 04-14-2013, 11:33 AM
 mwiener2
mwiener2's Avatar
Title: Trunk Monkey Chief
Car: 2005 Rocketback, 2010 Clown Car
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
If this is happening with the engine running, it's not your battery or a low voltage problem... unless you've needed to jump the car a lot.
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
mwiener2
Find More Posts by mwiener2
#6: 04-14-2013, 11:33 AM
 solidkevlar
this stuff gets me scared . cause my old 300zx burned to the ground cause of electical problems.also my buddys golf gti vr6 they think his had something to do with the hids that got installed. my z car was stock, only had it 6 months
solidkevlar
#7: 04-14-2013, 11:36 AM
 solidkevlar
no i started the car from a event in fargo, let it warm up, turned on the road and at the stop light i hit the defrost and it happend.
solidkevlar
#8: 04-14-2013, 05:22 PM
 mwiener2
mwiener2's Avatar
Mice
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
mwiener2
#9: 04-14-2013, 05:42 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Originally Posted by mwiener2 View Post
Mice
BarManBean
Find More Posts by BarManBean
#10: 04-14-2013, 06:18 PM
 solidkevlar
i found out the problem my lil boy spilt his drink in the cup holder and it leaked threw on the wire connector so i had to take it apart and clean it all up i got it to stop...wife failed to tell me this the other day.
solidkevlar
#11: 04-15-2013, 11:51 AM
 InnocentGuns
InnocentGuns's Avatar
Car: 05 L/GT,99 tib, 99 gmc, 06 M109r,
Send a private message to InnocentGuns Find all posts by InnocentGuns Reply With Quote
Glad you got it resolved.
InnocentGuns
Find More Posts by InnocentGuns
#12: 04-15-2013, 04:20 PM
 Chameleon
Chameleon's Avatar
Car: '05 Subaru Legacy GT
Send a private message to Chameleon Find all posts by Chameleon Reply With Quote
Thats a sigh of relief ...
Chameleon
Find More Posts by Chameleon
#13: 04-15-2013, 07:24 PM
 ragman
ragman's Avatar
Car: '05 LGT Wagon Limited 5EAT BNR EVO16G
Send a private message to ragman Find all posts by ragman Reply With Quote
HA!! Somehow its always the wife's fault!
ragman
Find More Posts by ragman
#14: 04-16-2013, 06:31 AM
 ChachiFBaby
ChachiFBaby's Avatar
Car: Subaru Legacy
Send a private message to ChachiFBaby Find all posts by ChachiFBaby Reply With Quote
This sounded like a VW forum for a bit...
ChachiFBaby
Find More Posts by ChachiFBaby
