Reload this Page Reinstalling the steering knuckle to strut
#1: 11-17-2012, 05:06 PM
 Nbalcom
Send a private message to Nbalcom Find all posts by Nbalcom Reply With Quote
I took the steering knuckle off to replace ball joints and cv joints. When I removed the strut-to-knuckle bolts, the strut extended down (from spring pressure I assume). Now I'm having a difficult time getting the steering knuckle back into the slot on the strut. how is one to compress the strut to get it put back together? Am I missing something?
Nbalcom
Find More Posts by Nbalcom
#2: 11-17-2012, 05:08 PM
 Stang70Fastback
Stang70Fastback's Avatar
Car: 1998 Subaru Legacy Outback Limited
Send a private message to Stang70Fastback Find all posts by Stang70Fastback Reply With Quote
If anything, from my experience, the knuckle should easily fall further down than the strut. The strut is the only thing keeping the wheels from dropping further when you jack the car up. So it sounds like you don't have something disconnected. Is the swaybar still attached?
Also, you DID mark the angle of the top strut-to-knuckle nut right? Because that's how your alignment is done, lol.
Stang70Fastback
Find More Posts by Stang70Fastback
#3: 11-17-2012, 09:02 PM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
Are you doing it in the drive way with only one side jacked up? If so, the sway bar is under torsion and you will NEVER get thing lined up until you disconnect the swaybar.
Actually, while we are talking about the swaybar....disconnect the endlinks regardless of if you have only one, or both sides jacked up. It will give you a little bit more travel with the lower control arm and make things a million times easier.....especially if its an Outback
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#4: 11-17-2012, 09:13 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
You can put a 2x4 under the hub bolts and jack it up to compress the strut and spring.
monkeyposeur
Find More Posts by monkeyposeur
#5: 11-17-2012, 09:35 PM
 Kennyfvholla
Kennyfvholla's Avatar
Car: 99 OBL, 04 Accord EX 6MT coupe
Send a private message to Kennyfvholla Find all posts by Kennyfvholla Reply With Quote
Take one bolt out of the sway bar end link and it will allow you to get the arm low enough. That's exactly how I did it.
The Following User Says Thank You to Kennyfvholla For This Useful Post:
monkeyposeur (11-17-2012)
Kennyfvholla
Find More Posts by Kennyfvholla
#6: 11-17-2012, 09:43 PM
 monkeyposeur
Car: 95 BK, 93 SS!
That too, lol.
monkeyposeur
#7: 11-18-2012, 07:24 PM
 Nbalcom
I knew I was missing something. I can work on engines all day, but have little experience with suspension stuff. Really appreciate the help!
Nbalcom
