jikhead Posted September 30, 2005 Share Posted September 30, 2005 Will the red Subaru 4 pots/2pots that are from Japan fit on the LGT? Link to comment Share on other sites More sharing options...
inthedeck Posted September 30, 2005 Share Posted September 30, 2005 Dunno...but you could definately fit the USDM STi front calipers, with no issues. The rears, though, require some modification. Also, they can probably be sourced cheaper! than the JDM ones. Just a thought. Link to comment Share on other sites More sharing options...
SVXWRX Posted September 30, 2005 Share Posted September 30, 2005 Will the red Subaru 4 pots/2pots that are from Japan fit on the LGT? the red 4-pots on the '06 USDM WRX might be easier to get than JDM ones. Link to comment Share on other sites More sharing options...
apexjapan Posted September 30, 2005 Share Posted September 30, 2005 Note - they use smaller brake pads than the 2-pot fronts currently on your car, so will not actually improve braking performance that much, if at all. Cheers, Paul Hansen http://www.avoturboworld.com | http://www.sevenphotos.com | http://www.scoobymag.com Link to comment Share on other sites More sharing options...
edmundu Posted September 30, 2005 Share Posted September 30, 2005 With the exception of better pedal modulation/feel/response, it is a downgrade! The rotors are considerably smaller & thinner. Read much less mass to absorb heat, which is what your brakes do. Like Inthedeck mentioned, pickup up STI Brembo's, or good aftermarket stuff like Stoptech, Ap Racing, Alcon, Brembo GT's.... I have the STI Brembo's, and I love them! Simply awesome stopping power, and I can do it repeatedly without issues. Link to comment Share on other sites More sharing options...
BatChips107 Posted September 30, 2005 Share Posted September 30, 2005 where can you buy the STi Brembo's and how much do the fronts run?? Link to comment Share on other sites More sharing options...
edmundu Posted September 30, 2005 Share Posted September 30, 2005 where can you buy the STi Brembo's and how much do the fronts run?? You can buy them used, for anywhere from $700-850, the current going rate. OR you can buy them NEW for about $1350, and they would include slotted/drilled rotors + better pads + ss lines. I bought my set used, and I bought 2pc rotors, along with Ferodo ds2500 pads & ss lines. I basically paid the same as I would have NEW, but I have superior rotors/pads! Link to comment Share on other sites More sharing options...
Limeade Posted October 12, 2005 Share Posted October 12, 2005 Got a link to who sells them new? Link to comment Share on other sites More sharing options...
edmundu Posted October 12, 2005 Share Posted October 12, 2005 Mastro Subaru just had a sale on them! But a bunch of vendors sell them. checkout the Nasioc boards, as someone usually has a sale on them. Edit: I forgot the link, and it looks like they are still on sale! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted October 12, 2005 Share Posted October 12, 2005 im not sure if the sti front brembo's will fit under the stock wheels...does anyone know? Link to comment Share on other sites More sharing options...
edmundu Posted October 12, 2005 Share Posted October 12, 2005 im not sure if the sti front brembo's will fit under the stock wheels...does anyone know? No they will NOT fit under stock wheels without a rather large 12-13mm spacer! Link to comment Share on other sites More sharing options...
al-gorithm Posted October 12, 2005 Share Posted October 12, 2005 I assume that the LGT Goodyear SS lines will work too. Someone please correct me if I am wrong. Link to comment Share on other sites More sharing options...
edmundu Posted October 12, 2005 Share Posted October 12, 2005 I assume that the LGT Goodyear SS lines will work too. Someone please correct me if I am wrong. Yes, any line for the LGT will work. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted October 13, 2005 Share Posted October 13, 2005 No they will NOT fit under stock wheels without a rather large 12-13mm spacer! didnt think so Link to comment Share on other sites More sharing options...
agctr Posted October 13, 2005 Share Posted October 13, 2005 Know of anyone that sells the Brembo upgrade in Oz ? Ada///M. Link to comment Share on other sites More sharing options...
eL GaTo Posted October 22, 2005 Share Posted October 22, 2005 I have been looking for aftermarket front rotors(stock size) for the LGT 05 and have been unsuccesful to date. I have checked Brembos, Racing Brakes ....etc. with no luck. The stock size, I believe, is 316mm x 30mm. "Remember..."MODDING is a HOBBY:icon_bigg, not a BAAAD HABIT";) . Link to comment Share on other sites More sharing options...
Leonardo Posted October 22, 2005 Share Posted October 22, 2005 I'm getting STi fronts and Godspeed has the caliper bracket to fit the rear brmbo on the Leg GT and is working on the inserts to have use of the parking brake like on his STi-to-WRX kit. Link to comment Share on other sites More sharing options...
Leonardo Posted October 22, 2005 Share Posted October 22, 2005 Oh, enjoy! http://cgi.ebay.com/ebaymotors/2003-Subaru-WRX-STI-Brembo-Brakes_W0QQcmdZViewItemQQcategoryZ107058QQitemZ4584592992QQrdZ1QQsspagenameZWDVWnd Link to comment Share on other sites More sharing options...
avs Posted October 27, 2005 Share Posted October 27, 2005 Everyone are talking about upgrading to bigger brakes. What about a bigger master cylinder ? Link to comment Share on other sites More sharing options...
edmundu Posted October 27, 2005 Share Posted October 27, 2005 Everyone are talking about upgrading to bigger brakes. What about a bigger master cylinder ? You would need a bigger master if you wanted to push a greater amount of fluid thru the system with less pedal stroke. I'm running STI Brembo's and if I even look at the brake pedal the car reacts! Seriously, I just nudge the pedal with my big toe, and the car is stopping right now! I don't think we need one. I'm not a professional, just relying upon my personal experience. Link to comment Share on other sites More sharing options...
derffred Posted October 27, 2005 Share Posted October 27, 2005 damn, i definately want bigger/better calipers without getting bigger wheels.. i don't want 18s.. how tight of a squeeze is it? Link to comment Share on other sites More sharing options...
Leonardo Posted October 28, 2005 Share Posted October 28, 2005 Just get 17x8 Rotas or STi teke-offs Link to comment Share on other sites More sharing options...
derffred Posted October 28, 2005 Share Posted October 28, 2005 go to pl-tek.. they have big brake kits for the LGT... kinda expensive.. but they give options. Link to comment Share on other sites More sharing options...
Boxer2Blower Posted December 31, 2005 Share Posted December 31, 2005 What about the WRX set-up on an OBTX? Our brakes are smaller than the LGT. Link to comment Share on other sites More sharing options...
zildjiank Posted January 1, 2006 Share Posted January 1, 2006 Here is a link for some brake components for the Leggy... Might want to make sure it is compatible though for the 2005 GT model year http://www.teaguesauto.com/Brakes.htm#Brake%20Pads Link to comment Share on other sites More sharing options...
