Reload this Page Valve cover removal
#1: 11-19-2012, 10:28 AM
Valve cover removal
 hukne001
hukne001's Avatar
Car: 2005 Legacy GT, 1998 Outback Sport
Send a private message to hukne001 Find all posts by hukne001 Reply With Quote
What I know: I need to remove my passenger side valve cover due to it dripping oil onto the uppipe and creating a nasty burning smell.
Don't know: If the leak is due to a cracked valve cover or just a bad gasket.
Need to know: What are some tips for those that have removed their valve cover and is there any gaskets or seals that will need to be replaced in removal of valve cover and other items during this process?
Thanks
hukne001
Find More Posts by hukne001
#2: 11-19-2012, 10:31 AM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
most likely bad gasket
search search search
this was just covered again last week.
Nrw
Find More Posts by Nrw
#3: 11-19-2012, 10:37 AM
 hukne001
hukne001's Avatar
I did search but didn't find anything. I'll try look again
hukne001
#4: 11-19-2012, 10:40 AM
 Nrw
Nrw's Avatar
https://www.google.com/search?q=valv...w=1098&bih=450
Nrw
#5: 11-19-2012, 10:44 AM
 Lucid
Lucid's Avatar
Car: 06 BSM OBXT, 06 SWP 2.5i
Send a private message to Lucid Find all posts by Lucid Reply With Quote
I don't think there's a walkthrough for the valve cover gaskets, but this thread has some good tips:
http://legacygt.com/forums/showthread.php?t=179627
It's not too tough. On my OB I did the passenger side, in place, without running into any complications. On the 2.5i, both sides were leaking, and the timing belt needed done so we just pulled the engine.
Good luck.
Lucid
Find More Posts by Lucid
#6: 11-19-2012, 11:04 AM
 hukne001
hukne001's Avatar
See when I do my searches I type it in on the forum search and never seem to get relevant anything.
Thanks lucid
hukne001
#7: 11-19-2012, 12:05 PM
 Max Capacity
Max Capacity's Avatar
Yea, most of us know the search function, sucks.
Max Capacity
#8: 11-19-2012, 12:33 PM
 mustangendsley
mustangendsley's Avatar
Car: 2005 2.5 GT Limited, Stage 2
Send a private message to mustangendsley Find all posts by mustangendsley Reply With Quote
it is a pain in the ace job. bolts are hard to get to in the back. gasket always falls off. i had a hard time with mine. a subaru mech had a hard time doing it also. Took him 3 times.
mustangendsley
Find More Posts by mustangendsley
#9: 11-19-2012, 10:39 PM
 Aracheon
Aracheon's Avatar
Title: Clutch Artist
Car: 05 SWP Limited 5MT Wagon
Send a private message to Aracheon Find all posts by Aracheon Reply With Quote
I took a stab at the RH one with the engine in the car - the gasket ended up folding up inside the cover upon reinstallation, and as you can imagine, made a hell of a mess all over the floor.
Since my clutch was making a little bit of noise anyway and I feared having to install a TSK3, I just yanked the engine out and did both rocker cover gaskets at the same time. Hell of a lot easier with the engine out of the car. (Though I've been told you can raise the engine up a few inches to give the space you need to do the covers.)
But since it took me the same amount of time to do the passenger side cover gasket with the engine in the car as the process of pulling the engine and reinstalling it, I'm not sure which route I'd take if I had to do it again. Would depend on how much space I had, I suppose.
Aracheon
Find More Posts by Aracheon
