#1:
11-18-2012, 08:59 PM
2013 HK headunit question
Car: 2012 LGT
Could someone with a 2013 Legacy Limited with the non-NAV H/K radio post what the model number is (the number on the lower right corner of the stereo) - curious if it's the same as the 2012 (which is PE627UI) - thanks!
#2:
04-08-2013, 01:32 PM
Car: 2012 Legacy GT 6MT
Anyone ever answer this? I'd also be interested in a head unit swap for my 2012.
#3:
04-08-2013, 02:00 PM
Title: Teaser of the G
Car: 2012 Legacy GT
I have my dash trim pulled right now so I will try to remember to look.
#4:
04-08-2013, 03:08 PM
Car: 2012 LGT
In the 2013 Outback, the number on the front is PE658U1 - what I don't know is if that's the same for the 2013 Legacy.
#5:
04-09-2013, 07:01 PM
Car: 2013 Legacy 2.5i Limited
PE658U1
Sent from my PG86100 using Tapatalk 2
#6:
04-09-2013, 07:43 PM
Car: 2012 LGT
So that radio will support a rear camera, if you are so inclined (it's equipped that way in the Outback)
#7:
04-09-2013, 08:47 PM
Nice ... are the RCA connections present in the back of the car to connect the camera? I've got a 2013 Legacy Limited with the HK Head Unit and speaker system, and am thinking about installing a camera.
#8:
04-10-2013, 07:02 AM
anyone know if the navigation unit can be swapped? It looks like a much nicer upgrade compared to 2012.
#9:
04-10-2013, 10:18 AM
Car: 2012 3.6R Limited RRP
For what you'd pay for a new oem head unit (over $1000), you could get a much, much nicer aftermarket unit.
#10:
04-11-2013, 07:41 AM
sucks, maybe I'll wait fir them to end up in junk yards
I like OEM
#11:
04-11-2013, 05:30 PM
Car: 2012 LGT
Yes, but not as RCA connectors - it uses 4 pins from the long two row, 28 pin connector
It's hard to tell - there are a number of connectors which are different between the H/K head unit and the NAV head unit - you could probably make it work with some wiring, but it doesn't look to be plug and play
The Following User Says Thank You to DrD123 For This Useful Post:
#12:
04-11-2013, 06:07 PM
Car: 2012 Legacy GT
I have the PE627U1 and I will verify tonight what the RCA adapter harness looks like for the AUX. The one pictured in the EBay link below clearly includes video.
http://www.ebay.com/itm/AUX-USB-Cabl...f01805&vxp=mtr
#13:
04-11-2013, 06:23 PM
Car: 2012 LGT
So that OEM one from China looks a little different than what is in my car or what I have seen in 2013 - the center coax connector is covered, as well - not sure what's up with that.
Anyway - the 2012 H/K unit (PE627U1) does not support the rear view camera as far as I can tell (when you go into the diagnostic mode, it doesn't list the rearview camera, either) - the 2013 H/K unit (PE658U1) does support a rear view camera. The connectors are the same - the only difference on the wiring diagram from 2012 to 2013 is the addition of the rear view camera leads.
I looked more at the connectors for the NAV unit - it looks like the 2013 NAV might work with the 2012+ H/K system - most of the connectors look to be the same, whereas there were a number of ones which were different for the 2012 NAV. (still not a very cost effective way to add NAV, but if you can get one cheap, it might be worth it - note that you also need to replace the trim around the radio if you add the NAV unit)
#14:
04-11-2013, 06:37 PM
Car: 2012 Legacy GT
I just want a camera, not nav.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
