Reload this Page Power Steering going?
#1: 12-09-2012, 10:11 AM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
Send a private message to TimmonsBM Find all posts by TimmonsBM Reply With Quote
Hi there, I have a '05 GT manual with 87k miles. I think the power steering is going on it. Anyone have that problem and can explain what it feels like? At speeds on the highway it handles well but at slow speeds it is almost impossible. Any other ideas besides power steering? How hard is it to fix that?
TimmonsBM
Find More Posts by TimmonsBM
#2: 12-09-2012, 10:42 AM
 PeterJMC
PeterJMC's Avatar
Title: Lvl 63 Night Elf Dwarf Paladin
Car: '13 Toyota Prius: Drive Yo' Self Edition
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
I would answer these questions, hopefully it will help figure out where the problem might be. In general, if your power steering pump wasn't working you would find it easier to move the steering wheel as your speed increases vs while you are slow moving.
Do you hear any whining/squeeling noises coming from the pump/ engine bay when you turn your steering wheel?
Inspect your accessory belt which drives your power steering pump for excessive wear
- If your belt isn't biting it won't drive your power steering pump.
Inspect the power steering fluid reservoir to ensure it's full.
Inspect the power steering fluid hoses for signs of moisture.
- Signs of moisture around the hoses would indicate there is a leak which would cause low fluid levels or introducing air into the system.
'13 Prius: Drive Yo' Self Edition
PeterJMC
Find More Posts by PeterJMC
#3: 12-09-2012, 12:18 PM
 gear_monkey
Send a private message to gear_monkey Find all posts by gear_monkey Reply With Quote
I am having some symptoms that might help the OP. Just after starting my car, if I turn the steering wheel, while still parked, I get a gritty, gear feeling feedback in the steering wheel.
As soon as I start to drive, it smoothes out. I did a complete fluid flush a few days ago following the great guide found on this site. I was very hopeful that would solve my problem.
Yesterday, after starting the car, I quickly turned the steering wheel while backing out of a parking spot and I got two short loud belt squeals.
I took the drive belt off while flushing the fluid and it looked to be in good shape with no visible cracking.
I'm stumped. Hope this aids the OP and isn't a thread hijack.
gear_monkey
Find More Posts by gear_monkey
#4: 12-09-2012, 04:12 PM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
Thanks for the help. The reservoir has proper fluid, ill check the rest once I get a chance. The car is hard to steer at sub 5mph speeds but also had issues when exiting highway and going through the large loop.
Thanks monkey I now know that probably won't fix my issues.
TimmonsBM
#5: 12-10-2012, 03:04 PM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
Help please
TimmonsBM
#6: 12-11-2012, 03:39 AM
 Max Capacity
Max Capacity's Avatar
Did you buy the car new ?
Does it have the proper fluid in it ?
Max Capacity
#7: 12-11-2012, 07:32 AM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
I did not hut the car new. It does have proper fluid.
TimmonsBM
#8: 12-11-2012, 07:39 AM
 PeterJMC
PeterJMC's Avatar
SO did you check the condition of your drive belt?
- Are there cracks in the ribs?
- Is there excess slack in the belt and the tensioner might need to be tightened? (You will need to consult the repair manual on this step)
Did you check the condition of the power steering lines?
- Is there moisture on the lines? (would be evidence of air getting into the system and causing problems.
If all check out okay, try to flush fluid.
If flushing fluid doesn't work, I would suspect you have a failing PS pump.
If you have any difficulties with doing the above, I'd recommend you take it to a shop and see if hey can help figure out the problem.
PeterJMC
#9: 12-11-2012, 10:57 AM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
I dropped it off this morning at the repair shop on base they called me a bit ago and Said that the belt was bad and are replacing that. Only about 100$ so not to bad hopefully that fixes the problem. I'll let u guys know, thanks for the advice.
TimmonsBM
#10: 12-11-2012, 12:03 PM
 Max Capacity
You know the belt is about $15-20.00
If you plan to keep this car for a while. You may want to learn how to use the Auto Hobby Shop and start doing preventitive maintenance. Once you learn these are fairly easy to work on.
Hang around here, we can teach you.
The Following 2 Users Say Thank You to Max Capacity For This Useful Post:
liljonson (12-12-2012), PeterJMC (12-13-2012)
Max Capacity
#11: 12-11-2012, 12:20 PM
 rice_rocket
Car: 05 LGT
Send a private message to rice_rocket Find all posts by rice_rocket Reply With Quote
I was actually thinking about this the other day myself. I have always had a bit of a squeak when first starting up with cold belts so I didn't think much of it. I have noticed lately my dry steering is absolutely horrible when I had to get out of a tight parking spot in my parking garage. I did just peek at the reservoir and it is full, but didn't inspect too far. I'm also not sure which belt is the PS belt specifically, but I did a full check on all the belts that I could touch and didn't feel anything special. I always do my own work, but with a second kid now time is at such a premium.. I hope to get to a full timing belt job as soon as it gets warm.. that or pay someone to do it for the first time in my life
Funny how I came across the thread about this. My car certainly has no problems steering after I get to a couple MPH so it doesn't sound as severe as the OP. I did also jump up tire size to 18's.. but kept the same width of tread so I don't see why the tires would be harder to steer at a dead/slow speed.
rice_rocket
Find More Posts by rice_rocket
#12: 12-11-2012, 12:22 PM
 rice_rocket
Car: 05 LGT
Oooh, one thing to add/ask for people here. I was told back in the day that I can use the auto-tranny fluid as power steering fluid.. seeing as I have extra.. would this work/mix with whatever I have? I could certainly take a few minutes, suck out what fluid is in the top of the reservoir, and fill it back up every few days just before I leave the parking lot at work.. yeah I know it's not a flush, but I'm sure it would help?
rice_rocket
#13: 12-12-2012, 04:03 AM
 TimmonsBM
TimmonsBM's Avatar
Car: '05 LGT Ltd
Got the car back yesterday and everything is fine. No issues at all.
The Following User Says Thank You to TimmonsBM For This Useful Post:
TimmonsBM
#14: 12-12-2012, 05:11 AM
 liljonson
liljonson's Avatar
Car: 07 LGT
Send a private message to liljonson Find all posts by liljonson Reply With Quote
He is right. I've been a tech for about a decade at Toyota and Subarus in general are the easiest cars you were will work on and I work on the second easiest make lol. Definitely learn from the forums and save lots and lots of money
Sent from my Galaxy Nexus using Tapatalk 2
liljonson
Find More Posts by liljonson
#15: 12-12-2012, 07:08 AM
 Max Capacity
Spend the few bucks and put the correct fluid in it. your much better off doing that. It's much cheaper than screwing something up the cost over $100 to replace.
Think about it...
Max Capacity
