Go Back   Subaru Legacy Forums > Technical Forums > Transmissions
Reload this Page Emergency!! help please
#1: 11-24-2012, 05:31 PM
 quick4dr
quick4dr's Avatar
Title: Contributing V.P.
Car: 05GT BNR 16g, EWG,ELH,FMIC w/cdVB, EFI
Send a private message to quick4dr Find all posts by quick4dr Reply With Quote
hey on my way up my street i started smelling trans fluid. Pulled in my driveway and had an ocean under the car and a trail leading up my street. my tranny cooler line rupture and split. After I replace the line, what Trans Fluid is safe to add to the trans since Subaru is closed sundays and I cant get their stuff. What should I use, or should i wait till monday to add fluid, and just let the car sit after I replace the hose? how much damage can be done to my trans if i lost a lot of fluid over the course of about 2 football fields all at idle crawling.
quick4dr
Find More Posts by quick4dr
#2: 11-24-2012, 06:13 PM
 subielova88
subielova88's Avatar
Car: 97Gs-t, 92 TSI AWD(Projects)05 LGT 5MT
Send a private message to subielova88 Find all posts by subielova88 Reply With Quote
Genuine Subaru Automatic Transmission Fluid
IDEMITSU ATF HP
Castrol Transmax J
Pennzoil ATF J *
* Available Only in the USA (except Alaska and Hawaii)
Those are the only fluids you can use in your transmission, and you should be fine with your trans, i am a auto technician myself and I've seen worse things happening in the field to transmissions and they were ok, so fix your line and make you sure you check your fluid level the proper way...
The Following User Says Thank You to subielova88 For This Useful Post:
quick4dr (11-24-2012)
subielova88
Find More Posts by subielova88
#3: 11-24-2012, 08:04 PM
 quick4dr
quick4dr's Avatar
Thank you Dave - hexmods for the assist on my trans issue! Class act !
The Following User Says Thank You to quick4dr For This Useful Post:
xero287 (11-24-2012)
quick4dr
