Reload this Page Clutch rattle?
#1: 03-31-2013, 06:43 PM
Clutch rattle?
 Matt166
Send a private message to Matt166 Find all posts by Matt166 Reply With Quote
Looking to see if anyone has a similar symptom.
While accelerating I get a breif rattle at low revs - around 1 to 1.5k rpm. Seems to be coming from the middle of the car and only noticeable with the window down.
It happens in every gear, so is tied to rpm. However It does not make a noise while the car is revved stationary.
My guess is something loose on the clutch plate - any ideas?
Matt166
Find More Posts by Matt166
#2: 03-31-2013, 06:53 PM
 lesanekusa
lesanekusa's Avatar
Car: 1998 legacy outback &2006 B-9 Tribeca
Send a private message to lesanekusa Find all posts by lesanekusa Reply With Quote
check your heat shield. Between exhaust pipe and drive shaft.Last time I have a big chunk of ice stuck between shield and drive shaft .From drifting in deep snow LOL. Slide under the car and try to tap the shield.It's wort a try.
lesanekusa
Find More Posts by lesanekusa
#3: 03-31-2013, 08:12 PM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
Car: 2009 OBP Legacy 2.5i SE 5sp
Send a private message to GEE-OTTO Find all posts by GEE-OTTO Reply With Quote
How many miles on the car? Original clutch ? If it is a more solid "clacking" it is the clutch if it is a more thin sheet of metal rattle could be a heat shield.
GEE-OTTO
Find More Posts by GEE-OTTO
#4: 03-31-2013, 08:35 PM
 Matt166
150k on car, clutch and gearbox replaced with a new OEM unit by PO at 100k.
Its not the usual heat shield rattle I have had on previous cars. Sounds more like a chirpy rattle.
The other reason I ruled out the heat shield is that it doesn't happen when the car is stationary. Seeing as a clutch plate will rotate at the same rpm in every gear when the car is actually moving regardless of mph it has me thinking that it may be the cause.
Matt166
#5: 04-01-2013, 04:51 PM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
50K on a stock clutch esp one that sees increased wear can be the death of it...
GEE-OTTO
